deve87 Skrevet 1. februar 2018 Del Skrevet 1. februar 2018 Kjører siste stabile versjon av Domoticz på en raspberry 3. Kursen hvor denne er på gikk og siden vil ikke Domoticz starte opp! Har aldri hatt problem med før. Ifølge service, så sier Raspberry at Domoticz kjører. Fungerer ikke stoppe og starte Domoticz igjen. Her er loggen /home/pi/domoticz/domoticz 2018-02-01 16:50:17.094 Domoticz V3.8153 (c)2012-2017 GizMoCuz 2018-02-01 16:50:17.095 Build Hash: 494fff7, Date: 2017-07-30 12:19:41 2018-02-01 16:50:17.095 Startup Path: /home/pi/domoticz/ 2018-02-01 16:50:17.127 Sunrise: 08:31:00 SunSet:16:38:00 2018-02-01 16:50:17.127 EventSystem: reset all events... 2018-02-01 16:50:17.210 PluginSystem: Started, Python version '3.4.2'. 2018-02-01 16:50:17.211 Philips Hue: Using default poll interval of 10 secs. 2018-02-01 16:50:17.219 Active notification Subsystems: email, pushover (2/12) 2018-02-01 16:50:17.220 WebServer(HTTP) started on address: :: with port 8080 2018-02-01 16:50:17.257 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: use_certificate_chain_file: No such file or directory 2018-02-01 16:50:17.257 Error: WebServer(SSL) check privileges for opening ports below 1024 2018-02-01 16:50:17.258 Proxymanager started. 2018-02-01 16:50:17.259 Starting shared server on: :::6144 2018-02-01 16:50:17.259 TCPServer: shared server started... 2018-02-01 16:50:17.260 RxQueue: queue worker started... 2018-02-01 16:50:19.261 Philips Hue: Worker started... 2018-02-01 16:50:19.261 KMTronic: Started 2018-02-01 16:50:19.261 EventSystem: reset all events... 2018-02-01 16:50:19.263 EventSystem: reset all device statuses... 2018-02-01 16:50:19.335 Python EventSystem: Module not found - Trying to initialize. 2018-02-01 16:50:19.337 Python EventSystem: Initalizing event module. 2018-02-01 16:50:19.338 EventSystem: Started 2018-02-01 16:50:19.464 EnOcean: Using serial port: /dev/ttyUSB0 2018-02-01 16:50:19.464 EnOcean Send: 55 00 01 00 05 70 08 38 2018-02-01 16:50:19.464 EnOcean Send: 55 00 01 00 05 70 03 09 2018-02-01 16:50:19.539 EnOcean: 02 (05/01) 00 FF BA D7 00 0A 2018-02-01 16:50:19.539 EnOcean: Transceiver ID_Base: 0xffbad700 2018-02-01 16:50:19.629 PluginSystem: Entering work loop. 2018-02-01 16:50:19.739 EnOcean: 02 (21/00) 00 02 0B 01 00 02 06 03 00 01 9D 75 AE 45 4F 01 03 47 41 54 45 57 41 59 43 54 52 4C 00 00 00 00 00 2018-02-01 16:50:19.739 EnOcean: Version_Info, App: 02.0b.01.00, API: 02.06.03.00, ChipID: 01.9d.75.ae, ChipVersion: 45.4f.01.03, Description: GATEWAYCTRL 2018-02-01 16:50:19.761 OpenZWave: using config in: /home/pi/domoticz/Config/ Could Not Open OZW Log File.2018-02-01 16:50:19.765 Always, OpenZwave Version 1.4.2501 Starting Up 2018-02-01 16:50:19.765 OpenZWave: Starting... 2018-02-01 16:50:19.765 OpenZWave: Version: 1.4-2501-g5af6780-dirty 2018-02-01 16:50:19.951 OpenZWave: Driver Ready 2018-02-01 16:50:19.951 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 1 (0x01) 2018-02-01 16:50:19.952 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 2 (0x02) 2018-02-01 16:50:19.952 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 3 (0x03) 2018-02-01 16:50:19.953 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 4 (0x04) 2018-02-01 16:50:19.953 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 5 (0x05) 2018-02-01 16:50:19.954 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 6 (0x06) 2018-02-01 16:50:19.954 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 7 (0x07) 2018-02-01 16:50:19.955 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 8 (0x08) 2018-02-01 16:50:19.955 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 9 (0x09) 2018-02-01 16:50:19.956 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 10 (0x0a) 2018-02-01 16:50:19.956 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 11 (0x0b) 2018-02-01 16:50:19.957 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 12 (0x0c) 2018-02-01 16:50:19.957 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 13 (0x0d) 2018-02-01 16:50:19.957 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 14 (0x0e) 2018-02-01 16:50:19.958 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 15 (0x0f) 2018-02-01 16:50:19.958 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 16 (0x10) 2018-02-01 16:50:19.959 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 17 (0x11) 2018-02-01 16:50:19.959 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 28 (0x1c) 2018-02-01 16:50:19.960 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 29 (0x1d) 2018-02-01 16:50:19.960 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 31 (0x1f) 2018-02-01 16:50:19.961 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 32 (0x20) 2018-02-01 16:50:19.962 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 33 (0x21) 2018-02-01 16:50:19.963 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 34 (0x22) 2018-02-01 16:50:19.964 