Homeseer helt DØ????
mr.rs4
Det vet jeg ikke , men skulle tro det.
Restartet HS og nå jobber på spreng ligger på 45-70% og oppi 300mb++ minne bruk. Og HS starter ikke opp i chrome
Log:
Spoiler
28.01.2019 12.37.36 ~!~Startup~!~Settings Loaded.
28.01.2019 12.37.36 ~!~Startup~!~********************************************************************************
28.01.2019 12.37.36 ~!~Startup~!~            HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
28.01.2019 12.37.36 ~!~System~!~Ending plug-in process HSPI_ZWave
28.01.2019 12.37.36 ~!~Startup~!~Creating Class Objects...
28.01.2019 12.37.36 ~!~Startup~!~COM port classes started.
28.01.2019 12.37.36 ~!~Startup~!~Application interface class started.
28.01.2019 12.37.36 ~!~Startup~!~Web server class started.
28.01.2019 12.37.36 ~!~Startup~!~E-Mail SEND class started.
28.01.2019 12.37.36 ~!~Startup~!~E-Mail RECEIVE class started.
28.01.2019 12.37.36 ~!~Startup~!~Plug-In Interface class started.
28.01.2019 12.37.36 ~!~Startup~!~HSPhone external interface class started.
28.01.2019 12.37.36 ~!~Startup~!~Local voice recognition class started.
28.01.2019 12.37.36 ~!~Startup~!~Database SAVE process started.
28.01.2019 12.37.36 ~!~Startup~!~Loading configuration file ...
28.01.2019 12.37.36 ~!~Database~!~Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
28.01.2019 12.37.36 ~!~Database~!~Loading Devices...
28.01.2019 12.37.36 ~!~Load Config~!~65 total devices loaded.
28.01.2019 12.37.36 ~!~Load Config~!~Loading Event Groups...
28.01.2019 12.37.36 ~!~Load Config~!~Loading Events...
28.01.2019 12.37.36 ~!~Load Config~!~4 total events loaded.
28.01.2019 12.37.36 ~!~Load Config~!~Loading COUNTERS...
28.01.2019 12.37.36 ~!~Load Config~!~Loading TIMERS...
28.01.2019 12.37.36 ~!~Startup~!~HomeSeer version is: 3.0.0.435
28.01.2019 12.37.36 ~!~Startup~!~Creating Speaker Client Interface Object...
28.01.2019 12.37.36 ~!~Startup~!~Initializing phone interface...
28.01.2019 12.37.36 ~!~HSPhone~!~HomeSeer Phone Web Interface initializing.
28.01.2019 12.37.36 ~!~Startup~!~This version of HomeSeer is registered as a HS3PRO version.
28.01.2019 12.37.36 ~!~Error~!~Unable to start plug-in API: Only one usage of each socket address (protocol/network address/port) is normally permitted
28.01.2019 12.37.36 ~!~Startup~!~Checking for available plug-ins
28.01.2019 12.37.36 ~!~Plug-In~!~Found plug-in: JowiHue, version: 2.0.2.8
28.01.2019 12.37.37 ~!~Plug-In~!~Found plug-in: MyQ, version: 1.2018.717.1011
28.01.2019 12.37.37 ~!~Plug-In~!~Found plug-in: RFXCOM, version: 30.0.0.37
28.01.2019 12.37.37 ~!~Plug-In~!~Found plug-in: HSZigBee, version: 3.0.1.7
28.01.2019 12.37.37 ~!~Plug-In~!~Found plug-in: Z-Wave, version: 3.0.1.249
28.01.2019 12.37.37 ~!~Startup~!~Initializing Plug-Ins
28.01.2019 12.37.37 ~!~Plug-In~!~Finished initializing plug-in Z-Wave
28.01.2019 12.37.37 ~!~HSTouch Server Error~!~Exception in client listener: Only one usage of each socket address (protocol/network address/port) is normally permitted restarting...
28.01.2019 12.37.37 ~!~Startup~!~HStouch server started, waiting for clients to connect.
