Frankh Skrevet 17. oktober 2018 Del Skrevet 17. oktober 2018 Hei! Tenkte jeg skulle teste ut Smater Control sin Sensibo plugin. Gjorde som beskrevet Extract the HSPI_SCREPOSTIROY.EXE file from the zip file and place it in your HS3 directory Restart HS3 Use the HS3 plugin manager to start the repository plugin. Navigate to Plugins / SCREPOSITORY / Manage Smarter Control Plugins Men da jeg skulle installere Sensibo plugin restartet HS og etter det vil den ikke starte. Er det noen måte jeg klarer å få HS opp igjen? Sensibo pluginet ble plutselig ikke så viktig lenger :P Benytter Raspberry pi3 og HS 3.0.0.435 og Screpository (Smarter Control) 5.0.2.0 Får denne feilmeldingen ved ./go pi@raspberrypi:~/HomeSeer $ ./go HomeSeer Linux starting... 01.36.33.7474:[Database]->Opening (Mode=Read Only) up HomeSeer LOG database /home/pi/HomeSeer/Logs/HomeSeerLog.hsd 01.36.34.1212:[Startup]->Loading Settings 01.36.34.2331:[Warning]->HomeSeer was not shut down successfully the previous time it was started. 01.36.34.3752:[Startup]->Settings Loaded. 01.36.39.3716:[Startup]-> 01.36.39.3733:[Startup]->******************************************************************************** 01.36.39.3775:[Startup]-> HomeSeer version 3.0.0.435 Edition: HS3 Standard Starting Now 01.36.39.3798:[Startup]->******************************************************************************** 01.36.39.3816:[Startup]-> 01.36.39.4460:[Startup]->Creating Class Objects... 01.36.39.4532:[Startup]->COM port classes started. 01.36.39.4670:[Startup]->Application interface class started. 01.36.39.4896:[Startup]->Web server class started. 01.36.39.4964:[Startup]->E-Mail SEND class started. 01.36.39.5011:[Startup]->E-Mail RECEIVE class started. 01.36.39.5160:[Startup]->Plug-In Interface class started. 01.36.39.5246:[Startup]->Local voice recognition class started. 01.36.39.5371:[Startup]->Database SAVE process started. 01.36.39.5388:[Startup]->Loading configuration file ... 01.36.39.6013:[Database]->Opening (Mode=Read Only) up HomeSeer database /home/pi/HomeSeer/Data/HomeSeerData.hsd 01.36.42.3120:[Database]->Loading Devices... 01.36.42.3628:[Load Config]->158 total devices loaded. 01.36.42.3738:[Load Config]->Loading Event Groups... 01.36.42.4416:[Load Config]->Loading Events... 01.36.42.7255:[Load Config]->20 total events loaded. 01.36.42.7271:[Load Config]->Loading COUNTERS... 01.36.42.7499:[Load Config]->Loading TIMERS... 01.36.42.8251:[Startup]->HomeSeer version is: 3.0.0.435 01.36.42.8284:[Startup]->Creating Speaker Client Interface Object... 01.36.42.8411:[Startup]->This version of HomeSeer is registered as a HS3STANDARD version. 01.36.43.0266:[Info]->Remote plug-in API interface started on port XXXX 01.36.43.0286:[Startup]->Checking for available plug-ins 01.36.45.6386:[Plug-In]->Found plug-in: JowiHue, version: 2.0.2.6 01.36.47.8000:[Plug-In]->Found plug-in: mcsMQTT, version: 3.4.5.2 01.36.49.9673:[Plug-In]->Found plug-in: MQTT, version: 1.5.0.0 01.36.52.1854:[Plug-In]->Found plug-in: RFXCOM, version: 30.0.0.36 01.36.55.8795:[Plug-In]->Found plug-in: SCREPOSITORY, version: 5.0.2.0 * Assertion at metadata.c:980, condition `index < meta->heap_blob.size' not met Stacktrace: at <unknown> <0xffffffff> at (wrapper managed-to-native) System.Reflection.MonoCMethod.InternalInvoke (System.Reflection.MonoCMethod,object,object[],System.Exception&) <0x00043> at System.Reflection.MonoCMethod.InternalInvoke (object,object[]) <0x0003b> at System.RuntimeType.CreateInstanceMono (bool) <0x0012b> at System.RuntimeType.CreateInstanceSlow (bool,bool,bool,System.Threading.StackCrawlMark&) <0x00063> at System.RuntimeType.CreateInstanceDefaultCtor (bool,bool,bool,System.Threading.StackCrawlMark&) <0x00067> at System.Activator.CreateInstance (System.Type,bool) <0x000b3> at System.RuntimeType.CreateInstanceImpl (System.Reflection.BindingFlags,System.Reflection.Binder,object[],System.Globalization.CultureInfo,object[],System.Threading.StackCrawlMark&) <0x005c3> at