70
Alt skrevet av SveinHa
Leker litt med Node-Red Dashboard, ikke like rett frem for meg... Problemstilling: Har en slider som styrer en dimmer i HS4. Dimmeren styres også fra flere andre steder og må ha tilbakemelding i NR Dashboard uavhengig av hvor den er styrt fra. Har laget noe greier som virker men lite elegant. Dimmeren styres greit fra NRD men i det jeg har sluppet den hopper den til gammel verdi men retter seg da jeg kjører en Sync hvert 10 sek. Lite elegant, noen som har bedre løsninger? [{"id":"a17d57ca2bd415ed","type":"inject","z":"bd6892582b896458","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":false,"onceDelay":0.1,"topic":"sync","x":90,"y":1080,"wires":[["51e7fbdbd2098aeb","3e2336b1e2952084"]]},{"id":"2b572d1453bf7926","type":"ui_slider","z":"bd6892582b896458","name":"Slider Lampetter","label":"Lampetter","tooltip":"","group":"7137fe863ebb3555","order":3,"width":0,"height":0,"passthru":false,"outs":"end","topic":"control","topicType":"str","min":0,"max":"100","step":1,"className":"","x":720,"y":1140,"wires":[["a1e001f80f23084e"]]},{"id":"3e2336b1e2952084","type":"hs-device","z":"bd6892582b896458","name":"Bolig Stue Dim Lampetter Goap Switch Dim Lampetter","device":"896","server":"8cea2f7d775df12f","feature":"901","reportonstartup":true,"x":260,"y":1140,"wires":[["33aa6ca6a604e474"]]},{"id":"33aa6ca6a604e474","type":"function","z":"bd6892582b896458","name":"Extract Value","func":"var svar = \"\";\nvar value=msg.payload.value;\nsvar = {payload:value.toFixed(0)};\nreturn svar;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":1140,"wires":[["2b572d1453bf7926"]]},{"id":"a4806c0c2520326a","type":"function","z":"bd6892582b896458","name":"Create msg","func":"var svar = \"\";\nvar inn=msg.payload;\nif (inn != null) {\nvar msg1 = {payload: {\"value\":inn}, topic: \"control\"};\nreturn msg1;}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1050,"y":1140,"wires":[["811709e3f452d914"]]},{"id":"811709e3f452d914","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":1210,"y":1140,"wires":[["3e2336b1e2952084"]]},{"id":"a1e001f80f23084e","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":890,"y":1140,"wires":[["a4806c0c2520326a"]]},{"id":"7137fe863ebb3555","type":"ui_group","name":"Kolonne2","tab":"e3ef94435f0945bf","order":2,"disp":false,"width":"6","collapse":false,"className":""},{"id":"8cea2f7d775df12f","type":"hs-server","name":"HS4","host":"172.16.0.102","port":"80"},{"id":"e3ef94435f0945bf","type":"ui_tab","name":"Home","icon":"home","order":1,"disabled":false,"hidden":false}] Samme problemstilling gjelder for brytere.
Det kommer an på... Du kan assosiere bryter direkte til dimmer, ikke garantert at det funker i alle kombinasjoner men stort sett funker det. Assosiasjoner gjøres vha hub men er helt uavhengige etterpå.
Egentlig ikke, har 5 Fibaro røykvarslere med Z-Wave men har skiftet 3 stk på reklamasjon og de kan ikke sammenkobles annet enn gjennom logikk i HS.
Har en blanding av Z-Wave og Zigbee. Den nevnte Sunricher bryteren er Zigbee og den vil fungere helt uavhengig av hub, den andre varianten (soverom) krever hub slik jeg har laget det, vurderer Sunricher løsningen der og men det funker så godt i dag at det ikke er prioritert nå.
Ja, der er jo noen filosofivalg som må gjøres... Jeg har gjort det relativt enkelt hjemme hos meg: Ikke-oppholdsrom har bevegelsessensor som slår på lys med intensitet og timere alt etter når på døgnet det er (dag-skumring-natt, natt krever langt mindre lysintensitet og normalt langt kortere etterløpstid). Ingen manuelle brytere. Oppholds- og soverom har manuelt lys med bryter og/eller skjermstyring (HSTouch). Bryteren på soverom har litt automatikk: Slår av eller på 2% (er lyset av slås det på 2%, er det på slås det av). Når HS4 ser at lyset står på 2% kjører et event som på kvelden setter 60% lysstyrke og på dagen setter 100%, greit med litt beskjedent lys på natt... Har et par strategisk plasserte brytere (ved entredør og soverom) som kjører et script som slår av alt manuelt lys, låser entredør, slår av Sonos og slikt og et script som låser opp entredør, slår på espressomaskinen (trenger minst 15 minutt) og slår på litt basislys slik jeg normalt ville gjort når jeg står opp. Utelys helautomatisk som på ved solnedgang, av kl 23 (ukedager) og 24 (helg). Overstyres med bevegelssensorer ute om natten. Har noen slike strømløse/batteriløse brytere: https://www.kjell.com/no/produkter/smarte-hjem/fjernkontroller/smarte-dimmerer/sunricher-zigbee-fjernstrombryter-for-veggmontering-p51600 Funker supert og assosieres direkte til dimmere, da kan dimmeren styres direkte uteom hub men OGSÅ fra hub. Har bare prøvd mot Sunricher dimmer, vet ikke om det funker mot andre men nydelig at bryteren ikke krever ekstern strøm på noen måte. Jeg ser godt tanken med å ha et system som funker om hub går ned men vet ikke om jeg hadde prioritert å legge mye penger eller arbeid i noe som egentlig aldri skal brukes... Just my 5 cents, du får tenke litt selv hvordan du vil ha ting...
