Viser innholdet med mest poeng fra 29. des. 2024 i alle områder
  1. Du vil bruke filter i objects for å luke bort falske notifikasjoner. Her er min konfigurasjon, kjører på en i3-6100U med 4gb ram. Kjører detect på gpu (integrert i cpu). Anbefaler betaen med "full access". Kode: #environment_vars: # LIBVA_DRIVER_NAME: i965 #LIBVA_DRIVER_NAME: iHD mqtt: host: homeassistant user: mqtt_user password: mqtt_password detectors: ov: type: openvino device: GPU model: width: 300 height: 300 input_tensor: nhwc input_pixel_format: bgr path: /openvino-model/ssdlite_mobilenet_v2.xml labelmap_path: /openvino-model/coco_91cl_bkgr.txt objects: track: - person - car - cat filters: person: threshold: 0.75 car: threshold: 0.90 go2rtc: streams: reolink_510wa: - rtsp://admin:[email protected]:554/h264Preview_01_main reolink_510wa_sub: - rtsp://admin:[email protected]:554/h264Preview_01_sub record: enabled: true retain: days: 5 mode: motion alerts: retain: days: 5 pre_capture: 5 post_capture: 5 detections: retain: days: 5 pre_capture: 5 post_capture: 5 cameras: reolink_510wa: ffmpeg: output_args: record: preset-record-generic-audio-aac hwaccel_args: preset-vaapi #-hwaccel_device /dev/dri/renderD128 -hwaccel_output_format yuv420p inputs: - path: rtsp://127.0.0.1:8554/reolink_510wa?video&audio input_args: preset-rtsp-restream roles: - record - path: rtsp://127.0.0.1:8554/reolink_510wa_sub?video&audio input_args: preset-rtsp-restream roles: - detect detect: enabled: true width: 640 height: 480 fps: 5 snapshots: enabled: true timestamp: true bounding_box: true retain: default: 30 motion: mask: 0.176,0,0.721,0.252,0.872,0.519,1,0.731,1,0,0.781,0,0.575,0.003 threshold: 60 contour_area: 15 improve_contrast: 'true' objects: mask: 0.835,0.303,1,0.087,0.669,0,0.149,0 version: 0.15-0
  2. Hei! 03/22 = V1 Firmware 04/22 = V1 Firmware 09/22= V2 Firmware 07/24= V2 Firmware Forskjell på V1 vs V2. Korrigert kompensasjonstabell = Det vil si at den ønskede temperaturen harmonerer med målt temperatur. Alle modeller skal ha repeater funksjon på Zigbee. (V1 hadde en "aggressiv" kompensasjonstabell innebygget på linje med alle "dumme" panelovner, men dumme ovner rapporterer ikke målt temperatur og derfor opplever man ikke denne forskjellen) V1 modeller kan oppdateres til V2 firmware om man har en kontroller som støtter dette. Firmware ligger på nettsiden til Elektroimportøren, eller kontakt kundesenter for å få oversendt disse. Mvh Pål, Namron
  3. @JoeHugin Ikke noe som er bestemt enda, men jeg hører i gangene om at det diskuteres ettersom flyttbar varme er populært i resten av Europa. Så kan hende det kommer i 2025, før nesten vinter sesong, men ikke 100% sikkert enda.
  4. Er det noen planer om å inkludere Matter-støtte for oljeovnene og?
  5. Jeg ser også frem til Matter for Gen3 oljefylt radiator.. 😮‍💨 forøvrig en fantastisk varmeovn, prøvd mye rart i 15 år, men denne får faktisk god temp i stua. bare den hadde sluttet å vise celsius og fahrenheit om hverandre, så hadde jeg blitt glad 😅
