        matvik
                Innlegg38
Alt skrevet av matvik
	Til informasjon og hjelp til feilfix så er loggen min under Sep-20 6:44:58 AM Error Initializing plug-in(2): teslaSeer Instance::Object reference not set to an instance of an object.STACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces() Sep-20 6:44:58 AM teslaSeer Warning Unable to create basic device. Error: Object reference not set to an instance of an object. Sep-20 6:44:58 AM Error NewDeviceEx failed to create and add a new device. Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:58 AM Error Device could not be added - duplicate device reference ID: -1 Sep-20 6:44:58 AM Error Too many devices, cannot create more than 9000 devices Sep-20 6:44:40 AM Warning Attempt by plugin to register a duplicate link of teslaSeerConfig. Plugin: teslaSeer Instance:
	Kan være jeg har gjort noe alvorlig feil i installasjonen, men skrudde av plugin, avsluttet homeseer, fulgte readme filen og startet homseer opp igjen. Av en eller annen grunn har TeslaSeer laget 8800 nye devicer som gjør at Homeseer ikke lenger fungerer noe særlig, treeeeeegt, noen som har peiling på hva det kan skyldes?
	Takker!
	Den ser jeg, men hva har du satt opp som innstilling for å få den til å låse seg selv rett etterpå?
	Men må du da ikke ha automatisk innlogging på maskinen som administrator? Det er vel ikke heldig?
	Har forsøkt det også, samt at jeg har laget en event kun for å endre temperatur. Skjer ingenting når eventen kjøres, men når jeg endrer devicen manuelt fra device manager så oppdateres appen med satt tempereatur på klimaanlegget.
	Jeg har nok et spørsmål som forhåpentligvis kan løses like fort som det forrige Jeg har laget en event for å skru på varmen i bilen fra en Enocean knapp, se vedlagt event. Problemet er at den ikke setter temperaturen i det hele tatt, men kun skrur på klimaanlegget. Når jeg går inn på device manager og endrer på driver_temp_setting manuelt så fungerer det veldig bra, men når den trigges fra en event så skjer det ingenting. Noen som kan peke meg i retning av mulig feil?
	Tusen takk! Det fungerte Endret først til 2 desimaler, men det fungerte ikke.. så endret til 5 og da fungerte det Da mangler jeg bare å finne ut hva jeg skal gjøre med informasjonen jeg henter ut, skulle gjerne ha visualisert det og lagt det inn i en database, men det får bli neste steg!
	Får samme virusfeil jeg også, men har lagt den til på ignorelisten (håper at det er en falsk positiv..) Jeg forsøker å få til noe ala geofencing jeg også og har forsøkt meg med forslaget til hflatoey med easytrigger og latitude/longitude informasjonen til bilen, men..jeg får det ikke til. Det jeg forsøker å gjøre er å lese ut hvor mye den ladet på en spesifikk posisjon (har gitt den en ganske stor geofence nå) for å så sende meg en epost. Trigger jeg eventen manuelt så får jeg eposten med verdien til parameteren jeg ønsker å få ut, men samme hva jeg forsøker så får jeg den ikke til å trigge selv, noe som ser den logiske bristen min?
	Noen her som har testet Fireangel integrert med Homeseer? Fungerer disse i serie utenom Homeseer også? Altså at man kan styre alle fra Homeseer, men at de fungerer helt fint i serie hvis Homeseer går ned også? Vurderer også Nest Protect med Homeseer plugin.
	Hei! Får følgende feilmelding: WARNING: Failed getting InterfaceStatus from Current Cost - the interface was not found in the list of active interfaces, the list may need to be refreshed. Det som er litt frustrerende er at den dukker opp på ulike plugins nå og da. Det eneste som har skjedd er at strømmen har gått hjemme tre ganger og at Homeseer maskinen da har mistet strøm. Har forsøkt å enable/disable, reinstallere samt google, men virker som det er forskjellige løsninger på hvert enkelt plugins problem med "Failed getting Interface status". Noen som har vært borte i det med Current Cost, eventuelt har opplevd det med andre plugins som har noen tips?
	Hei! Får denne feilmeldingen, er det noe som jeg må endre på? " feb-25 13:41:19 tesla debug (404) API server has changed, contact the developer of this plugin feb-25 13:41:19 Error In URLAction GET: The remote server returned an error: (404) Not Found."
	Det her løste seg ved en reinstallering av Ubuntu... så null læringseffekt!
- 22 svar
	Er ikke erfaren nok med HomeSeer, men trodde ikke det var såpass ustabilitet mellom releasene. Virket jo som f.eks .362 ikke var testet i det hele tatt.. Skal vente lenger neste gang!
- 4 svar
	Takker! Har testet ut litt forskjellig og fikk det til å fungere fint med Ubuntu 16.10 og HS .318. Ser nå at når jeg nedgraderte fra .357 til .318 på Ubuntu 17.04 så fungerte det også, så skal teste litt mer nå men akkurat nå ser det ut som om Ubuntu 17.04 og HS .318 er en god kombinasjon. Fikk en rekke feil på .357: - Zwave enheten falt ut hele tiden. - plugins fungerte ikke - fikk monofeil i logge - Generell treghet and the list goes on.
- 4 svar
	Har over den siste måneden slitt veldig med å en rekke ting til å fungere i HomeSeer og da jeg har hatt en del problemer som andre ikke har hatt så har jeg begynt å se på variablene. Det ser ut som om det at jeg kjører Ubuntu 17.04 server sammen med HomeSeer .357 på en virtuell maskin er noe som ikke akkurat er standard. Derfor lurer jeg, hvis jeg skal komme igang med noe stabilt så jeg får startet å automatisere istedenfor troubleshoote, hva kjører dere stabilt?
