Viser innholdet med mest poeng fra 05. nov. 2022 i alle områder
  1. Gleder meg til jeg har tid til å se på dette. Som vanlig: Gratis for HS4 pro. For alle andre: I disse "Black dager" har HS rabatter. Notable Features and Improvements HS4Touch includes many tweaks and improvements over HS3Touch. This list includes the most noteworthy changes. Better support for 4K screens (scaling toolbars and palettes) Camera property added for easier inclusion of cameras integrated with HS4 Right-clicking on an element opens a menu with these options: Actions When Released, Actions When Pressed, Select Normal Image, Select Pressed Image, Set Association, Bring Forward, Send Backward, Rename, Delete, Copy, Save as Custom Template. New Simple graphics skin added with updated and more customizable elements. Device selection has changed throughout the program. Devices are displayed in a better format and matches the selectors in HS4 to make it easier to find a device. Device lists can now include the device reference #. This can sometimes make is easier to find a specific device feature. The Windows client now includes a new WebView control that is based on the Edge browser. This allows for displaying any type of web content. Variables have been added and may be used in place of explicit references to cameras, devices, and labels. This allows for very dynamic screens and can reduce your screen count. New replacement variable "$LASTCHANGE" will display the last change of a device. Screens can now be into groups for better organization. Groups will display on the screens menu. The screens menu is now alpha sorted. New action to set the color of a color bulb. Screens can now be set to a height greater than the actual screen. The screen can then be scrolled. On Windows CONTROL-R can be used to run the Windows client. New property on a screen that will stop that screen from returning to the main screen. When dragging the corner of an element, hold down the shift key to keep the aspect ratio. Clicking on an element in the elements palette now displays the resolution of the element. When moving an element with the control arrows, holding the Control key moves it by 10 pixels rather than 1. For IOS, deployment options added for IPhone 14. Many bug fixes throughout the program Updated clients are required for Android and IOS, which are named HS4Touch.
  2. I dag forsket jeg på hvordan man kan integrere mitt Flexit Uni2 med CU60 styreenhet og CI60 panel - uten å måtte gå til innkjøp av CI66 modbus-adapter. Jeg kan komme med følgende opplysninger: Protokollen mellom styreenhet og panel / mellom styreenhet og adapter er RS485, men IKKE modbus. Dette er en proprietær protokoll. Baud er 115,2 Kbaud 8N1 (LSB) Styreenhet sender to forskjellige telegram syklisk: Et kort telegram hvor pakkene alltid starter med 2 - 1: Og et langt telegram hvor pakkene alltid starter på 0 - 16: Feltet markert med rødt har jeg bekreftet er viftehastighet (0 = av, 1 = lav fart, 2 = middels fart, 3 = full fart). Egentlig er det bare å gjennomgå alle feltene og finne ut hva de representerer. Det virker som om prinsippene er like https://github.com/Vongraven/Flexit-SL4R-master (som ble nevnt over). Men protokollen er ikke lik. Jeg tror det bør være en relativ grei jobb å tilpasse det. Jeg har bestilt en Elfin EW11A (https://www.aliexpress.com/item/4001152539658.html) og tenker å gjøre et forsøk med denne. Vil tro den gjør susen. Tenker å sende rådata rett fra EW11 over TCP socket og parse dem eksternt i Node-Red. Det å sende verdier til styreenheten kan nok være mer utfordrende med denne metoden. Jeg er usikker på hvordan flytkontrollen egentlig er lagt opp. Men det får bli neste problem. Hardwareoppsett: Eksempel på korte type telegram og lang type telegram: Serial buffer.csv