Z-Water har ikke vekselkontakt så en enkel omkobling der går ikke. Har temperatursensorene innstilling for Heat/Cool? I så fall står den feil. Regner med du har sjekket at der virkelig går varmtvann i sløyfene når aktuatorene har spenning, i så fall er de NC og slik de fleste har.
ALLE andre plugger med effektmåling har kWh teller så det det hadde vært veldig flott om det kunne dukke opp en slik funksjon i denne også etterhvert.
Det ser for meg ut som et ganske strengt rutenett der hver enkelt objekt grupperes i en eller flere kolonner og rekkefølgen av objektene og rekkefølgen av kolonnene kan modifiseres i /View/Dashboard menyen. Hvert enkelt objekt kan endres i bredde men beholder høyde/bredde forholdet. Med dette som utgangspunkt så har en jo en del begrensninger men får også en veldig konsistent utseende. Fargepalette er Light, Dark og Custom så en kan jo trikse en god del på den siden og. Mye roteprogrammering men her er flowen min for bildet over så langt, henter data fra både HS4 og MQTT: [{"id":"bd6892582b896458","type":"tab","label":"HMI","disabled":false,"info":"Node Red UI"},{"id":"2b070f1c4f123439","type":"inject","z":"bd6892582b896458","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":false,"onceDelay":0.1,"topic":"sync","x":90,"y":480,"wires":[["68aeab8d8cc0a568","24c96b0a09e51a79","f4628910ddbd0842"]]},{"id":"b0bd0bee704ca2a2","type":"mqtt in","z":"bd6892582b896458","name":"","topic":"Pool/TempOutside","qos":"2","datatype":"auto","broker":"6db118ed1b0c56de","nl":false,"rap":true,"rh":0,"x":110,"y":740,"wires":[["8f6820eaab18ff56","50722e1696144c01"]]},{"id":"8f6820eaab18ff56","type":"ui_chart","z":"bd6892582b896458","name":"","group":"394dcffd2bbde9fc","order":2,"width":0,"height":0,"label":"TempOutside","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":890,"y":720,"wires":[[]]},{"id":"447d83713bc15202","type":"mqtt in","z":"bd6892582b896458","name":"","topic":"Pool/TempWater","qos":"2","datatype":"auto","broker":"6db118ed1b0c56de","nl":false,"rap":true,"rh":0,"x":100,"y":620,"wires":[["181b1ea5b01130aa"]]},{"id":"059b0a959ff9cc50","type":"mqtt in","z":"bd6892582b896458","name":"","topic":"Pool/TempDome","qos":"2","datatype":"auto","broker":"6db118ed1b0c56de","nl":false,"rap":true,"rh":0,"x":100,"y":680,"wires":[["f63728a2287667ec"]]},{"id":"f8b50f685fa55795","type":"ui_chart","z":"bd6892582b896458","name":"","group":"45fc21be8d63c5ff","order":3,"width":0,"height":0,"label":"TempOutside","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":1100,"y":740,"wires":[[]]},{"id":"6a43f2652264b1ab","type":"ui_chart","z":"bd6892582b896458","name":"","group":"47a266d7202a6d2f","order":1,"width":0,"height":0,"label":"TempWater","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"25","ymax":"35","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":1100,"y":660,"wires":[[]]},{"id":"7007c23f63671f43","type":"ui_chart","z":"bd6892582b896458","name":"","group":"45fc21be8d63c5ff","order":2,"width":0,"height":0,"label":"TempDome","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":1100,"y":700,"wires":[[]]},{"id":"24c96b0a09e51a79","type":"hs-device","z":"bd6892582b896458","name":"Uteområde Pool Pool VP Aeon Labs Switch Pool VP W","device":"581","server":"8cea2f7d775df12f","feature":"583","reportonstartup":false,"x":560,"y":460,"wires":[["e27f2d3db5e9f6f9"]]},{"id":"873e9689c2ac0a83","type":"ui_gauge","z":"bd6892582b896458","name":"","group":"b31303479769b0ef","order":3,"width":0,"height":0,"gtype":"donut","title":"VP W","label":"W","format":"{{value}}","min":0,"max":"3500","colors":["#00b500","#e6e600","#ca3838"],"seg1":"2500","seg2":"3000","className":"","x":1250,"y":460,"wires":[]},{"id":"80cabf4d730c69e9","type":"hs-device","z":"bd6892582b896458","name":"Uteområde Pool Pool VP Aeon Labs Switch Pool VP Switch","device":"581","server":"8cea2f7d775df12f","feature":"587","reportonstartup":false,"x":300,"y":120,"wires":[["97a96b7eb024e484"]]},{"id":"2c12c58c597facb6","type":"ui_switch","z":"bd6892582b896458","name":"","label":"VP SW","tooltip":"","group":"b31303479769b0ef","order":3,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"payload.control.status","topicType":"str","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":780,"y":120,"wires":[["a0309c8e844301eb"]]},{"id":"26ea40c467b040f9","type":"ui_chart","z":"bd6892582b896458","name":"","group":"47a266d7202a6d2f","order":3,"width":0,"height":0,"label":"VP