MOVEZ(z-wave) indiegogo kampanje
Salvesen
Da var det ny oppdatering fra teptron, ny utsettelse. 1-2 måneder, var noe med godkjenningen av radioen som var problemet denne gang. Så får vi håpe dette er siste utsettelse så vi får brukt de litt i sommer..
Saw it coming! :P
Ny oppdatering fra 15. august:
Quote
Hi Backers!
Quick update.
We are currently working with the last pieces of the puzzle and everything is still going according to plan, even though the time schedule is off. Many of you have contacted us about integration with different hubs. We are in contact with a 10-20 number of different hub manufacturers regarding integration of MOVEZ so it will work "out of the box". Otherwise, we are waiting for certifications that you know through the latest update. We understand that it's frustrating that the product development has been delayed but we are soon there and the result will be really good. Thank you for all the support and have a really nice week!
44 minutter siden, MortenB skrev:
Halve september unnagjort, snakker vi nok en forsinkelse??
Begynner å bli litt utålmodig..
Enig, begynner å bli litt matt av liten oppdatering og oppfølging. De burde heller bare si 3-4 måneder i stede for å oppdatere hver måned pga de har sagt 1-2. Men det skal visstnok ha blitt en ny policy hos indie* at en må oppdatere hver måned, så satser på det kommer ny info snart. Håper bare det er "reell" info denne gang..
posted by MOVE by Teptron Sep 16, 2017 • 11:59AM
3 days ago
Current status
Hi from Sweden!
We are still working as fast as possible to complete MOVEZ with all things required.
That said, due to the delays we will add free batteries to all units!
4 x AAA Rechargeable NiMH batteries will be supplied to each MOVEZ unit.
We have tested a lot of different battery types with the product and the batteries that you will be provided is the best we have found.
Last but not least thank you for your patience and have a really nice weekend!
Team MOVEZ
Ikke et ord om forventet levering. Det tyder ikke bra ... ☹️
Nei her er det bare til å smøre seg en skive til med tålmodighet, men sånn er det vel med kickstarterprodukter :) Dog litt merkelig at her hadde de vel et fungerende produkt, og skulle bare hive inn Z-wave støtte (sikkert ikke bare bare men men) det fine er at jeg kan utsette innkjøpet av solrullegardiner litt til ?
  • 4 uker senere...
Nope, 29 dager siden sist. Så om de skal følge retningslinjene bør det komme noe de neste dagene [emoji4]
Det kom faktisk en mail i dag.
De sier ikke så mye om leveringsdato men gir oss mulighet til å kjøpe bedre solcellepanel....
New solar panel!
We have some good news to share with you.
As you all probably know there is a solar panel included in the package. Our initial thought was that the user automates the device based on solar conditions which means that the motor will only run when the sun is bright enough. So there will be a balance between energy consumption and energy gains and the unit will be self sufficient. That was perfect in theory...
In real life the user wants to use the device even when the sun is not strong enough to charge the batteries e.g. for privacy and going to bed at night.
Because of the feedback we have received from our 10.000 + users we have been developing a new solar panel that is powerful enough to charge the batteries in a sufficient way. Ta-da! It´s now released and available at https://www.teptron.com/product/solar-panel .
If you are interested in adding the larger solar panel to your MOVEZ kit we are going to give you an exclusive backer discount of 20%! Use the bonus code MOVEZVIP20 when you place the order and the larger solar panel will be shipped along with your Indiegogo order.*
When it comes to MOVEZ we are still working on the software and waiting for the certifications. That said we are moving forward and we want the product to be market ready as fast as possible, just like you. So we are all in this together with the same goal in mind.
*The solar panel offer is for MOVEZ backers only. If used by a non MOVEZ backer we will cancel the order.
[\quote]