System.Activator.CreateInstance (System.Type,System.Reflection.BindingFlags,System.Reflection.Binder,object[],System.Globalization.CultureInfo,object[]) <0x001fb> at System.Activator.CreateInstance (System.Type,System.Reflection.BindingFlags,System.Reflection.Binder,object[],System.Globalization.CultureInfo) <0x00047> at System.SecurityUtils.SecureCreateInstance (System.Type,object[],bool) <0x00097> at System.SecurityUtils.SecureCreateInstance (System.Type) <0x0001b> at System.ComponentModel.LicenseManager.ValidateInternalRecursive (System.ComponentModel.LicenseContext,System.Type,object,bool,System.ComponentModel.License&,string&) <0x000c7> at System.ComponentModel.LicenseManager.ValidateInternal (System.Type,object,bool,System.ComponentModel.License&) <0x0004f> at System.ComponentModel.LicenseManager.Validate (System.Type) <0x00027> at HSPI_SENSIBO.Main..cctor () <0x0009b> at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0x0006f> at <unknown> <0xffffffff> at (wrapper managed-to-native) object.__icall_wrapper_mono_generic_class_init (intptr) <0x00037> at HSPI_SENSIBO.HSPI.get_Name () <0x00027> at (wrapper runtime-invoke) <Module>.runtime_invoke_object__this__ (object,intptr,intptr,intptr) <0x000cb> at <unknown> <0xffffffff> at (wrapper managed-to-native) System.Reflection.MonoMethod.InternalInvoke (System.Reflection.MonoMethod,object,object[],System.Exception&) <0x00043> at System.Reflection.MonoMethod.Invoke (object,System.Reflection.BindingFlags,System.Reflection.Binder,object[],System.Globalization.CultureInfo) <0x000ab> at System.RuntimeType.InvokeMember (string,System.Reflection.BindingFlags,System.Reflection.Binder,object,object[],System.Reflection.ParameterModifier[],System.Globalization.CultureInfo,string[]) <0x010a7> at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet (object,System.Type,string,object[],string[],bool[]) <0x000cb> at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet (object,System.Type,string,object[],string[],System.Type[],bool[]) <0x00057> at Scheduler.clsHSPI/Worker.ProcessAssembly () <0x00137> at (wrapper remoting-invoke-with-check) Scheduler.clsHSPI/Worker.ProcessAssembly () <0x00063> at (wrapper xdomain-dispatch) Scheduler.clsHSPI/Worker.ProcessAssembly (object,byte[]&,byte[]&) <0x00103> at (wrapper xdomain-invoke) Scheduler.clsHSPI/Worker.ProcessAssembly () <0x000e3> at (wrapper remoting-invoke-with-check) Scheduler.clsHSPI/Worker.ProcessAssembly () <0x0004b> at Scheduler.clsHSPI/PluginAttributes.Process () <0x0041b> at Scheduler.clsHSPI.FindInterfaces (bool&) <0x004cf> at (wrapper remoting-invoke-with-check) Scheduler.clsHSPI.FindInterfaces (bool&) <0x00073> at Scheduler.SC_Main.c730f8742e287d8f2971f387fee693ad4 () <0x0008b> at Scheduler.SC_Main.StartUp () <0x00903> at HSConsole.HSConsole.Main () <0x00413> at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0x000bf> Native stacktrace: Debug info from gdb: [New LWP 1197] [New LWP 1198] [New LWP 1201] [New LWP 1202] [New LWP 1203] [New LWP 1205] [New LWP 1206] [New LWP 1207] [New LWP 1208] [New LWP 1209] [New LWP 1210] [New LWP 1211] [New LWP 1212] [New LWP 1213] [New LWP 1214] [New LWP 1215] [New LWP 1226] [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1". 0x76e194cc in __waitpid (pid=1227, stat_loc=0x7e8bfa00, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29 29 ../sysdeps/unix/sysv/linux/waitpid.c: Ingen slik fil eller filkatalog. Id Target Id Frame * 1 Thread 0x76f30570 (LWP 1196) "(System)_17-okt" 0x76e194cc in __waitpid (pid=1227, stat_loc=0x7e8bfa00, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29 2 Thread 0x763ff470 (LWP 1197) "SGen worker" 0x76e1494c in __pthread_cond_wait (cond=0x3258f0, mutex=0x3258bc) at pthread_cond_wait.c:186 3 Thread 0x76a53470 (LWP 1198) "Finalizer" 0x76e17014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0x31d8c0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 