28.01.2019 12.37.37 ~!~Web Server~!~Local IP address (subnet) is: 192.168.120.115 (255.255.255.0)
28.01.2019 12.37.37 ~!~Web Server~!~Web Server started on port 8088
28.01.2019 12.37.37 ~!~Warning~!~Error starting web server, port in use? Are you running a web server on the designated port? Edit settings.ini in the Config folder and change gWebSvrPort=## to a different port #. Only one usage of each socket address (protocol/network address/port) is normally permitted
28.01.2019 12.37.37 ~!~Warning~!~Web Server Stopped
28.01.2019 12.37.37 ~!~Startup~!~Creating ASP.NET application host...
28.01.2019 12.37.37 ~!~Startup~!~Start automation engine...
28.01.2019 12.37.37 ~!~Startup~!~Initializing Speaker Client Interface
28.01.2019 12.37.38 ~!~HSTouch Server Error~!~Exception in client listener: Only one usage of each socket address (protocol/network address/port) is normally permitted restarting...
28.01.2019 12.37.38 ~!~Error~!~Unable to start remote speech API: Only one usage of each socket address (protocol/network address/port) is normally permitted
28.01.2019 12.37.38 ~!~Speech~!~Listening for remote speaker connections on port 10401
28.01.2019 12.37.38 ~!~Database~!~Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
28.01.2019 12.37.38 ~!~Startup~!~Updater services starting...
28.01.2019 12.37.38 ~!~Startup~!~Starting Find service...
OK. Første du skal lære nå er at du skal ta backup av HS3-mappen din med jevne mellomrom. :)
Deretter må vi begynne å finne ut av hva du har gjort.
Steng HS3, og kverk alle plugin'er som måtte kjøre.
Gå til HS3\Data\Z-wqave (dvs. her: C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave) og slett Z-wave2.dB.
Prøv så å starte opp på nytt.
Hvis ikke det går begynner jeg å gå seriøst tom for idéer...
Ser jo ut som den går i evig løkke når den prøver å starte hs touch server?
Hvilken port lytter hs touch server vanligvis på? Hvis du kverker Homeseer og prøver å telnette til samme port, får du da connected?
telnet localhost NN (NN er portnummer)
Ja backup ja. Får en ny og bedre z-wave usb om 1 dag eller 3.
Tenkte bare at dette er en "øvelse" og starter på ny.
Men med slike happenings er det greit å lære litt av(der av back up og). Men det tenkte jeg skulle gjøre etter nye z-wave usb plug in.
Alt nå ser jeg som en læring, der jeg HAR FÅTT VELDIG MYE HJELP IFRA DERE?
Setter stor pris på det?
Det kan kanskje være eit tips å ikkje begynne med Z-wave, Ikea/Zigbee og 433 MHz på ein gang - da er sjansen nokså stor for at noko for skeis enda ein gang!
Som det står i HS-skolen (som du vel har lest til punkt og prikke?) så er BLBackup blant dei aller første plugins du bør installere og sette skikkeleg opp med event før du legg alt for mykje energi i det andre ?
Startet opp NUC igjen, etter å ha stått av et par timer.
Forsøker å ta vekk en node(Fibaro bevegelse sensor), og får dette til svar:
Please wait...
Error, the Remove Node from Network response object is null and a normal ending was not reported - Remove Node failed.
Error: Error, the Remove Node from Network response object is null and a normal ending was not reported - Remove Node failed.
Reloading (importing) node information...
Getting Z-Wave node list for network CBE00046...
Found 9 Z-Wave nodes
Syncing Z-Wave nodes with device list...
Synchronize nodes finished. Number of device nodes to be created/added = 1
Node: 6 Supports Class(es): ZWAVEPLUS_INFO, VERSION, MANUFACTURER_SPECIFIC_V2, SENSOR_BINARY, CONFIGURATION, NOTIFICATION_V6, DEVICE_RESET_LOCALLY, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, BATTERY, WAKE_UP, POWERLEVEL
Node 6 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Error: Node 6 did not provide Wake-Up Command Class information - it will not be processed further.
Warning: The device at node 6 should result in 2 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
Så det er tydligvis en feil med denne Node nr6, som skal være den Fibaro Strips sensor, som jeg skulle sette opp sist. Så det er ihvertfall en feil rundt den en plass. Øverst på Home.
Bilde av Home
Spoiler
Endret av mr.rs4
Ja det var kanskje et par ting som var galt.....