W","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"3500","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":1080,"y":620,"wires":[[]]},{"id":"e27f2d3db5e9f6f9","type":"function","z":"bd6892582b896458","name":"Extract Value","func":"var svar = \"\";\nvar value=msg.payload.value;\nsvar = {payload:value.toFixed(0)};\nreturn svar;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":460,"wires":[["0b0d4068d4db0acd","6e6db3683ec2140b"]]},{"id":"bcb299f99d8057c2","type":"ui_gauge","z":"bd6892582b896458","name":"","group":"b31303479769b0ef","order":3,"width":0,"height":0,"gtype":"donut","title":"Filtersirk","label":"W","format":"{{value}}","min":0,"max":"500","colors":["#ffff00","#73d216","#ca3838"],"seg1":"330","seg2":"400","className":"","x":1090,"y":520,"wires":[]},{"id":"a98903487fdc51b7","type":"function","z":"bd6892582b896458","name":"Extract Value","func":"var svar = \"\";\nvar value=msg.payload.value;\nsvar = {payload:value.toFixed(0)};\nreturn svar;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":520,"wires":[["bcb299f99d8057c2","87e6ed5553c1cfea"]]},{"id":"68aeab8d8cc0a568","type":"hs-device","z":"bd6892582b896458","name":"Uteområde Pool Pool Filter Fibaro Switch Pool Filter Power","device":"1117","server":"8cea2f7d775df12f","feature":"1122","reportonstartup":true,"x":580,"y":520,"wires":[["a98903487fdc51b7"]]},{"id":"0b0d4068d4db0acd","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":920,"y":620,"wires":[["26ea40c467b040f9"]]},{"id":"50722e1696144c01","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":290,"y":740,"wires":[["f8b50f685fa55795","c26e44f1ef456505"]]},{"id":"6e6db3683ec2140b","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":1090,"y":460,"wires":[["873e9689c2ac0a83"]]},{"id":"48c4e3aebcd831c6","type":"change","z":"bd6892582b896458","name":"Av","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"status\":\"OFF\"}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1070,"y":140,"wires":[["64e07103c1553251"]]},{"id":"17e31f8813594c62","type":"change","z":"bd6892582b896458","name":"På","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"status\":\"ON\"}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1070,"y":100,"wires":[["64e07103c1553251"]]},{"id":"64e07103c1553251","type":"json","z":"bd6892582b896458","name":"","property":"payload","action":"","pretty":false,"x":1210,"y":120,"wires":[["80cabf4d730c69e9"]]},{"id":"a0309c8e844301eb","type":"switch","z":"bd6892582b896458","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":true,"outputs":2,"x":930,"y":120,"wires":[["17e31f8813594c62"],["48c4e3aebcd831c6"]]},{"id":"8152c53f411495af","type":"ui_chart","z":"bd6892582b896458","name":"","group":"47a266d7202a6d2f","order":3,"width":0,"height":0,"label":"Filter W","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"500","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":1080,"y":560,"wires":[[]]},{"id":"87e6ed5553c1cfea","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":910,"y":560,"wires":[["8152c53f411495af"]]},{"id":"f63728a2287667ec","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":290,"y":680,"wires":[["7007c23f63671f43"]]},{"id":"181b1ea5b01130aa","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":290,"y":620,"wires":[["6a43f2652264b1ab"]]},{"id":"eb838059898d3fdc","type":"hs-device","z":"bd6892582b896458","name":"Uteområde Pool Pool Filter Fibaro Switch Pool Filter Switch","device":"1117","server":"8cea2f7d775df12f","feature":"1123","reportonstartup":false,"x":300,"y":240,"wires":[["15b7f60e9e8f9a65"]]},{"id":"72e2b0155c15c2a7","type":"ui_switch","z":"bd6892582b896458","name":"","label":"FilterSW","tooltip":"","group":"b31303479769b0ef","order":3,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"payload.control.status","topicType":"str","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":760,"y":240,"wires":[["b774a2faac9275e6"]]},{"id":"aff52e931bc694c8","type":"change","z":"bd6892582b896458","name":"Av","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"status\":\"OFF\"}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":260,"wires":[["c234bf11af45b0a8"]]},{"id":"c234bf11af45b0a8","type":"json","z":"bd6892582b896458","name":"","property":"payload","action":"","pretty":false,"x":1190,"y":240,"wires":[["eb838059898d3fdc"]]},{"id":"e390ae5cb88c5ade","type":"change","z":"bd6892582b896458","name":"På","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"status\":\"ON\"}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":220,"wires":[["c234bf11af45b0a8"]]},{"id":"b774a2faac9275e6","type":"switch","z":"bd6892582b896458","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":true,"outputs":2,"x":890,"y":240,"wires":[["e390ae5cb88c5ade"],["aff52e931bc694c8"]]},{"id":"f4628910ddbd0842","type":"hs-device","z":"bd6892582b896458","name":"Bolig