Får inkludert denne fint i HS, men hvis jeg forsøker å endre setpoint i HS så skjer det ingenting på termostaten.
Hvis jeg endrer på termostaten så oppdaterer det seg i HS.
Har forsøkt å eksludere og inkludere flere ganger, både som secure og non-secure.
Har testet termostaten mot Futurehome og der fungerer det fint å endre setpoint.
Kjører siste versjon HS4 og testet både med legacy z-wave, z-wave 4 og siste beta plugin.
Logg fra inkludering (ingen feilmeldinger)
26.12.2022 18:45:10    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat System Notification Set to NOTIFICATION for type System Notification, Event: System Hardware Failure OEM Failure Code, Failure Codes: 0
26.12.2022 18:45:09    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat Access Control Notification Set to NOTIFICATION for type Access Control Notification, Event: Closed
26.12.2022 18:45:07    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat Heating Setpoint Set to Setpoint 21 (C)
26.12.2022 18:45:06    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat kW Hours Set to 1,14 (1,14 kW Hours)
26.12.2022 18:45:06    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat Cooling Setpoint Set to Setpoint 20 (C)
26.12.2022 18:45:05    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat Mode Set to Mode v1_Heat
26.12.2022 18:45:04    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat Power Management Notification Set to NOTIFICATION for type Power Management Notification, Event: Power Applied
26.12.2022 18:45:03    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat Switch Set to ON
26.12.2022 18:45:03    Legacy-Plugin    Z-Wave    Device: Node 19 Z-Wave Thermostat Temperature Set to 19 (C)
26.12.2022 18:44:23    Legacy-Plugin    Z-Wave    13 out of 14 Child devices of node 19 were created successfully.
26.12.2022 18:44:23    Legacy-Plugin    Z-Wave    Adding Node 19 Z-Wave Thermostat Watts as an Energy tracking device.
26.12.2022 18:44:23    Legacy-Plugin    Z-Wave    Adding Node 19 Z-Wave Thermostat kW Hours as an Energy tracking device.
26.12.2022 18:44:22    Legacy-Plugin    Z-Wave    Node 19 Z-Wave Thermostat supports having its date/time set. Current TimeZone is Vest-Europa (normaltid) with a UTC offset of 1h, 0m and a Current UTC time of 26.12.2022 17:44
26.12.2022 18:44:22    Legacy-Plugin    Z-Wave    Getting association information for Node 19 Z-Wave Thermostat
26.12.2022 18:44:22    Legacy-Plugin    Z-Wave    Assigning return route from node 1 to Node 19 Z-Wave Thermostat
26.12.2022 18:44:21    Legacy-Plugin    Z-Wave    UZB1: Adding association for Z-Wave device Node 19 Z-Wave Thermostat (Node 19, Group 1) to HomeSeer
26.12.2022 18:44:21    Legacy-Plugin    Z-Wave    Root Node Device Node 19 Z-Wave Thermostat was created for node 19 on network E8EB3851
26.12.2022 18:44:21    Legacy-Plugin    Z-Wave    All associations for node 19 have been retrieved successfully, it supports associations on these groups: 1.
26.12.2022 18:44:21    Legacy-Plugin    Z-Wave    Node 19 Association Group 1 can have 5 associations, and currently has 0
26.12.2022 18:44:21    Legacy-Plugin    Z-Wave    Getting association information for node 19
26.12.2022 18:44:21    Legacy-Plugin    Z-Wave    Node 19 Supports Thermostat Setpoint CC and supports these setpoints: Heating 1, Cooling 1
26.12.2022 18:44:21    Legacy-Plugin    Z-Wave    Node 19 Supports Thermostat Mode CC and supports these modes: Off, Heat, Cool
26.12.2022 18:44:20    Legacy-Plugin    Z-Wave    Node 19 Supports 3 Notification Types: Access_Control Power_Management System
26.12.2022 18:44:19    Legacy-Plugin    Z-Wave    Node 19 Meter is Supported for Electric_meter, Type ELECTRIC_A, Scale is INSTANT
26.12.2022 18:44:19    Legacy-Plugin    Z-Wave    Node 19 Meter is Supported for Electric_meter, Type ELECTRIC_V, Scale is INSTANT
26.12.2022 18:44:19    Legacy-Plugin    Z-Wave    Node 19 Meter is Supported for Electric_meter, Type ELECTRIC_W, Scale is INSTANT
26.12.2022 18:44:19    Legacy-Plugin    Z-Wave    Node 19 Meter is Supported for Electric_meter, Type ELECTRIC_kWh, Scale is ACCUMULATED
26.12.2022 18:44:19    Legacy-Plugin    Z-Wave    Node 19 is a Z-Wave Plus node.  Retrieving ZWPlus Info...
26.12.2022 18:44:19    Legacy-Plugin    Z-Wave    Node 19 is Z-Wave version: Lib: 7,16 App: 10.22
26.12.2022 18:44:18    Legacy-Plugin    Z-Wave    Z-Wave manufacturer information for node 19, ID: 1080=438H (UNKNOWN), Type: 4=4H, ID: 264=108H
26.12.2022 18:44:15    Legacy-Plugin    Z-Wave    Done. Node 19 Added.