Hva er det å gjøre med det?
Enklest å slette alt å legge inn på ny? Må en remove/exclude devices på alt da?
Spoiler
Loading network information from your Z-Wave interface...
Done.
Synchronizing network information against HomeSeer devices...
Synchronize nodes finished. Number of device nodes to be created/added = 0
Node: 2 Supports Class(es): ZWAVEPLUS_INFO, APPLICATION_STATUS, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, CONFIGURATION, CRC_16_ENCAP, DEVICE_RESET_LOCALLY, FIRMWARE_UPDATE_MD, MANUFACTURER_SPECIFIC_V2, METER_V2, MULTI_INSTANCE_ASSOCIATION, NOTIFICATION_V6, POWERLEVEL, SECURITY, SENSOR_MULTILEVEL_V8, SWITCH_BINARY, VERSION
Node: 2 Supports Secure Class(es): ASSOCIATION, CONFIGURATION, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, MULTI_INSTANCE_ASSOCIATION, SWITCH_BINARY, VERSION
Node 2 is Z-Wave version: Lib: 4,24 App: 3.2
Node 2 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 3 Supports Class(es): ZWAVEPLUS_INFO, BASIC_V2, VERSION, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, ASSOCIATION_GRP_INFO_V2, ASSOCIATION, POWERLEVEL, WAKE_UP, BATTERY, NOTIFICATION_V6, CRC_16_ENCAP, CONFIGURATION, SENSOR_MULTILEVEL_V8, MULTI_INSTANCE_ASSOCIATION, APPLICATION_STATUS, SENSOR_BINARY, SENSOR_ALARM, SECURITY, FIRMWARE_UPDATE_MD
Node: 3 Supports Secure Class(es): BASIC_V2, DEVICE_RESET_LOCALLY, ASSOCIATION, WAKE_UP, NOTIFICATION_V6, MULTI_INSTANCE_ASSOCIATION, CONFIGURATION, SENSOR_BINARY, SENSOR_ALARM
Node 3 is Z-Wave version: Lib: 4,05 App: 3.2
Node 3 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 4 Supports Class(es): ZWAVEPLUS_INFO, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, APPLICATION_STATUS, BATTERY, CONFIGURATION, CRC_16_ENCAP, DEVICE_RESET_LOCALLY, FIRMWARE_UPDATE_MD, MANUFACTURER_SPECIFIC_V2, MULTI_INSTANCE_ASSOCIATION, NOTIFICATION_V6, POWERLEVEL, SECURITY, SENSOR_MULTILEVEL_V8, VERSION, WAKE_UP
Node: 4 Supports Secure Class(es): ASSOCIATION, CONFIGURATION, DEVICE_RESET_LOCALLY, MANUFACTURER_SPECIFIC_V2, MULTI_INSTANCE_ASSOCIATION, NOTIFICATION_V6, VERSION, WAKE_UP
Node 4 is Z-Wave version: Lib: 4,38 App: 3.2
Node 4 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 7 Supports Class(es): ZWAVEPLUS_INFO, APPLICATION_STATUS, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, CONFIGURATION, CRC_16_ENCAP, DEVICE_RESET_LOCALLY, FIRMWARE_UPDATE_MD, MANUFACTURER_SPECIFIC_V2, METER_V2, MULTI_INSTANCE_ASSOCIATION, NOTIFICATION_V6, POWERLEVEL, SECURITY, SENSOR_MULTILEVEL_V8, SWITCH_BINARY, VERSION
Node: 7 Supports Secure Class(es): ASSOCIATION, CONFIGURATION, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, MULTI_INSTANCE_ASSOCIATION, SWITCH_BINARY, VERSION
Node 7 is Z-Wave version: Lib: 4,24 App: 3.2
Node 7 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 8 Supports Class(es): ZWAVEPLUS_INFO, APPLICATION_STATUS, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, CONFIGURATION, CRC_16_ENCAP, DEVICE_RESET_LOCALLY, FIRMWARE_UPDATE_MD, MANUFACTURER_SPECIFIC_V2, METER_V2, MULTI_INSTANCE_ASSOCIATION, NOTIFICATION_V6, POWERLEVEL, SECURITY, SENSOR_MULTILEVEL_V8, SWITCH_BINARY, VERSION
Node: 8 Supports Secure Class(es): ASSOCIATION, CONFIGURATION, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, MULTI_INSTANCE_ASSOCIATION, SWITCH_BINARY, VERSION
Node 8 is Z-Wave version: Lib: 4,24 App: 3.2