Kjøkken Beveg Kjøk Aeon Labs Multilevel Sensor Beveg Kjøk Temperature","device":"83","server":"8cea2f7d775df12f","feature":"87","reportonstartup":true,"x":440,"y":340,"wires":[["33af4e4f3bf9e3b9"]]},{"id":"33af4e4f3bf9e3b9","type":"function","z":"bd6892582b896458","name":"Extract Value","func":"var svar = \"\";\nvar value=msg.payload.value;\nsvar = {payload:value.toFixed(1)};\nreturn svar;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":340,"wires":[["9774175638722593"]]},{"id":"9774175638722593","type":"show-value","z":"bd6892582b896458","name":"","path":"","x":690,"y":380,"wires":[["d0dad447410a790e","b109a4a06c64234c"]]},{"id":"d0dad447410a790e","type":"ui_chart","z":"bd6892582b896458","name":"","group":"ab0b4b6271303101","order":2,"width":0,"height":0,"label":"Temp Kjøkken","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":880,"y":380,"wires":[[]]},{"id":"15b7f60e9e8f9a65","type":"function","z":"bd6892582b896458","name":"Extract Value","func":"var svar = \"\";\nvar value=msg.payload.status;\nif (value == \"On\") {\nsvar = {payload:1};\nreturn svar}\nif (value == \"Off\") {\nsvar = {payload:0};\nreturn svar}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":610,"y":240,"wires":[["72e2b0155c15c2a7"]]},{"id":"5e2be42900ee5080","type":"inject","z":"bd6892582b896458","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":false,"onceDelay":0.1,"topic":"sync","x":90,"y":180,"wires":[["80cabf4d730c69e9","eb838059898d3fdc"]]},{"id":"97a96b7eb024e484","type":"function","z":"bd6892582b896458","name":"Extract Value","func":"var svar = \"\";\nvar value=msg.payload.status;\nif (value == \"On\") {\nsvar = {payload:1};\nreturn svar}\nif (value == \"Off\") {\nsvar = {payload:0};\nreturn svar}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":120,"wires":[["2c12c58c597facb6"]]},{"id":"b109a4a06c64234c","type":"ui_text","z":"bd6892582b896458","group":"ab0b4b6271303101","order":1,"width":0,"height":0,"name":"","label":"Temp kjøkken","format":"{{msg.payload}}","layout":"col-center","className":"","x":880,"y":420,"wires":[]},{"id":"c26e44f1ef456505","type":"ui_text","z":"bd6892582b896458","group":"394dcffd2bbde9fc","order":1,"width":0,"height":0,"name":"","label":"Utetemperatur","format":"{{msg.payload}}","layout":"col-center","className":"","x":900,"y":760,"wires":[]},{"id":"6db118ed1b0c56de","type":"mqtt-broker","name":"DaleMQTT","broker":"172.16.0.94","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"394dcffd2bbde9fc","type":"ui_group","name":"Trends","tab":"e3ef94435f0945bf","order":2,"disp":false,"width":"6","collapse":false,"className":""},{"id":"45fc21be8d63c5ff","type":"ui_group","name":"PoolTrends","tab":"b91fa54f1d7b5859","order":3,"disp":false,"width":"5","collapse":false,"className":""},{"id":"47a266d7202a6d2f","type":"ui_group","name":"PoolTrend2","tab":"b91fa54f1d7b5859","order":2,"disp":false,"width":"5","collapse":false,"className":""},{"id":"8cea2f7d775df12f","type":"hs-server","name":"HS4","host":"172.16.0.102","port":"80"},{"id":"b31303479769b0ef","type":"ui_group","name":"Values","tab":"b91fa54f1d7b5859","order":1,"disp":false,"width":"4","collapse":false,"className":""},{"id":"ab0b4b6271303101","type":"ui_group","name":"Default","tab":"e3ef94435f0945bf","order":1,"disp":false,"width":"6","collapse":false,"className":""},{"id":"e3ef94435f0945bf","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false},{"id":"b91fa54f1d7b5859","type":"ui_tab","name":"Pool","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Ga opp det forsøket mitt og startet med Node-Red Dashboard i stedet. Har bare snekret et par kladdebilder enda men ser en liten utfordring. Når bildet ikke har vært vist på en stund tar det evigheter (=opptil flere minutt) før trendobjektene oppdateres. Eksempel et halvminutt eller så etter siden vises: En stund senere: Beklager hvis jeg kupper tråden din @Terje Klungervik men jeg tenker å komme med noe mer matnyttig etterhvert...
