Hente batteristatus for alle enheter
stigvi
Bare et lite tips til de som har mange batteridrevne sensorer og bruker Home Assistant
Putt dette
{%- for state in states.sensor %}
{%- if 'battery' in state.name | lower %}
{% if state.state | int < 30 %}**{% endif %}{{state.state_with_unit}}, {{ state.name}}, {{ as_timestamp(state.last_updated) | timestamp_custom("%H:%M/%d.%m")}}{% if state.state | int < 30 %}**{% endif %}
{%- endif -%}
{% endfor %}
inn i en markdown panel og du får en liste ala dette i Lovelace. Merk at alle under 30% blir merket med fet skrift.
85 %, Bod Battery Level, 08:10/03.03
88 %, AQ2 Battery Level, 08:10/03.03
48 %, AQ3 Battery Level, 08:10/03.03
75 %, AQ4 Battery Level, 08:23/03.03
81 %, AQ5 Battery Level, 08:10/03.03
91 %, AQ6 Battery Level, 08:10/03.03
88 %, AQ7 Battery Level, 08:10/03.03
88 %, AQ8 Battery Level, 09:26/03.03
91 %, AQ9 Battery Level, 08:10/03.03
100 %, Bad 1. etg bryter Battery Level, 08:10/03.03
100 %, Bad 1. etg sensor Battery Level, 08:10/03.03
100 %, Bad U. etg bryter Battery Level, 08:10/03.03
99 %, Motion Sensor Battery Level, 08:10/03.03
91 %, Boddor Battery Level, 08:10/03.03
100 %, Gang 1. etg sensor Battery Level, 08:10/03.03
100 %, Gang 1. etg bryter Battery Level, 08:10/03.03
100 %, Gang U. etg sensor Battery Level, 08:10/03.03
100 %, Gang U. etg bryter Battery Level, 08:10/03.03
100 %, Garasje bryter Battery Level, 08:10/03.03
100 %, Garasje sensor Battery Level, 08:10/03.03
91 %, Garasjedor Battery Level, 08:10/03.03
100 %, Garasjeport Battery Level, 08:10/03.03
60 %, Garasjeport bryter Battery Level, 08:10/03.03
100 %, Gjesterom U. etg bryter Battery Level, 08:10/03.03
100 %, Hagestue Battery Level, 08:10/03.03
91 %, Hagestue sensor Battery Level, 08:10/03.03
91 %, Hoveddor Battery Level, 08:10/03.03
100 %, Hoveddor U. etg Battery Level, 08:10/03.03
100 %, Kjoekken bryter Battery Level, 08:10/03.03
100 %, Kontor bryter Battery Level, 08:10/03.03
100 %, Ringeklokke Battery Level, 08:10/03.03
96 %, Rullegardin hagestue a battery level, 08:10/03.03
99 %, Rullegardin hagestue b battery level, 08:37/03.03
100 %, Rullegardin hagestue c battery level, 08:10/03.03
57 %, SM-G930F Battery Level, 10:28/03.03
74 %, SM-G955F Battery Level, 10:20/03.03
100 %, Soverom 1. etg bryter Battery Level, 08:10/03.03
100 %, Soverom U. etg bryter Battery Level, 08:10/03.03
100 %, Stue bryter Battery Level, 08:10/03.03
87 %, TRADFRI open/close remote  Battery Level, 08:10/03.03
100 %, TV Stue bryter Battery Level, 08:10/03.03
100.0  %, UPS Battery, 08:10/03.03
27.1  V, UPS Battery Voltage, 08:10/03.03
100 %, Ute 1. etg sensor Battery Level, 08:10/03.03
100 %, Vannsensor bad 1. etg Battery Level, 08:10/03.03
100 %, Vannsensor bad U. etg Battery Level, 08:10/03.03
100 %, Vannsensor kjokkenbenk Battery Level, 08:10/03.03
95 %, Vannsensor ute 1. etg Battery Level, 08:10/03.03
100 %, Vannsensor ute 2. etg Battery Level, 08:10/03.03
100 %, Vannsensor ute U. etg Battery Level, 08:10/03.03
100 %, Vaskerom bryter Battery Level, 08:10/03.03
100 %, Vaskerom sensor Battery Level, 08:10/03.03
Putt dette
{%- endif -%}
{% endfor %}
*snip*
Om du bruker
{%- if 'battery' in state.name | lower and 'level' in state.name | lower %}
så slipper du sånn som "UPS Voltage" og "battery state".
Ja. Og dette for bare å liste opp de som har sunket under 70% istedenfor å liste opp all. Mulighetene er mange ?
{%- if state.state | int < 70 %}
{% if state.state | int < 27 %}**{% endif %}{{state.state_with_unit}}, {{ state.name}}, {{ as_timestamp(state.last_updated) | timestamp_custom("%H:%M/%d.%m")}}{% if state.state | int < 27 %}**{% endif %}
{%- endif -%}
{%- endif -%}
{% endfor %}
Edit: Her er test på < 70% med i den første testen istedenfor en ekstra nedenfor og så har jeg tatt med en test på "not in" så med fiLLLip sitt tips er vel det meste dekket
{%- if 'battery' in state.name | lower and 'voltage' not in state.name | lower and state.state | int < 70 %}
{%- endif -%}
{% endfor %}
Endret av stigvi
På 3.3.2020 den 5.42, stigvi skrev:
Hva er årsaken til template-sensorene mine ikke plukkes opp av denne? Jeg har en drøss Wyze-sensorer hvor jeg har splittet ut batteriet i separate sensorer og det hadde jo vært ålreit å kun vise de som er døden nær.
Jeg har satt opp alle batterisensorene slik:
- platform: template
  sensors:
    battery_garage:
      friendly_name: 'Garage Door'
      value_template: >-
        {% if states('binary_sensor.garage') %}
          {{ state_attr('binary_sensor.garage', 'battery_level') }}
        {% else %}
          unknown
        {% endif %}
      unit_of_measurement: '%'
      device_class: battery
Er det for øvrig en bedre måte å sette opp denne malen på som kan generere en batterisensor for hver nye dør- eller bevegelsessensor jeg inkluderer i systemet mitt?
Hvilken versjon av Home Assistant bruker du? Dette som du spør om kom i en versjon i vinter.
  sensors:
    battery_garage:
      value_template: >-
        {% else %}
          unknown
        {% endif %}
Jeg bruker https://github.com/thomasloven/lovelace-auto-entities for mine batteri, temp sensor etc
Ser veldig kjekt ut! Men det fungerer ikke hos meg. Kan du legge ut kortdefinisjonen her, så jeg kan se hva jeg mangler?
  - content: >-
        | lower and state.state | int <= 40 %}
        {% if state.state | int < 20 %}**{% endif %}{{state.state_with_unit}},
        timestamp_custom("%H:%M/%d.%m")}}{% if state.state | int < 20 %}**{%
        endif %}
        {%- endif -%}
        {% endfor %}
    type: markdown
Merk at denne lister opp kun de sensorene som har battery i navnet og har en batteristatus som er mindre enn 40%. Endre på dette etter eget behov.
Endret av stigvi