Node 8 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 9 Supports Class(es): ZWAVEPLUS_INFO, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, APPLICATION_STATUS, BATTERY, CONFIGURATION, CRC_16_ENCAP, DEVICE_RESET_LOCALLY, FIRMWARE_UPDATE_MD, MANUFACTURER_SPECIFIC_V2, MULTI_INSTANCE_ASSOCIATION, NOTIFICATION_V6, POWERLEVEL, SECURITY, SENSOR_MULTILEVEL_V8, VERSION, WAKE_UP
Node: 9 Supports Secure Class(es): ASSOCIATION, CONFIGURATION, DEVICE_RESET_LOCALLY, MANUFACTURER_SPECIFIC_V2, MULTI_INSTANCE_ASSOCIATION, NOTIFICATION_V6, VERSION, WAKE_UP
Node 9 is Z-Wave version: Lib: 4,38 App: 3.2
Node 9 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 10 Supports Class(es): ZWAVEPLUS_INFO, BASIC_V2, VERSION, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, ASSOCIATION_GRP_INFO_V2, ASSOCIATION, POWERLEVEL, WAKE_UP, BATTERY, NOTIFICATION_V6, CRC_16_ENCAP, CONFIGURATION, SENSOR_MULTILEVEL_V8, MULTI_INSTANCE_ASSOCIATION, APPLICATION_STATUS, SENSOR_BINARY, SENSOR_ALARM, SECURITY, FIRMWARE_UPDATE_MD
Node: 10 Supports Secure Class(es): BASIC_V2, DEVICE_RESET_LOCALLY, ASSOCIATION, WAKE_UP, NOTIFICATION_V6, MULTI_INSTANCE_ASSOCIATION, CONFIGURATION, SENSOR_BINARY, SENSOR_ALARM
Node 10 is Z-Wave version: Lib: 4,05 App: 3.2
Node 10 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node 2 Supports 1 Notification Types: Power_Management
Power_Management Supports Events: Over Current Detected, Over Load Detected
Error: Node 3 did not provide Wake-Up Command Class information - it will not be processed further.
Error: Node 4 did not provide Wake-Up Command Class information - it will not be processed further.
Node 7 Supports 1 Notification Types: Power_Management
Warning: Node 8 did not respond to the Notification Supported request.
Error: Exception creating Sensor Multilevel child device of node 8, GET for supported sensor types indicated failure.
Error: Node 9 did not provide Wake-Up Command Class information - it will not be processed further.
Error: Node 10 did not provide Wake-Up Command Class information - it will not be processed further.
All associations for node 2 have been retrieved successfully, it supports associations on these groups: 1, 2, 3.
6 out of 6 Child devices of node 2 were created successfully.
11 out of 11 Child devices of node 3 were created successfully.
7 out of 7 Child devices of node 4 were created successfully.
Enabling instant status for Z-Wave device Hoved Etg Gang Fibaro Switch - Hoved Dør (7) on Group 2
Enabling instant status for Z-Wave device Hoved Etg Gang Fibaro Switch - Hoved Dør (7) on Group 3
6 out of 6 Child devices of node 7 were created successfully.
Enabling instant status for Z-Wave device Hoved Etg Gang Fibaro Switch - Test (8) on Group 2
Warning: Instant status for Z-Wave device Hoved Etg Gang Fibaro Switch - Test (8) on Group 2 failed. Please rescan this device when communications are working better to try again.
Enabling instant status for Z-Wave device Hoved Etg Gang Fibaro Switch - Test (8) on Group 3
Warning: Instant status for Z-Wave device Hoved Etg Gang Fibaro Switch - Test (8) on Group 3 failed. Please rescan this device when communications are working better to try again.
6 out of 6 Child devices of node 8 were created successfully.
7 out of 7 Child devices of node 9 were created successfully.
11 out of 11 Child devices of node 10 were created successfully.