Begynte i går kveld å leke litt med node-red-contrib-tv men ikke hatt tid til å få gang på noe vettigt enda... Liker egentlig ikke designet så godt men det er nå en start...
FB, MS og Google på hugget? PC går i sirup...
SveinHa svarte på SveinHa sitt emne i Automasjonskaféen
Skjer litt mer i kulisssene en folk flest er klar over, hva gjør din Android eller Eplefon i det skjulte... https://www.scss.tcd.ie/doug.leith/apple_google.pdf -
Oversikt over produkter, systemer, forhandlere etc.
SveinHa svarte på aBjelke sitt emne i Automasjonskaféen
Jeg slår litt andre veien enn @Moskus 😊, har 60-70 Z-Wave enheter koblet til HomeSeer 4 og de funker 99% eller noe sånn. Har en og annen feilfunksjon, helt usystematisk i ny og ne. Som at utelyset styres fra 3 Z-Wave dimmere pga geografisk avstand (3 bygninger) og av og til er det et utelys som ikke slår seg på eller av. Slike ting skjer jevnlig og har gjort det siden dag 1. Teorien bak Z-Wave tilsier jo at slikt ikke skal skje men gjør det likevel. Den siste tiden har jeg begynt å supplere/bytte ut med Zigbee og selv om jeg bare har kommet opp i 20 enheter ser det ut til å fungere meget bedre, både raskere og mer pålitelig. Jeg har hatt noe Ikea Zigbee utstyr i mange år, styrt både med IKEA Gateway og med Jowihue/DeConz/Conbee, ingen av disse 2 variantene synes jeg var særlig bra. Nå kjører jeg Zigbee via en Raspberry Pi 3B+ med zigbee2mqtt, Mosquitto MQTT Broker på en virtuell Linuxmaskin og programmerer noe i HomeSeer 4 vha mcsMQTT og noe direkte i Node-Red. Mitt opplegg er vel kanskje ikke helt for en nybegynner men du må vurdere litt egne kunnskaper, der finnes mange alternativer, både gratis og som må kjøpes og betalingsløsningene har ofte noen uker prøvetid. Jeg var gjennom mange varianter før jeg falt ned på HomeSeer. Edit: Z-Wave dimmere dimmer veldig i trappetrinn, spesielt Qubino men også Fibaro, mens de Zigbee dimmerene jeg har dimmer veldig jevnt uten trappetrinn, både HUE, Sunricher og Ikea. -
Ja, det vil jeg tro. Flere her som bruker Z-Water som sikkert kan bidra på den biten. Homey vet jeg ikke noe om.
Der står "NC" på aktuatoren så den har nok strøm siden den er aktivert (=blå stripe synlig). Sjekk kobling eller logikk. Jeg har ikke Z-Water men vanlige releer til min vannbårne gulvvarme og DS18B20 gulvsensorer via Fibaro UBS. Termostatene er enkle events i HS4
De pleier å være NC men finnes også i NO. De bildene dine viser er åpne (fordi der står strøm på?) og de er trege, kan ta opptil flere minutter fra åpen til stengt eller motsatt.
Versjonsnummer? Jeg kom i skade for å installere siste beta (4.2.0.8) og fikk en del merkelige og alvorlige feil som at enkelte devicer ikke dukker opp i drop-down lister. Du kan jo også prøve med en annen nettleser.
- 3 svar
Hadde behov/ønske om litt nattlys på soverommet men en slik plugg som en bare stapper i stikkontakten er jo bare for pingler... En HUE bevegelssensor, en HUE LED stripe og litt eksperimentering i Node Red endte opp slik: Dimmer opp i løpet av 10 sek og etter 1 minutt dimmer ned igjen i løpet av 120 sek.
