Moskus Skrevet 15. november 2017 Del Skrevet 15. november 2017 Lar deg sette en vilkårlig device som Root med vilkårlige devicer som Child Devices. Parameter: RooTID|child1ID,child2ID,etc Sub Main(ByVal params As String) Dim lines() As String = params.ToString.Split("|") Dim rootRef As Integer = lines(0) Dim children() As String = lines(1).Split(",") Dim rootDevice As Scheduler.Classes.DeviceClass = hs.GetDeviceByRef(rootRef) rootDevice.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Parent_Root Dim childDevice As Scheduler.Classes.DeviceClass For Each c As Integer In children childDevice = hs.GetDeviceByRef(c) rootDevice.AssociatedDevice_Add(hs, c) childDevice.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Child childDevice.AssociatedDevice_Add(hs, rootRef) Next End Sub 1 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
