Reparer "døende" Telldus TZWP-100
LarsH
Jeg har en bunke Telldus TZWP-100 (TZWP-101) brytere. Etter 4 år i drift, har noen av de har begynt å "dø".
Det starter med litt summing når de skrus på, eller de kan gå helt berserk (avpåavpåavpåavpå...).
I stedet for å bytte ut modulene (= endel jobb i Home Assistant), er det lett å gi de nytt liv med nye kondensatorer i strømforsynings-modulen.
Hittil har jeg fikset 4stk.
Strømforsyningen i TZWP-100/TZWP-101 er mistenkelig lik referansedesignet til AC/DC -konverteren (LNK304DG).
Du trenger:
* 3-kantet "stjerne"-trekker
* Nye kondensatorer av god kvalitet:
- 2stk 4.7uF 400V 105C Ø8mm H12mm
- 1stk 100uF 16V 105C Ø5mm H12mm
- 1stk 10uF 50V 105C Ø5mm H12mm
(Høydene er cirka. Det er litt å gå på)
* Litt lodde-erfaring (blyfritt - kan være en utfordring)
Bytt ut disse 4 kondensatorene:
Nye kondensatorer:
Nye kondensatorer på plass:
  • Like 4
  • 11 måneder senere...
Hi!
I have that exact problem with many telldus units. Fortunately I didn't throw them away, and after reading your post I'm definitely going to fix them!
But I don't know where to buy those capacitors. I live in Sweden and has looked at www.elfa.se, but there are so many different capacitors to choose from. Where did you find your capacitors, and what kind of capacitors are they more exactly? I have found many different kinds of capacitors, but I do not know which ones to choose.
Thanks in advance!
49 minutes ago, PEK said:
Hi!
Thanks in advance!
I bought them somewhere on Ebay. Elfa is (unfortunately) too expensive for small buys.
The capacitors are Radial Electrolytic Capacitors, preferrably with low ESR.
They need to be specified for up to 105 degrees Celcius.
4.7uF 400V has 3.5mm pitch between leads.
10uF 50V and 100uF 16V are both 2mm pitch.
If you are able to get hold of quality caps like Panasonic or other Japanese ones, you're good to go.
Beware of fake components when not using a well reputed seller.
Elfa is well reputed 🙂 but expensive.
Ang. blyfri: Jeg bruker standard gammeldags 60/40 loddetinn.
Tillfør 60/40 tinn på loddepunktene og fjern alt med solderwick så komponenten kommer fri fra PCB.
Lodd på plass komponenten med 60/40.
Fjern fluss og andre urenheter fra loddepunktene med isopropanol
Blyholdig tinn er ikke så sprøtt som blyfritt og vil formodlingen tåle mere.
Uansett er blyholdig loddetinn til reperasjoner mere miljøvennlig da apparatet får en lengre levetid.
Apparater som ikke lar seg reparere avhendes selvfølgelig på "gjenbruksstasjonen" i riktig container.