Putler i vei litt videre. Poster her når jeg har fått "hull på byllen", dvs. fått ting til å virke. Denne gangen er det en IKEA rund 5-knapp fjernkontroll via zigbee2mqtt som styrer en wallplug i HS4 og er Sunricher rele via mqtt/zigbee2mqtt: Litt for andre og litt for meg selv som huskeliste 😉 [{"id":"0e1f5a47dab01ac8","type":"tab","label":"IKEA Remote SW2","disabled":false,"info":""},{"id":"e7d4221599ac53c2","type":"mqtt in","z":"0e1f5a47dab01ac8","name":"SW2","topic":"zigbee2mqtt/IKEA/Tradfri_SW2","qos":"2","datatype":"auto","broker":"6db118ed1b0c56de","nl":false,"rap":true,"rh":0,"x":90,"y":80,"wires":[["1e2e7dccdd786a5f"]]},{"id":"40365f1ed2766793","type":"mqtt out","z":"0e1f5a47dab01ac8","name":"Spisebord","topic":"zigbee2mqtt/Lys/Spisebord/set","qos":"0","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"6db118ed1b0c56de","x":760,"y":80,"wires":[]},{"id":"1e2e7dccdd786a5f","type":"json","z":"0e1f5a47dab01ac8","name":"","property":"payload","action":"obj","pretty":false,"x":230,"y":80,"wires":[["064e9d908740e547"]]},{"id":"064e9d908740e547","type":"function","z":"0e1f5a47dab01ac8","name":"DekodSW2","func":"var svar = \"\";\nvar action=msg.payload.action;\nif (action==\"toggle\") {\n svar= {payload:\"TOGGLE\"};\n}\nif (action==\"brightness_up_click\") {\n svar= {payload:\"ON\"};\n}\nif (action==\"brightness_down_click\") {\n svar= {payload:\"OFF\"};\n}\nif (action==\"arrow_left_click\") {\n svar= {payload:\"L\"};\n}\nif (action==\"arrow_right_click\") {\n svar= {payload:\"R\"};\n}\n\nreturn svar;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":130,"y":160,"wires":[["07fb951a50e9c8c6"]]},{"id":"ecd3c99e5f1797a0","type":"hs-device","z":"0e1f5a47dab01ac8","name":"HjerterKjøk","device":"1688","server":"8cea2f7d775df12f","feature":0,"reportonstartup":false,"x":770,"y":180,"wires":[[]]},{"id":"07fb951a50e9c8c6","type":"switch","z":"0e1f5a47dab01ac8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"OFF","vt":"str"},{"t":"eq","v":"TOGGLE","vt":"str"},{"t":"eq","v":"L","vt":"str"},{"t":"eq","v":"R","vt":"str"}],"checkall":"true","repair":true,"outputs":5,"x":290,"y":160,"wires":[["40365f1ed2766793"],["40365f1ed2766793"],["40365f1ed2766793"],["6d6a304991a8d20b"],["579dcb740e976515"]],"outputLabels":["","","","Ev1","Ev2"]},{"id":"579dcb740e976515","type":"change","z":"0e1f5a47dab01ac8","name":"Av","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"status\":\"OFF\"}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":200,"wires":[["c1e0bc0d7ac004f4"]]},{"id":"c1e0bc0d7ac004f4","type":"json","z":"0e1f5a47dab01ac8","name":"","property":"payload","action":"","pretty":false,"x":590,"y":200,"wires":[["ecd3c99e5f1797a0"]]},{"id":"6d6a304991a8d20b","type":"change","z":"0e1f5a47dab01ac8","name":"På","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"status\":\"ON\"}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":160,"wires":[["49dbaad0fe1bd6b0"]]},{"id":"49dbaad0fe1bd6b0","type":"json","z":"0e1f5a47dab01ac8","name":"","property":"payload","action":"","pretty":false,"x":590,"y":160,"wires":[["ecd3c99e5f1797a0"]]},{"id":"bf58b55dadacba35","type":"comment","z":"0e1f5a47dab01ac8","name":"Telldus wallplug i HS4","info":"","x":960,"y":180,"wires":[]},{"id":"6097e1532a616b0b","type":"comment","z":"0e1f5a47dab01ac8","name":"Sunricher Zigbee rele","info":"","x":960,"y":80,"wires":[]},{"id":"8de42efafb168028","type":"comment","z":"0e1f5a47dab01ac8","name":"IKEA 5-knapp fjernkontroll","info":"","x":150,"y":40,"wires":[]},{"id":"6db118ed1b0c56de","type":"mqtt-broker","name":"DaleMQTT","broker":"172.16.0.94","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"8cea2f7d775df12f","type":"hs-server","name":"HS4","host":"172.16.0.102","port":"80"}]
