Viser innholdet med mest poeng fra 12. jan. 2026 i alle områder
  1. Det tipper jeg du har rett i. Selv om jeg ville testet først med en enkel T568B TP-kabel og brukt 1 og 2 derfra til hhv A og B på Modbus-modulen. Har jobbet en del med videre oppsett nå, her er det jeg har til nå. Her er hele modbus.yaml: - name: "modbusgw" type: rtuovertcp host: 192.168.0.11 port: 502 retry_on_empty: true timeout: 10 climates: - name: Swegon CASA R3 unique_id: swegon_casa_r3 slave: 1 address: 6200 input_type: input target_temp_register: 5100 temperature_unit: C precision: 1 sensors: - name: Swegon fresh air temperature unique_id: swegon_fresh_air_temp slave: 1 address: 6200 scale: 0.1 unit_of_measurement: °C device_class: temperature precision: 1 input_type: input - name: Swegon supply air before re-heater temperature unique_id: swegon_outside_air_temp slave: 1 address: 6201 scale: 0.1 unit_of_measurement: °C device_class: temperature precision: 1 input_type: input - name: Swegon heated supply air temperature unique_id: swegon_supply_air_temp slave: 1 address: 6202 scale: 0.1 unit_of_measurement: °C device_class: temperature precision: 1 input_type: input - name: Swegon extract air temperature unique_id: swegon_extract_air_temp slave: 1 address: 6203 scale: 0.1 unit_of_measurement: °C device_class: temperature precision: 1 input_type: input - name: Swegon exhaust air temperature unique_id: swegon_exhaust_air_temp slave: 1 address: 6204 scale: 0.1 unit_of_measurement: °C device_class: temperature precision: 1 input_type: input - name: Swegon room temperature unique_id: swegon_room_temp slave: 1 address: 6205 scale: 0.1 unit_of_measurement: °C device_class: temperature precision: 1 input_type: input - name: Swegon air RH unique_id: swegon_air_RH slave: 1 address: 6213 unit_of_measurement: "%" device_class: humidity input_type: input - name: Swegon air AH unique_id: swegon_air_AH slave: 1 address: 6214 unit_of_measurement: "g/m³" scale: 0.01 precision: 1 input_type: input - name: Swegon unit state numerical unique_id: swegon_unit_state_num slave: 1 address: 6300 input_type: input - name: Swegon operating mode numerical unique_id: swegon_operating_mode_num slave: 1 address: 5000 input_type: holding - name: Swegon extract fan RPM unique_id: swegon_extract_fan RPM slave: 1 address: 6305 scale: 1 unit_of_measurement: rpm input_type: input - name: Swegon supply fan RPM unique_id: swegon_supply_fan RPM slave: 1 address: 6304 scale: 1 unit_of_measurement: rpm input_type: input - name: Swegon summer night cooling control numerical unique_id: swegon_summer_night_cooling_control_numerical slave: 1 address: 5163 input_type: holding - name: Swegon summer cooling Fresh air temperature limit modbus unique_id: swegon_summer_cooling_fresh_air_temp_limit_modbus slave: 1 address: 5164 unit_of_measurement: °C device_class: temperature input_type: holding - name: Swegon summer cooling Fresh air temperature start limit modbus unique_id: swegon_summer_cooling_fresh_air_temp_start_limit_modbus slave: 1 address: 5165 unit_of_measurement: °C device_class: temperature input_type: holding - name: Swegon summer cooling room temperature limit modbus unique_id: swegon_summer_cooling_room_temp_limit_modbus slave: 1 address: 5166 unit_of_measurement: °C device_class: temperature input_type: holding - name: Swegon summer cooling minimum supply temperature limit modbus unique_id: swegon_summer_cooling_min_supply_temp_limit_modbus slave: 1 address: 5167 unit_of_measurement: °C device_class: temperature input_type: holding ...og fra templates.yaml: - sensor: - name: "Swegon unit state" unique_id: swegon_unit_state state: > {% set state = states('sensor.swegon_unit_state_numerical') %} {% set map = { '0': "External Stop", '1': "User Stopped", '2': "Starting", '3': "Normal", '4': "Commissioning" } %} {{map.get(state) if state in map else 'Unknown'}} attributes: numerical_mode: "{{ states('sensor.swegon_unit_state_numerical') }}" - select: - name: "Swegon operating mode" unique_id: swegon_operating_mode state: > {% set state = states('sensor.swegon_operating_mode_numerical') %} {% set map = { '0': "Stopped", '1': "Away", '2': "Home", '3': "Boost", '4': "Travelling" } %} {{map.get(state) if state in map else 'Unknown'}} options: "{{ ['Stopped', 'Away', 'Home', 'Boost', 'Travelling']}}" select_option: - service: modbus.write_register data: address: 5000 unit: 1 hub: modbusgw value: > {% set map = { "Stopped": '0', "Away": '1', "Home": '2', "Boost": '3', "Travelling": '4' } %} {{map.get(option) if option in map else 'Unknown'}} - name: Swegon summer night cooling control unique_id: swegon_summer_night_cooling_control state: > {% set state = states('sensor.swegon_summer_night_cooling_control_numerical') %} {% set map = { '0': "Off", '1': "Low", '2': "Normal", '3': "High", '4': "Full", '5': "User" } %} {{map.get(state) if state in map else 'Unknown'}} options: "{{ ['Off', 'Low', 'Normal', 'High', 'Full', 'User']}}" select_option: - service: modbus.write_register data: address: 5163 unit: 1 hub: modbusgw value: > {% set map = { "Off": '0', "Low": '1', "Normal": '2', "High": '3', "Full": '4', "User": '5' } %} {{map.get(option) if option in map else 'Unknown'}} - number: - name: "Swegon summer cooling room temperature limit" unique_id: swegon_summer_cooling_room_temperature_limit state: "{{ states('sensor.swegon_summer_cooling_room_temperature_limit_modbus') }}" step: "{{ 0.5 }}" min: "{{ 0 }}" max: "{{ 35 }}" set_value: service: modbus.write_register data: address: 5166 unit: 1 hub: modbusgw value: "{{ value }}" De to tingene som ikke funker så bra er at sensor.swegon_exhaust_air_temperature av en eller annen grunn melder 0 grader, og at scale'en for target_temp og målt temp brukt i climate'en er forskjellig, sånn at en av de blir feil uansett om jeg bruker scale: 1 eller scale: 0.1 🤷‍♀️
