Viser innholdet med mest poeng fra 15. jan. 2026 i alle områder
  1. @Arsenii I also use a modified version of @Siljelb setup and the only differense between her setup and the Swegon documentation is the "one off" difference due to two different way of adressing registers in the modbus world. See https://community.home-assistant.io/t/modbus-register-address-mapping-trouble/167057 and google for "home assistant modbus pdu address" to get more details. The first 4 sensors in my yaml config: sensors: - name: Swegon fresh air temperature unique_id: swegon_fresh_air_temp slave: 1 address: 6200 scale: 0.1 unit_of_measurement: °C device_class: temperature precision: 1 input_type: input scan_interval: 30 - name: Swegon supply air before re-heater temperature unique_id: swegon_outside_air_temp slave: 1 address: 6201 ... - name: Swegon heated supply air temperature unique_id: swegon_supply_air_temp slave: 1 address: 6202 ... - name: Swegon extract air temperature unique_id: swegon_extract_air_temp slave: 1 address: 6203 ... The corresponding registers in the Swegon documentation; As you can se the registers are one off. Subtract one and use that in the HA configuration. The 3x prefix indicate that this is a readonly register. It can only be read not updated using modbus, and are also marked R (read) in the documentation.