Da har jeg forenklet litt og fått det til å virke tilfredsstillende: [{"id":"6e716fb5.71658","type":"tab","label":"Flow 2"},{"id":"8f9a50d4b09f6554","type":"mqtt in","z":"6e716fb5.71658","name":"Bev1","topic":"zigbee2mqtt/HUE/Sov1Beveg","qos":"0","datatype":"auto","broker":"6db118ed1b0c56de","nl":false,"rap":true,"rh":0,"x":170,"y":160,"wires":[["b1faf566507cd1bb"]]},{"id":"042eecf372789b8e","type":"mqtt out","z":"6e716fb5.71658","name":"Nattlys","topic":"zigbee2mqtt/HUE/NattlysSov1/set","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"6db118ed1b0c56de","x":1170,"y":200,"wires":[]},{"id":"599f78525155c46b","type":"change","z":"6e716fb5.71658","name":"Av","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"brightness\":0,\"transition\":60}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":260,"wires":[["042eecf372789b8e"]]},{"id":"555f9fffe3349a6b","type":"delay","z":"6e716fb5.71658","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"x":780,"y":260,"wires":[["599f78525155c46b"]]},{"id":"cd90cb56d0f52093","type":"change","z":"6e716fb5.71658","name":"På","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"brightness\":150,\"transition\":15}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":160,"wires":[["042eecf372789b8e"]]},{"id":"b1faf566507cd1bb","type":"json","z":"6e716fb5.71658","name":"","property":"payload","action":"","pretty":false,"x":330,"y":160,"wires":[["317aadc39d87352b"]]},{"id":"317aadc39d87352b","type":"switch","z":"6e716fb5.71658","name":"Beveg","property":"payload.occupancy","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":510,"y":160,"wires":[["1ba54974b376c742"]]},{"id":"1ba54974b376c742","type":"switch","z":"6e716fb5.71658","name":"Illum LUX < 15","property":"payload.illuminance_lux","propertyType":"msg","rules":[{"t":"lt","v":"15","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":720,"y":160,"wires":[["cd90cb56d0f52093","4b62b6861f671f57"]]},{"id":"4b62b6861f671f57","type":"function","z":"6e716fb5.71658","name":"","func":"msg.delay = 60000;\nvar m1 = {reset:true};\nreturn [[m1,msg]];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":260,"wires":[["555f9fffe3349a6b"]]},{"id":"6db118ed1b0c56de","type":"mqtt-broker","name":"DaleMQTT","broker":"172.16.0.94","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}] Takker og bukker for hjelpen. Veldig greit å kjøre Node-Red parallellt med HomeSeer
Da er jeg kommet litt nærmere: Lyset går på som planlagt men med flere aktiveringer av bevegelssessensoren køer det seg opp med "av" kommandoer, 5 i dette eksempelet. Ved HVER ny bevegelse vil jeg slette alt i køen og legge inn kun 1 ny forsinket kommando. Hvordan? [{"id":"6e716fb5.71658","type":"tab","label":"Flow 2"},{"id":"8f9a50d4b09f6554","type":"mqtt in","z":"6e716fb5.71658","name":"Bev1","topic":"zigbee2mqtt/HUE/Sov1Beveg","qos":"0","datatype":"auto","broker":"6db118ed1b0c56de","nl":false,"rap":true,"rh":0,"x":170,"y":160,"wires":[["b1faf566507cd1bb"]]},{"id":"042eecf372789b8e","type":"mqtt out","z":"6e716fb5.71658","name":"Nattlys","topic":"zigbee2mqtt/HUE/NattlysSov1/set","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"6db118ed1b0c56de","x":1230,"y":260,"wires":[]},{"id":"d118a9f20f32cace","type":"change","z":"6e716fb5.71658","name":"På langsom","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"brightness\":100,\"transition\":25}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":260,"wires":[["042eecf372789b8e","a9c4f1bd5c640d81","555f9fffe3349a6b"]]},{"id":"599f78525155c46b","type":"change","z":"6e716fb5.71658","name":"Av","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"brightness\":0,\"transition\":30}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":360,"wires":[["042eecf372789b8e","a9c4f1bd5c640d81"]]},{"id":"555f9fffe3349a6b","type":"delay","z":"6e716fb5.71658","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"x":720,"y":360,"wires":[["599f78525155c46b"]]},{"id":"cd90cb56d0f52093","type":"change","z":"6e716fb5.71658","name":"På rask","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"brightness\":30,\"transition\":1}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":160,"wires":[["042eecf372789b8e","a9c4f1bd5c640d81","0ccec4c709bd297b"]]},{"id":"0ccec4c709bd297b","type":"delay","z":"6e716fb5.71658","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":720,"y":260,"wires":[["d118a9f20f32cace"]]},{"id":"a9c4f1bd5c640d81","type":"debug","z":"6e716fb5.71658","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1210,"y":340,"wires":[]},{"id":"b1faf566507cd1bb","type":"json","z":"6e716fb5.71658","name":"","property":"payload","action":"","pretty":false,"x":330,"y":160,"wires":[["317aadc39d87352b"]]},{"id":"317aadc39d87352b","type":"switch","z":"6e716fb5.71658","name":"Beveg","property":"payload.occupancy","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":510,"y":160,"wires":[["1ba54974b376c742"]]},{"id":"1ba54974b376c742","type":"switch","z":"6e716fb5.71658","name":"Illum