  • 2 måneder senere...
hmmm skrev (4 timer siden):
Hei.
fant du ut av dette? har samme problemet
Nei, kom ikke noe lenger, så endte opp med å kjøre programmer lokalt på termostat. Vet ikke hvem problemet ligger hos, om det er programvaren i termostaten eller z-wave plugin til HS.
Lagt inn unsecure ja. prøvde på nytt nå.
samme som Actibus, HS oppdaterer value når jeg stiller fysisk på termostaten, men ikke omvendt.
av og på styrt fra HS funker også.
så kan vel bruke temperaturdevicen og styre bryteren fra HS kanskje ?
men 13 av 14 child devicer? kan det bety noe rart?
Add Node started...
Activate the 'Add to Network' function on the device...
A new node is being added...
Adding a new SLAVE NODE...
DONE - Add Node Operation is Complete.
Done. Node 49 Added.
Reloading (importing) node information...
Synchronizing node information with HomeSeer and creating new device(s) as necessary...
Synchronize nodes finished. Number of device nodes to be created/added = 1
Z-Wave manufacturer information for node 49, ID: 1080=438H (UNKNOWN), Type: 4=4H, ID: 264=108H
Node: 49 Supports Class(es): VERSION, ZWAVEPLUS_INFO, ASSOCIATION, MULTI_INSTANCE_ASSOCIATION, ASSOCIATION_GRP_INFO_V2, TRANSPORT_SERVICE, DEVICE_RESET_LOCALLY, MANUFACTURER_SPECIFIC_V2, SWITCH_BINARY, SENSOR_MULTILEVEL_V8, PROTECTION, METER_V2, NOTIFICATION_V6, CONFIGURATION, THERMOSTAT_MODE_V3, THERMOSTAT_OPERATING_STATE_V2, THERMOSTAT_SETPOINT, TIME, TIME_PARAMETERS, INDICATOR, POWERLEVEL, SUPERVISION, FIRMWARE_UPDATE_MD
Node 49 is Z-Wave version: Lib: 7,16 App: 10.22
Node 49 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node 49 Supports 3 Notification Types: Access_Control Power_Management System
Access_Control Supports Events: Open(22), Closed(23)
Power_Management Supports Events: Power Applied(1)
System Supports Events: System Hardware Failure OEM Failure Code(3)
Node 49 Supports Thermostat Mode CC and supports these modes: Off, Heat, Cool
Node 49 Supports Thermostat Setpoint CC and supports these setpoints: Heating 1, Cooling 1
All associations for node 49 have been retrieved successfully, it supports associations on these groups: 1.
Root Node Device Node 49 Z-Wave Thermostat was created for node 49 on network F6E18D88
AEOTEC: Adding association for Z-Wave device Node 49 Z-Wave Thermostat (Node 49, Group 1) to HomeSeer
13 out of 14 Child devices of node 49 were created successfully.
Finished.
Saving network information to file: Network F6E18D88_F6E18D88_2023-03-10_15.12.01.nodes. Please wait...
Done!
hmmm skrev (13 minutter siden):
... hvordan ser controllerne ut? De var akkurat ikke med i screenshot'et ditt.
Det ser jo ikke ut til å være noen grunn til at det ikke skal fungere. Hvis du endrer verdien på Heating Setpoint til 23 og trykker submit så skjer det ingenting?
status endres i HS, men ikke på termostaten. den slår heller ikke ut/inn om jeg går over/under aktuell temperatur.
stiller jeg opp eller ned fysisk på termostaten endres status i HS.
Jeg testet som sagt termostat mot futurehome og der fungerer å endre set point, så heller mot noe i HSs implementering eller at namron bruker en eller annen utenfor normalt konfigurering?
Kan det være samme surret som er med z-trm3?  nedgradering av fw osv? var vel noe desimaler der
ser i manualen at det står reprot istedefor report. aner ikke om det betyr noe
Actibus skrev (På 10.3.2023 den 16.22):
Begge deler kan være en problemstilling....
Korrekte navn på disse konstantene er:
- THERMOSTAT_MODE_REPORT_MODE_HEAT
- THERMOSTAT_MODE_REPORT_MODE_COOL
Dette er nok bare en skrivefeil og bør ikke ha noe å si. ThermostatMode har forøvrig ingenting med ThermostatSetpoint å gjøre (bortsett fra at setpoint påvirker når termostat er på / av).
Endret av OlavT
  • 9 måneder senere...
Fant dere ut av dette? Har akkurat samme problem med to stykk Z-TRM6 i HS. Får ikke endret setpunkt fra HS, men det oppdateres andre veien.
Lagt til unsecure, har siste versjon av Z-wave plugin. Virker jo å være et generelt problem HomeSeer har med termostater...?
Z-TRM6 er Heatit, ikke Namron. Er en egen tråd om dette og Heatit sine termostater her ett sted.
Z-TRM3 måtte ha FW oppdatering for å fungere.
