mk1 black limited
VIP
Alt skrevet av mk1 black limited
  1. Ehrmmm...(min utheving i rødt): A new feature is launching on your Echo device: Amazon Sidewalk. Amazon Sidewalk is a shared network that helps devices work better. For example, if your device loses its wifi connection, Sidewalk can simplify reconnecting to your router and help set up new Echo devices. Sidewalk can also extend the coverage for Sidewalk-enabled devices, such as Ring smart lights and pet and object trackers, so they can stay connected and continue to work over longer distances. When enabled, Sidewalk uses a small portion of your Internet bandwidth to provide these services to you and your neighbors. This setting will apply to all of your supported Echo and Ring devices that are linked to your Amazon account. Learn more about Amazon Sidewalk. Sidewalk is coming to your Echo device later this year, but you can disable this feature at any time from the Amazon Alexa app. To disable this feature, follow these instructions. You must have the latest version of the Alexa app on your phone to proceed. Click the appropriate link below on your mobile device to get the latest version: iOS Android To open the Alexa app, tap Open. Or tap Install or Update, then Open when complete. Sign into your Amazon account, if prompted. Tap More > Settings > Account Settings > Amazon Sidewalk. Turn Sidewalk off. Disablet i mine innstillinger allerede, men noe å følge med på kanskje.
  2. Jada, men når z-waveplugin plutselig finner en node som den selv setter navn på hjelper jo ikke det?
  3. Ja, fant den jeg også. Skal se på den litt nærmere.
  4. Ja, jeg tenkte det, men så kan det jo hende det er noder jeg faktisk har og bruker (hadde vært fint med en mulighet til å søke i eventer som ikke virker lenger fordi devicen ikke finnes lenger...), men det oppdager jeg vel etter hvert. Med 70+ noder så er det ikke så lett å huske alle sammen
  5. Måtte reinkludere en Danalock som hadde falt ut av nettet etter å ha stått strømløs en god stund (merkelig, men det er en annen sak). Når den var lagt inn og alt var bra fortsatte loggen med dette: nov-15 12.13.26 Z-Wave Getting Z-Wave node list for network xxx. nov-15 12.13.26 Z-Wave Found 75 Z-Wave nodes nov-15 12.13.26 Z-Wave Syncing Z-Wave nodes with device list... nov-15 12.13.27 Z-Wave Synchronize nodes finished. Number of device nodes to be created/added = 2 nov-15 12.13.27 Z-Wave Device synchronization needs to get Z-Wave class information for 2 nodes. Litt merkelig, men ser at alle er eksisterende batterinoder bortsett fra 126 og 127. Disse er nå lagt inn i HS som Z-Wave Node 126 Sigma Switch og Z-Wave Node 127 Sigma Switch. Og hvor kom disse fra og hva i all verden er de? Ikke klarer jeg å huske om jeg hadde disse i det hele tatt før heller. Arghh...
  6. Øh, kjørte en Audit node og så remove bad node - da gikk det bra.
  7. Kom du i mål med dette @Erling? Har samme problem etter at en Telldus strømbryter tok kvelden: xxx: Node 6 was not removed because the interface xxx does not have that node in its memory. (It may already be removed.) Remove bad node fungerer altså ikke: Node 6 was not removed from any interface in the system, it may still be communicating or function aborted. Restart av z-wave plugin hjelper ikke.
  8. Jeg hadde vel egentlig mest lyst til å installere fra bunn av for å ha kontroll på alt, men jeg kan jo prøve imaget også.
  9. Noen som har (funnet) en guide som inneholder alt man trenger for å legge inn HS4 på Raspberry Pi? Homeseer har lagt ut en guide som mangler mye...f.eks. den litt essensielle delen om hvordan man får lagt inn lisenskode (!). Jeg fikk installert det, og det virket inntil jeg la inn noen Z-wave enheter, etter det vil den ikke starte opp mer...:( Og en ting til - var det slik at det var en egen versjon for Pi? Og en annen for Linux generelt? Jeg tror jeg la inn den for Linux i så fall.
  10. Ny Miele@home-eier, løfter denne tråden for å se om det har kommet noe nytt Ser det er litt å hente på en integrasjon som finnes til Home Assistant, men lite til Homeseer enda ser det ut til?
  11. Ja, den ene slår den andre i hjel i denne sammenheng. Kunne godt tenkt meg å slippe spamming av z-wavenettet mens vaskemaskinen går.
  12. Tenker på wattforbruk. Den rapporterer for ofte, men ja, bare når det den er koblet til er i bruk. Brukes på vaskemaskin her
  13. Noen flere som har denne: http://manuals-backend.z-wave.info/make.php?lang=en&sku=GOAEZMNHYD1&cert= Sliter med at den rapporterer forbruk 'hele tiden'. Har prøvd å sette parameter 42 til 60, men det har ingen synlig effekt...
  14. Huk av for In HS Device Value og Number kanskje?
  15. Der var den på plass i HS:
  16. Da kom den endelig Superenkel å installere - nå er det bare å få den inn i Homeseer, heldigvis er det en plugin til det...:)
  17. OK, men det hadde vel funket dårlig å sette DC-spotter på AC?
  18. Dårlig med trekkerør gitt (dvs det er nok trekkerør fra bryter opp til taket og kanskje til trafoene), og det er uaktuelt å ta ned taket nå. Så lenge vi snakker 12V er det vel DC? Både gamle 12v glødepærer og 12v LED virker jo, det er driverne som ikke takler for liten belastning sånn jeg ser det? Ingen trafo å finne i 'spotkassene', og de sitter fast i isolasjonen så det er umulig å komme til der også.
  19. Ikke mulig uten å åpne taket
  20. Kunne tenkt meg en sånn - vi har ikke så mange dører som er lukket egentlig.
  21. Hadde samme problem med at EgiGeozoneBT ikke kjørte i bakgrunnen, derfor jeg skiftet til Tasker, men den er ikke helt stødig den heller. Kanskje man må gå tilbake til iPhone...
  22. I taket på kjøkkenet vårt har forrige eier vært så snill at han har lukket taket slik at det er umulig å få tak i trafoene som er brukt for å gi strøm til 6 stk 12v spotter. Jeg har byttet ut spottene som satt der med Gledopto Zigbee LED-spotter. Dessverre ser det ikke ut til at trafoene takler dette, da spottene flimrer veldig. Setter jeg inn en vanlig glødepære (altså bytter ut en av LED-pærene pr trafo) flimrer det ikke. Er det noe jeg kan sette inn mellom trafo og pærer som gjør at jeg kan bruke LED-pærene mine? Litt teit å bare kunne slå av eller dimme fire av seks pærer...:)
  23. Jeg ga opp beacons på Android, gikk over til å bruke Tasker sin Location-funksjon i stedet (som er mer ustabil og litt for treg til å oppdatere). Nå har jeg også satt opp WiFi near i tasker, ser om den er bedre enn Location.
  24. OK? Fortell mer
