Alpøy Skrevet 19. oktober 2018 Del Skrevet 19. oktober 2018 (endret) Hei, Noen som kjører id lock 150 her i OH? Sliter med at den sender "doble" kommandoer, dvs. at den går ON/OFF 2 ganger før den er ferdig med låsing/åpning. Lager noe trøbbel for reglene mine Låsing via Z-WAVE (ON): 2018-10-16 13:54:12.465 [ome.event.ItemCommandEvent] - Item 'MyLockSwitch ' received command ON 2018-10-16 13:54:12.469 [nt.ItemStatePredictedEvent] - MyLockSwitch predicted to become ON 2018-10-16 13:54:12.476 [vent.ItemStateChangedEvent] - MyLockSwitch changed from OFF to ON 2018-10-16 13:54:14.140 [vent.ItemStateChangedEvent] - MyLockSwitch changed from ON to OFF 2018-10-16 13:54:15.763 [vent.ItemStateChangedEvent] - MyLockSwitch changed from OFF to ON Åpne lås via Z-WAVE (OFF): 2018-10-16 13:54:24.241 [ome.event.ItemCommandEvent] - Item 'MyLockSwitch ' received command OFF 2018-10-16 13:54:24.246 [nt.ItemStatePredictedEvent] - MyLockSwitch predicted to become OFF 2018-10-16 13:54:24.250 [vent.ItemStateChangedEvent] - MyLockSwitch changed from ON to OFF 2018-10-16 13:54:25.917 [vent.ItemStateChangedEvent] - MyLockSwitch changed from OFF to ON 2018-10-16 13:54:26.481 [vent.ItemStateChangedEvent] - MyLockSwitch changed from ON to OFF Låse manuelt via insiden (inside): 2018-10-16 13:55:53.986 [vent.ItemStateChangedEvent] - MyLockSwitch changed from OFF to ON Åpne manuelt fra innsiden (inside): 2018-10-16 13:56:11.513 [vent.ItemStateChangedEvent] - MyLockSwitch changed from ON to OFF Som beskrevet ovenfor skjer dette kun ved å låse via Z-Wave kommando, ved manuell låsing kommer det bare en state change. Endret 19. oktober 2018 av Alpøy Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Alpøy Skrevet 20. oktober 2018 Forfatter Del Skrevet 20. oktober 2018 Løste seg ved å øke command poll til 5000ms, Ref: https://community.openhab.org/t/request-to-add-device-to-the-z-wave-db-new-version-of-id-lock/48824/52 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
