Homely integration
kolaf
SumMarius skrev (9 timer siden):
Finner ikke noe slikt. Jeg er sikkert litt dum. Vil ha ting plug'n'play helst.
Får masse som published men finner ikke noe configuration. Hvilke logger skal jeg lete i? MQTT loggen i HA eller noen logger i docker?
[16:02:14.680] DEBUG (1): Marked Contact as published
[16:02:14.722] DEBUG (1): Marked Tamper as published
[16:02:14.751] DEBUG (1): Marked Battery low as published
[16:02:14.769] DEBUG (1): Marked Battery voltage as published
[16:02:14.790] DEBUG (1): Marked Networklink address as published
[16:02:14.812] DEBUG (1): Marked Networklink strength as published
[16:02:14.833] DEBUG (1): Marked Temperature as published
[16:02:14.874] DEBUG (1): Marked Contact as published
[16:02:14.909] DEBUG (1): Marked Tamper as published
[16:02:14.929] DEBUG (1): Marked Battery low as published
[16:02:14.950] DEBUG (1): Marked Battery voltage as published
[16:02:14.968] DEBUG (1): Marked Networklink address as published
[16:02:14.989] DEBUG (1): Marked Networklink strength as published
[16:02:15.007] DEBUG (1): Marked Temperature as published
[16:02:15.025] DEBUG (1): Marked Fire as published
[16:02:15.048] DEBUG (1): Marked Battery low as published
[16:02:15.070] DEBUG (1): Marked Battery voltage as published
[16:02:15.088] DEBUG (1): Marked Networklink address as published
[16:02:15.124] DEBUG (1): Marked Networklink strength as published
[16:02:15.146] DEBUG (1): Marked Temperature as published
[16:02:15.165] DEBUG (1): Marked Fire as published
[16:02:15.183] DEBUG (1): Marked Battery low as published
[16:02:15.201] DEBUG (1): Marked Battery voltage as published
[16:02:15.221] DEBUG (1): Marked Networklink address as published
[16:02:15.241] DEBUG (1): Marked Networklink strength as published
[16:02:15.264] DEBUG (1): Marked Temperature as published
[16:02:15.283] DEBUG (1): Marked Fire as published
[16:02:15.301] DEBUG (1): Marked Battery low as published
[16:02:15.321] DEBUG (1): Marked Battery voltage as published
[16:02:15.350] DEBUG (1): Marked Networklink address as published
[16:02:15.373] DEBUG (1): Marked Networklink strength as published
[16:02:15.394] DEBUG (1): Marked Temperature as published
[16:02:15.412] DEBUG (1): Marked Motion as published
[16:02:15.431] DEBUG (1): Marked Tamper as published
[16:02:15.451] DEBUG (1): Marked Battery defect as published
[16:02:15.492] DEBUG (1): Marked Battery low as published
[16:02:15.510] DEBUG (1): Marked Battery voltage as published
[16:02:15.530] DEBUG (1): Marked Networklink address as published
[16:02:15.550] DEBUG (1): Marked Networklink strength as published
[16:02:15.568] DEBUG (1): Marked Temperature as published
[16:02:15.589] DEBUG (1): Marked Motion as published
[16:02:15.618] DEBUG (1): Marked Tamper as published
[16:02:15.644] DEBUG (1): Marked Battery defect as published
[16:02:15.672] DEBUG (1): Marked Battery low as published
[16:02:15.713] DEBUG (1): Marked Battery voltage as published
[16:02:15.731] DEBUG (1): Marked Networklink address as published
[16:02:15.760] DEBUG (1): Marked Networklink strength as published
[16:02:15.781] DEBUG (1): Marked Temperature as published
[16:02:15.802] DEBUG (1): Marked Contact as published
[16:02:15.826] DEBUG (1): Marked Tamper as published
[16:02:15.858] DEBUG (1): Marked Battery low as published
[16:02:15.879] DEBUG (1): Marked Battery voltage as published
[16:02:15.899] DEBUG (1): Marked Networklink address as published
[16:02:15.921] DEBUG (1): Marked Networklink strength as published
[16:02:15.940] DEBUG (1): Marked Temperature as published
[16:02:15.958] DEBUG (1): Marked Gateway as published
Her er litt info :
RauchWohn homely Fire (binary_sensor.rauchwohn_homely_fire)
MQTT discovery data:
Topic: homeassistant/binary_sensor/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/fire/config
Payload
device:
  identifiers:
    - edeffb64-fac3-4f02-845e-6f5ea98bdb0f
  sw_version: 1
  model: Intelligent Smoke Alarm
  manufacturer: Homely
  hw_version: 1
  suggested_area: Floor 1 - Wohnzimmer
unique_id: edeffb64-fac3-4f02-845e-6f5ea98bdb0f_fire
device_class: smoke
unit_of_measurement: null
state_class: null
command_topic: null
config_topic: homeassistant/binary_sensor/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/fire/config
availability_topic: homeassistant/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/online
state_topic: homeassistant/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/fire/state
platform: mqtt
Subscribed topics:
7 most recently received message(s)
0 most recently received message(s)
Som du ser, de kommer aldri en message ang. 'fire/state'
howi skrev (4 timer siden):
Ikke noen config message på fire her heller, kanskje den som stopper videre import av enheter? Hvordan får jeg fjernet alle enheter og legge de til på nytt?