Finished with Z-Wave device synchronization.
Skal prøve igjen, men denne gangen skal jeg trykk på bryterne
EDIT
Ser ut som det fungere igjen, uten at jeg vet helt hva som har gjort hva....
Men lurer på å slette den enkle Node som ligger igjen, og er det "greit" å gjøre det slik?
Spoiler
Den sliter enda med Node6
Spoiler
Endret av mr.rs4
Slik ser det ut nå, selv om ting ser ut som det fungere nå...
Skal jeg forsatt slette noe?
Ja, skal nok få opp en type plug in først ja. Og ta back up først.
Får en slik i morgen(love posten) Z-Wave.Me USB Stick og tenkte å ta back up på alt da. Mener jeg leste en plass at denne var best(iforhold til den z-wave stivk jeg har nå - Aeon Labs Z-stick gen5 USB-adapter), og med tanke på backup.
Det skal jeg og sjekke, og for å teste ut ?
De lærde strides om hvilken Z-Wave stick som er best, de fungerer alle sammen, men ingen EU-stick er optimal til HS. Hvis du får ny Z-Wave stick må du uansett starte nytt Z-Wave nettverk. Du har vært så plaget at hvis jeg var deg hadde jeg startet på nytt med fresh HomeSeer også. Les også igjennom HomeSeer skolen på nytt. Ikke stress med å få alt inn på en gang, ta en device av gangen og test at den fungerer slik den skal før du går videre. Det samme gjelder plugins, en om gangen.
Ja, det er det jeg og tenke. Denne gang var en "lærdom". Har ikke så stor nettverk enda, selv om det går en del tid. MEN det kommer til å bli en del større. Kan prøve å feile litt nå. Så skal jeg lese igjenom skolen på ny, lage back up plan, legge inn en plugin om gangen, og teste hver og enkelt ting.
Nå er det oppe og går, men ligger litt dobbelt opp i Event når jeg skal velge enheter.
Merkelig greier. Har ikke gjort så mye, men nå fungere alt helt 100%
Har nå fått til IKEA sine lys pærer, og laget en event med tid og bevegelse. Må teste med farge og så blir dette kanon bra.
Er usikker på hva en skal gjøre, slette alt eller ikke.
Får som sagt Z-Wave.Me USB Stick imorgen(om et par timer), har jo 90% Z-Wave produkter. + Fått til IKEA.
Men sliter litt med RFXcom, men det kan være pga ikke forstår helt hvordan lære opp HS. Har nå kjørt de gardinene til røyken står ut av de, for å prøve å lære både de og meg og HS....
En annen ting jeg lurer på, som kanskje kan ha forårsaket dette. Med f.eks Z-Wave, legger til / tar vekk devicer, jeg er for rask(les dum), og ser ikke at HS jobber, og skrur av PC / gjør andre ting osv, som ikke er bra....
Hvordan ser jeg HS jobber, og ikke må restarte eller gjøre "andre" ting som ikke er bra?
Vil så gjerna slippe dette igjen.
Ja, jeg har og nå lært meg back-up og har allerede kjørt den, og satt på daglig backup.
Nå fungere enda alt helt 100& og kan ikke se noe galt.
Men kantenkesdet er par senarioer:
1. Tar f.eks Z-Wave(siden det var den som var ustabil), legger til / tar vekk devicer, jeg er for rask(les dum), og ser ikke at HS jobber, og skrur av PC / gjør andre ting osv, som ikke er bra....
2. Har for lite RAM på NUC, med 8Gb ram. Skulle være nok, men når jeg er på en PC har jeg MANGE chrome sider oppe, som resultere i MYE ram forbruk.
På nr 1 skulle jeg ønsket å finne ut om det var den som forårsaket, kanskje kombinasjon med nr.2
På nr 2 må jeg ikke bruke for mange sider opp, evt kjøpe mer ram
Hva mener dere hva som kan forårsaket dette?
Avslutt HomeSeer og se i oppgavebehandling at både HomeSeer.exe og HSPI_* ikke kjører før du restarter. Har du automatisk Windows Updates og reboot? Det kan skape problemer.
Jeg ville brukt en annen PC til å administrere HomeSeer. Serveren ville jeg latt være bare en server.