4 Thread 0x7374b470 (LWP 1201) "Logging Class C" 0x76e14ce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0x7374a704) at pthread_cond_timedwait.c:198 5 Thread 0x734ff470 (LWP 1202) "Timer-Scheduler" 0x76e14ce8 in __pthread_cond_timedwait (cond=0xe6fa40, mutex=0xe6fa24, abstime=0x734fe35c) at pthread_cond_timedwait.c:198 6 Thread 0x733ff470 (LWP 1203) "(System)_17-okt" 0x76e14ce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0x733fed54) at pthread_cond_timedwait.c:198 7 Thread 0x72fff470 (LWP 1205) "Threadpool work" 0x76e14ce8 in __pthread_cond_timedwait (cond=0x1472a28, mutex=0x1472a58, abstime=0x72ffed60) at pthread_cond_timedwait.c:198 8 Thread 0x7335d470 (LWP 1206) "Threadpool work" 0x76d90cb0 in poll () at ../sysdeps/unix/syscall-template.S:84 9 Thread 0x72cff470 (LWP 1207) "Threadpool work" 0x76e14ce8 in __pthread_cond_timedwait (cond=0x1472a28, mutex=0x1472a58, abstime=0x72cfed60) at pthread_cond_timedwait.c:198 10 Thread 0x72aff470 (LWP 1208) "Threadpool work" 0x76e14ce8 in __pthread_cond_timedwait (cond=0x1472a28, mutex=0x1472a58, abstime=0x72afed60) at pthread_cond_timedwait.c:198 11 Thread 0x72230470 (LWP 1209) "(System)_17-okt" 0x76e14ce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0x7222f6d4) at pthread_cond_timedwait.c:198 12 Thread 0x72130470 (LWP 1210) "(System)_17-okt" 0x76e1494c in __pthread_cond_wait (cond=0xe70898, mutex=0xe7087c) at pthread_cond_wait.c:186 13 Thread 0x72030470 (LWP 1211) "(System)_17-okt" 0x76e14ce8 in __pthread_cond_timedwait (cond=0xe70cd8, mutex=0xe70cbc, abstime=0x7202f464) at pthread_cond_timedwait.c:198 14 Thread 0x71f30470 (LWP 1212) "(System)_17-okt" 0x76e1494c in __pthread_cond_wait (cond=0xe70e70, mutex=0xe70e54) at pthread_cond_wait.c:186 15 Thread 0x71e30470 (LWP 1213) "(System)_17-okt" 0x76e14ce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0x71e2f56c) at pthread_cond_timedwait.c:198 16 Thread 0x71aff470 (LWP 1214) "(System)_17-okt" 0x76e14ce8 in __pthread_cond_timedwait (cond=0xe70b40, mutex=0xe70b24, abstime=0x71afe44c) at pthread_cond_timedwait.c:198 17 Thread 0x718ef470 (LWP 1215) "(System)_17-okt" 0x76e186a0 in accept () at ../sysdeps/unix/syscall-template.S:84 18 Thread 0x71537470 (LWP 1226) "Timer-Scheduler" 0x76e14ce8 in __pthread_cond_timedwait (cond=0xe72dc8, mutex=0xe72dac, abstime=0x715362e4) at pthread_cond_timedwait.c:198 Thread 18 (Thread 0x71537470 (LWP 1226)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0xe72dc8, mutex=0xe72dac, abstime=0x715362e4) at pthread_cond_timedwait.c:198 #1 0x0021caf8 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 17 (Thread 0x718ef470 (LWP 1215)): #0 0x76e186a0 in accept () at ../sysdeps/unix/syscall-template.S:84 #1 0x0022e1c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 16 (Thread 0x71aff470 (LWP 1214)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0xe70b40, mutex=0xe70b24, abstime=0x71afe44c) at pthread_cond_timedwait.c:198 #1 0x0021caf8 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 15 (Thread 0x71e30470 (LWP 1213)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0x71e2f56c) at pthread_cond_timedwait.c:198 #1 0x002488f4 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 14 (Thread 0x71f30470 (LWP 1212)): #0 0x76e1494c in __pthread_cond_wait (cond=0xe70e70, mutex=0xe70e54) at pthread_cond_wait.c:186 #1 0x0021cdfc in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 13 (Thread 0x72030470 (LWP 1211)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0xe70cd8, mutex=0xe70cbc, abstime=0x7202f464) at pthread_cond_timedwait.c:198 #1 0x0021caf8 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 12 (Thread 0x72130470 (LWP 1210)): #0 0x76e1494c in __pthread_cond_wait (cond=0xe70898, mutex=0xe7087c) at pthread_cond_wait.c:186 #1 0x0021cdfc in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 11 (Thread 0x72230470 (LWP 