Finner config under home-assistant, ingen under Homely topic.
Endret av SumMarius
Utfyllende info
howi skrev (11 timer siden):
Når jeg tester dette, sletter jeg alle enheter i HA og starter imagen på nytt.
Har nå fått testet. Stopper opp etter å ha lagt inn Brannvarsler.
Ser på MQTT Explorer at den ikke legger inn fire som sensor på HA. Den ligger i Homely
Endret av SumMarius
Litt mer info :
Alle mine devices er der, inkludert hjemmesentralen ( den rekken i midten , fra ede ........ til  465......).
Bare 4 devices i containeren blir til en device i HA ( de 4 under binary_sensor), til de kommer det også config-messages
3 dukker opp under sensor ( helt oppe ), også med config-messages
Det ser ut til å være for mange publiseringer på en gang, slik at et eller annet dropper resten. Dersom jeg fikser entities/create-entities-mqtt.js slik at den faktisk tester på hvorvidt en entitet er publisert før eller ei så kan jeg i sqlite-fila skru av published-flagget for en og en device (to virket også) og så ramler de inn uavhengig av type. Så om koden endres til å publisere med litt delay mellom hver så tipper jeg det fungerer bedre.
OK
OK
Det kan gi mening ja. Muligens ett problem med mqtt-brokeren som sliter e.l? Jeg har skrevet ett lass med tester lokalt der alt virker fint, og når jeg publiserer hos meg virker alt greit, men jeg har en veldig over-specced server. Kan prøve å få lagt inn en delay på det, og eventuelt se om jeg har en måte å verifisere mottak/lest på ett vis.
Jeg finner ingen system med disse problemene.
HA kjører på en enkelt NUC, som har lite å gjøre, ifølge målingene.
Docker image kjører enten på en PI3 eller en dualcore Intel system, resultat er det samme.
Alltid de samme 4 enhetene dukker opp som devices i HA, alle andre kan jeg se i MQTT Explorer, men de kommer aldri med en config message.
Kjører jeg kolaf sin integrasjon, dukker alle røykvarslerne opp ( ikke Heat Sensor ) , men ingenting annet.
Ja, jeg sier ikke at det er det som skjer, bare at det kan hende. En annen tanke er om noe annet plukker opp meldingen. Tidligere har jeg kjørt entity-oppretting med qos = 2 som betyr at en melding kan leses nøyaktig 1 gang. Bygget ut nytt image nå som gjør to ting:
- Setter qos = 1
- Har en forsinkelse på 300ms mellom publisering av hver entitet, noe som bør være plenty tid til at det plukkes opp 🙂
Forhåpentligvis så ordner det problemene noen av dere har opplevd.
  • 4 uker senere...
@gert, jeg sliter med "invalid time value" som du tidligere opplevde. Dette skjer når jeg gjør et forsøk på å spinne opp en docker-container på en annen server enn min opprinnelige (fungerende) Unraid-container.
Forstod du hvorfor du fikk denne meldingen?
For min del kan jeg ikke si noe om det, men vil gjerne bemerke to ting.
Containeren er hos meg utrolig stabil, virker som en drøm.
Homely fortalte meg at det vil komme en stor oppdatering slutten av mars, uten at jeg vet, hva den vil inneholder.
BalleClorin skrev (På 19.3.2024 den 15.58):
@Ronniehl, kanskje du har en formening om hva som skjer her? 🙂 Jeg får altså følgende feilmelding når jeg forsøker å kjøre i gang en container i Portainer på en annen maskin enn den fungerende containeren i Unraid (som fungerer som en drøm):
[13:20:19.173] ERROR (1): Invalid time value
err: {
"type": "RangeError",
"message": "Invalid time value",
"stack":
RangeError: Invalid time value
at Date.toISOString (<anonymous>)
at Authentication.<anonymous> (/app/dist/homely/auth.js:39:94)
at Generator.next (<anonymous>)
at fulfilled (/app/dist/homely/auth.js:5:58)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
err: {
"stack":
Sorry, fikk ikke med meg denne tidligere. Virker som noe feil med respons fra homely (jeg slacka visst med feilhåndteringen der). Bygger en ny versjon nå med noe feilhåndtering, kan du teste den og se om det funker? Publiseres nå, så klar om ca 5 min. 🙂
Haha, er vel ingen som forventer at du overvåker forumet og plukker opp alt som dukker opp. Ei heller leverer 5 minutters-fixer på påskeaften. Tusen takk! 🙂
Under kommer den egentlige årsaken til feilen. Tolker det slik at token tilhører "gammel" økt/container?
[15:40:15.449] ERROR (1): body used already for: https://sdk.iotiliti.cloud/homely/oauth/token
err: {
"type": "TypeError",
"message": "body used already for: https://sdk.iotiliti.cloud/homely/oauth/token",
"stack":
TypeError: body used already for: https://sdk.iotiliti.cloud/homely/oauth/token
at Response.consumeBody (/app/node_modules/node-fetch/lib/index.js:344:30)
at Response.json (/app/node_modules/node-fetch/lib/index.js:269:22)
at Authentication.<anonymous> (/app/dist/homely/auth.js:62:36)