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 36 (0x24) 2018-02-01 16:50:19.965 OpenZWave: New Node added. HomeID: 3891412948, NodeID: 37 (0x25) 2018-02-01 16:50:20.082 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0 2018-02-01 16:50:20.164 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1 2018-02-01 16:50:20.320 (Philips Hue) Lighting Limitless/Applamp (Group Living room) 2018-02-01 16:50:20.329 (Philips Hue) Lighting Limitless/Applamp (Group Kjeller) 2018-02-01 16:50:20.340 (Philips Hue) Lighting Limitless/Applamp (Group All Lights) 2018-02-01 16:50:20.347 (Philips Hue) Lighting Limitless/Applamp (Scene Bright) 2018-02-01 16:50:20.356 (Philips Hue) Lighting Limitless/Applamp (Scene Dimmed) 2018-02-01 16:50:20.369 (Philips Hue) Lighting Limitless/Applamp (Scene Recover room 2) 2018-02-01 16:50:20.376 (Philips Hue) Lighting Limitless/Applamp (Scene Nightlight) Traceback (most recent call last): File "/home/pi/domoticz/scripts/python/script_device_PIRsmarter.py", line 12, in parts = changed_device.name.split(" ", 2) NameError: name 'changed_device' is not defined 2018-02-01 16:50:20.440 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1 2018-02-01 16:50:20.441 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1 2018-02-01 16:50:20.441 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1 2018-02-01 16:50:20.446 (Philips Hue) Temp (Kjeller trapp) Traceback (most recent call last): File "/home/pi/domoticz/scripts/python/script_device_PIRsmarter.py", line 12, in parts = changed_device.name.split(" ", 2) NameError: name 'changed_device' is not defined 2018-02-01 16:50:20.480 (Philips Hue) Light/Switch (Bevegelse kjellertrapp) 2018-02-01 16:50:20.487 (Philips Hue) Light/Switch (ZLLLightLevel Hue ambient light sensor 1) 2018-02-01 16:50:20.490 (Philips Hue) Lux (ZLLLightLevel Lux Hue ambient light sensor 1) 2018-02-01 16:50:20.494 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1 Traceback (most recent call last): 2018-02-01 16:50:20.495 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1 2018-02-01 16:50:20.495 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1 File "/home/pi/domoticz/scripts/python/script_device_PIRsmarter.py", line 12, in parts = changed_device.name.split(" ", 2) NameError: name 'changed_device' is not defined 2018-02-01 16:50:20.518 (Philips Hue) Temp (Stue/Kjøkken) Traceback (most recent call last): File "/home/pi/domoticz/scripts/python/script_device_PIRsmarter.py", line 12, in parts = changed_device.name.split(" ", 2) NameError: name 'changed_device' is not defined 2018-02-01 16:50:20.550 (Philips Hue) Light/Switch (Bevegelse Stue/Kjøkken) 2018-02-01 16:50:20.557 (Philips Hue) Light/Switch (ZLLLightLevel Hue ambient light sensor 2) Traceback (most recent call last): File "/home/pi/domoticz/scripts/python/script_device_PIRsmarter.py", line 12, in parts = changed_device.name.split(" ", 2) NameError: name 'changed_device' is not defined 2018-02-01 16:50:20.585 (Philips Hue) Lux (Stue LUX) Segmentation fault Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
TekTek Skrevet 1. februar 2018 Del Skrevet 1. februar 2018 Sannsynligvis korrupt minne kort som er årsaken. Raspberry pi er litt beryktet for dette ved strømbrudd..? Har du et omfattende anlegg ville jeg vurdert en liten UPS .... Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
deve87 Skrevet 1. februar 2018 Forfatter Del Skrevet 1. februar 2018 (endret) Fikk det i gang igjen ved å skrive /home/pi/domoticz/updaterelease Det kjørte igang en update på nytt selv om siste versjon var installert Var nok noen filer som var ødelagte... Endret 1. februar 2018 av deve87 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
xibriz Skrevet 1. februar 2018 Del Skrevet 1. februar 2018 Jeg ville byttet SD-kortet med en gang for å være på den sikre siden. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
deve87 Skrevet 2. februar 2018 Forfatter Del Skrevet 2. februar 2018 Må nok det nå. Etter en reboot I dag fordi Domoticz ikke sendte ut varsler lengre. Så ville ikke Raspban OS boot lenger. Eller den booter. Men feiler midt i.. ? Får bare håpe jeg har en backup av databasen til Domoticz et sted Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
jhenrikb Skrevet 1. april 2018 Del Skrevet 1. april 2018 Bare vent, kommer til å skje oftere Kjøp 2 ting Skikkelig SD kort (jeg kjøpte Sandisk High endurance). Selve RPi3 ble veldig merkbart raskere, og mye mindre feil med korrupte filer. I tillegg kjøpte jeg en APC UPS 700. Denne kan jeg kjøre hjemme-auto og internett på i opptil 15timer. Bruker jo bare noen få watt alt i alt. Verdt en problemfri RPI3 løsning. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
deve87 Skrevet 1. april 2018 Forfatter Del Skrevet 1. april 2018 (endret) Hei. Da er 2stk Sandisk High endurance 32GB bestilt ?? Endret 1. april 2018 av deve87 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