1209)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0x7222f6d4) at pthread_cond_timedwait.c:198 #1 0x002488f4 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 10 (Thread 0x72aff470 (LWP 1208)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0x1472a28, mutex=0x1472a58, abstime=0x72afed60) at pthread_cond_timedwait.c:198 #1 0x001918c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 9 (Thread 0x72cff470 (LWP 1207)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0x1472a28, mutex=0x1472a58, abstime=0x72cfed60) at pthread_cond_timedwait.c:198 #1 0x001918c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 8 (Thread 0x7335d470 (LWP 1206)): #0 0x76d90cb0 in poll () at ../sysdeps/unix/syscall-template.S:84 #1 0x00193504 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 7 (Thread 0x72fff470 (LWP 1205)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0x1472a28, mutex=0x1472a58, abstime=0x72ffed60) at pthread_cond_timedwait.c:198 #1 0x001918c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 6 (Thread 0x733ff470 (LWP 1203)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0x733fed54) at pthread_cond_timedwait.c:198 #1 0x002488f4 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 5 (Thread 0x734ff470 (LWP 1202)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0xe6fa40, mutex=0xe6fa24, abstime=0x734fe35c) at pthread_cond_timedwait.c:198 #1 0x0021caf8 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 4 (Thread 0x7374b470 (LWP 1201)): #0 0x76e14ce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0x7374a704) at pthread_cond_timedwait.c:198 #1 0x002488f4 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 3 (Thread 0x76a53470 (LWP 1198)): #0 0x76e17014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0x31d8c0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0x31d8c0, abstime=0x0) at sem_waitcommon.c:115 #2 0x76e17158 in __new_sem_wait_slow (sem=0x31d8c0, abstime=0x0) at sem_waitcommon.c:282 #3 0x001ac174 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 2 (Thread 0x763ff470 (LWP 1197)): #0 0x76e1494c in __pthread_cond_wait (cond=0x3258f0, mutex=0x3258bc) at pthread_cond_wait.c:186 #1 0x002158e8 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) Thread 1 (Thread 0x76f30570 (LWP 1196)): #0 0x76e194cc in __waitpid (pid=1227, stat_loc=0x7e8bfa00, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29 #1 0x000bbb44 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) ================================================================= Got a SIGABRT while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= ./go: linje 2: 1192 Avbrutt (SIGABRT) sudo mono HSConsole.exe --log pi@raspberrypi:~/HomeSeer $ Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Guahtdim Skrevet 17. oktober 2018 Del Skrevet 17. oktober 2018 slett filen HSPI_SCREPOSTIROY.EXE? Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Frankh Skrevet 17. oktober 2018 Forfatter Del Skrevet 17. oktober 2018 Takk for svar, men det testa jeg tidlig med samme utfall. 03.28.39.6459:[Plug-In]->Found plug-in: mcsMQTT, version: 3.4.5.2 03.28.41.8425:[Plug-In]->Found plug-in: MQTT, version: 1.5.0.0 03.28.44.0772:[Plug-In]->Found plug-in: RFXCOM, version: 30.0.0.36 * Assertion at metadata.c:980, condition `index < meta->heap_blob.size' not met Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Guahtdim Skrevet 17. oktober 2018 Del Skrevet 17. oktober 2018 Siden jeg selv ikke kjører Linux så vet jeg ikke. Hvis du har backup av HomeSeer katalogen ville jeg prøvd å kopiert inn den. Men det beste er kanskje å vente til noen av de som kjører Linux-utgaver kommer med innspill. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Frankh Skrevet 17. oktober 2018 Forfatter Del Skrevet 17. oktober 2018 Ahh...Du satte meg på sporet ?☺️Det var Sensibo.hspi eller hva den hete som laget krøll. Tusen hjertelig for innspill. Frank Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
