ivanowsky
    Futurehome
    Home Assistant
    Annet
ivanowsky sine prestasjoner
Smartplugger
Smartplugger (4/16)
  • Dedikert
  1. Takk for det. Jeg har slettet alle eksisterende homely enheter og entities fra HA og prøvd debug versjon av homely-mqtt nå. Der kommer det i container logg følgende etter start av containeren: (node:1) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead. (Use `node --trace-deprecation ...` to show where the warning was created) [15:08:21.484] INFO (1): Starting service [15:08:22.072] INFO (1): Authenticated. Token expires at 2023-11-26T15:38:22.072Z [15:08:22.238] INFO (1): Loaded 1 homes [15:08:24.616] INFO (1): Publishing state for Fire [15:08:24.616] INFO (1): Publishing state for Battery low [15:08:24.617] INFO (1): Publishing state for Battery voltage [15:08:24.617] INFO (1): Publishing state for Networklink address [15:08:24.618] INFO (1): Publishing state for Networklink strength [15:08:24.619] INFO (1): Publishing state for Temperature [15:08:24.619] INFO (1): Publishing state for Fire [15:08:24.619] INFO (1): Publishing state for Battery low [15:08:24.620] INFO (1): Publishing state for Battery voltage [15:08:24.620] INFO (1): Publishing state for Networklink address [15:08:24.620] INFO (1): Publishing state for Networklink strength [15:08:24.622] INFO (1): Publishing state for Temperature [15:08:24.622] INFO (1): Publishing state for Fire [15:08:24.623] INFO (1): Publishing state for Battery low [15:08:24.623] INFO (1): Publishing state for Battery voltage [15:08:24.624] INFO (1): Publishing state for Networklink address [15:08:24.624] INFO (1): Publishing state for Networklink strength [15:08:24.625] INFO (1): Publishing state for Temperature [15:08:24.625] INFO (1): Publishing state for Fire [15:08:24.627] INFO (1): Publishing state for Battery low [15:08:24.627] INFO (1): Publishing state for Battery voltage [15:08:24.627] INFO (1): Publishing state for Networklink address [15:08:24.627] INFO (1): Publishing state for Networklink strength [15:08:24.628] INFO (1): Publishing state for Temperature [15:08:24.628] INFO (1): Publishing state for Motion [15:08:24.629] INFO (1): Publishing state for Tamper [15:08:24.629] INFO (1): Publishing state for Battery defect [15:08:24.629] INFO (1): Publishing state for Battery low [15:08:24.630] INFO (1): Publishing state for Battery voltage [15:08:24.630] INFO (1): Publishing state for Networklink address [15:08:24.630] INFO (1): Publishing state for Networklink strength [15:08:24.630] INFO (1): Publishing state for Temperature [15:08:24.631] INFO (1): Publishing state for Fire [15:08:24.631] INFO (1): Publishing state for Battery low [15:08:24.631] INFO (1): Publishing state for Battery voltage [15:08:24.632] INFO (1): Publishing state for Networklink address [15:08:24.632] INFO (1): Publishing state for Networklink strength [15:08:24.633] INFO (1): Publishing state for Temperature [15:08:24.634] INFO (1): Publishing state for Fire [15:08:24.634] INFO (1): Publishing state for Battery low [15:08:24.634] INFO (1): Publishing state for Battery voltage [15:08:24.635] INFO (1): Publishing state for Networklink address [15:08:24.635] INFO (1): Publishing state for Networklink strength [15:08:24.635] INFO (1): Publishing state for Temperature [15:08:24.636] INFO (1): Publishing state for Fire [15:08:24.636] INFO (1): Publishing state for Battery low [15:08:24.636] INFO (1): Publishing state for Battery voltage [15:08:24.636] INFO (1): Publishing state for Networklink address [15:08:24.636] INFO (1): Publishing state for Networklink strength [15:08:24.637] INFO (1): Publishing state for Temperature [15:08:24.637] INFO (1): Publishing state for Motion [15:08:24.637] INFO (1): Publishing state for Tamper [15:08:24.637] INFO (1): Publishing state for Battery defect [15:08:24.638] INFO (1): Publishing state for Battery low [15:08:24.638] INFO (1): Publishing state for Battery voltage [15:08:24.638] INFO (1): Publishing state for Networklink address [15:08:24.639] INFO (1): Publishing state for Networklink strength [15:08:24.639] INFO (1): Publishing state for Temperature [15:08:24.639] INFO (1): Publishing state for Fire [15:08:24.639] INFO (1): Publishing state for Battery low [15:08:24.640] INFO (1): Publishing state for Battery voltage [15:08:24.640] INFO (1): Publishing state for Networklink address [15:08:24.640] INFO (1): Publishing state for Networklink strength [15:08:24.640] INFO (1): Publishing state for Temperature [15:08:24.641] INFO (1): Publishing state for Contact [15:08:24.641] INFO (1): Publishing state for Tamper [15:08:24.641] INFO (1): Publishing state for Battery low [15:08:24.641] INFO (1): Publishing state for Battery voltage [15:08:24.642] INFO (1): Publishing state for Networklink address [15:08:24.642] INFO (1): Publishing state for Networklink strength [15:08:24.642] INFO (1): Publishing state for Temperature [15:08:24.643] INFO (1): Publishing state for Fire [15:08:24.643] INFO (1): Publishing state for Battery low [15:08:24.643] INFO (1): Publishing state for Battery voltage [15:08:24.644] INFO (1): Publishing state for Networklink address [15:08:24.644] INFO (1): Publishing state for Networklink strength [15:08:24.644] INFO (1): Publishing state for Temperature [15:08:24.644] INFO (1): Publishing state for Contact [15:08:24.645] INFO (1): Publishing state for Tamper [15:08:24.645] INFO (1): Publishing state for Battery low [15:08:24.645] INFO (1): Publishing state for Battery voltage [15:08:24.646] INFO (1): Publishing state for Networklink address [15:08:24.646] INFO (1): Publishing state for Networklink strength [15:08:24.646] INFO (1): Publishing state for Temperature [15:08:24.646] INFO (1): Publishing state for Fire [15:08:24.647] INFO (1): Publishing state for Battery low [15:08:24.647] INFO (1): Publishing state for Battery voltage [15:08:24.648] INFO (1): Publishing state for Networklink address [15:08:24.648] INFO (1): Publishing state for Networklink strength [15:08:24.648] INFO (1): Publishing state for Temperature [15:08:24.649] INFO (1): Publishing state for Fire [15:08:24.649] INFO (1): Publishing state for Battery low [15:08:24.649] INFO (1): Publishing state for Battery voltage [15:08:24.650] INFO (1): Publishing state for Networklink address [15:08:24.651] INFO (1): Publishing state for Networklink strength [15:08:24.651] INFO (1): Publishing state for Temperature Så det stemmer med oppsettet i Homely (jeg har 11 røykvarslere, 2 bevegelsessensorer og 2 dørsensorer). Men i HA (og discovery meldinger i mqtt explorer) kommer det fortsatt kun de samme 4 røykvarslere som pleide å komme før og. Hva som er påfallende er at en av de fire røykvarslere mangler noen entities. Den har kun "Fire" og "Battery low". De andre tre har i tillegg "Battery voltage", "Networklink address", "Networklink strength", "Temperature".
  2. Nei ingenting der. Kanskje det helper: I mqtt explorer ser jeg meldinger om status oppdateringer for alle enheter (f.e. homely/UUID/temperature/state = 21.4) meldinger om discovery kun for 4 enheter (f.e. homeassistent/binary_sensor/UUID/fire/config = { ... } Om containeren sender ikke de andre discovery meldinger eller om de er "invalid" på en måte og blir forkastet av mosquitto kan jeg heller ikke si. Jeg skal også prøve å finne ut av det og kommer med en tilbakemelding om jeg finner noe ut :)
  3. Da har jeg sjekket det. I mqtt debug loggen ser jeg kun meldinger om de fire enhetene som er synlig i HA.
  4. Jeg har samme problem som @gert Ifølge mqtt explorer får brokeren oppdateringer for alle enheter men kun discovery for 4, med resultat at det vises kun de 4 enheter i HA.
  5. Samme her. Og det ser ut som om de har et større problem. Appen her funker ikke, den sier at hjemmesentralen er offline selv om den er på nett. Jeg hadde også en del varsler om offline/online hjemmesentral i løpet av uken. Virker veldig ustabilt for tiden. Finnes det egentlig en offisiell status side fra Homely hvor de varsler om problemer med systemet?