LUX","property":"payload.illuminance_lux","propertyType":"msg","rules":[{"t":"lt","v":"15","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":700,"y":160,"wires":[["cd90cb56d0f52093"]]},{"id":"6db118ed1b0c56de","type":"mqtt-broker","name":"DaleMQTT","broker":"172.16.0.94","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Begynte i natt å se litt på Node-Red og har nå fått til litt greier men trenger litt hjelp... Har en bevegelsessensor som skal slå på nattlys litt stille og rolig og slå av igjen etter en tid. Denne sender følgende via mqtt: Jeg ønsker å filtrerer ut "occupancy" og kjøre en flow når denne er "true". Lyset går da raskt opp til 30 for så å sakte gå opp til 100. 1 minutt senere skal det sakte slå seg av igjen. Denne flowen fungerer for så vidt men ved flere aktiveringer legger der seg flere "slå av" kommandoer i kø og det er ikke så lurt. Tatt i betraktning at jeg er heeeeelt fersk på Node-Red så er jeg fornøyd med at det virker sånn noenlunde men regner med det er ultraklønete laget. Noen som vil guide meg litt på vei? Noen flere parameter trengs også etterhvert som f.eks. er det ikke nødvendig med nattlys på dagtid, enten ut fra soloppgang/nedgang eller kanskje litt mer elegant vha. lyssensoren i bevegelssensoren. [{"id":"6e716fb5.71658","type":"tab","label":"Flow 2"},{"id":"8f9a50d4b09f6554","type":"mqtt in","z":"6e716fb5.71658","name":"Bev1","topic":"zigbee2mqtt/HUE/Sov1Beveg","qos":"0","datatype":"auto","broker":"6db118ed1b0c56de","nl":false,"rap":true,"rh":0,"x":190,"y":300,"wires":[["6be4bd0d5ef4eefb","a9c4f1bd5c640d81"]]},{"id":"042eecf372789b8e","type":"mqtt out","z":"6e716fb5.71658","name":"Nattlys","topic":"zigbee2mqtt/HUE/NattlysSov1/set","qos":"2","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"6db118ed1b0c56de","x":1230,"y":380,"wires":[]},{"id":"9abd98fd718357d6","type":"switch","z":"6e716fb5.71658","name":"Filtrer ut kun \"Bevegelse på\"","property":"payload.occupancy","propertyType":"msg","rules":[{"t":"cont","v":"true","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":580,"y":300,"wires":[["cd90cb56d0f52093"]],"outputLabels":["True"]},{"id":"6be4bd0d5ef4eefb","type":"json","z":"6e716fb5.71658","name":"","property":"payload","action":"","pretty":true,"x":360,"y":300,"wires":[["9abd98fd718357d6"]]},{"id":"d118a9f20f32cace","type":"change","z":"6e716fb5.71658","name":"På langsom","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"brightness\":100,\"transition\":25}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":380,"wires":[["042eecf372789b8e","a9c4f1bd5c640d81","555f9fffe3349a6b"]]},{"id":"599f78525155c46b","type":"change","z":"6e716fb5.71658","name":"Av","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"brightness\":0,\"transition\":30}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":480,"wires":[["042eecf372789b8e","a9c4f1bd5c640d81"]]},{"id":"555f9fffe3349a6b","type":"delay","z":"6e716fb5.71658","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"x":720,"y":480,"wires":[["599f78525155c46b"]]},{"id":"cd90cb56d0f52093","type":"change","z":"6e716fb5.71658","name":"På rask","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"brightness\":30,\"transition\":1}","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":280,"wires":[["042eecf372789b8e","a9c4f1bd5c640d81","0ccec4c709bd297b"]]},{"id":"0ccec4c709bd297b","type":"delay","z":"6e716fb5.71658","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":720,"y":380,"wires":[["d118a9f20f32cace"]]},{"id":"a9c4f1bd5c640d81","type":"debug","z":"6e716fb5.71658","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":850,"y":640,"wires":[]},{"id":"6db118ed1b0c56de","type":"mqtt-broker","name":"DaleMQTT","broker":"172.16.0.94","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Denne her: https://www.elkjop.no/product/smarte-hjem/smart-varme-strom-inneklima/136869/apex-smart-plug er jo rimelig slank OG 16A/3860W. Har ikke prøvd den da...
Har noen Sunricher batteriløse brytere og de er omtrent like tunge å trykke på som en vanlig Elko bryter med returfjær. Har ikke hatt de lenge men er kjempefornøyd så langt.
