  1. I dag
  2. Jeg ble lei av å bytte batterier på mine Z-Wave bevegelsessensorer så jeg har laget en Matter over Thread Occupancy sensor basert på disse komponentene: https://wiki.dfrobot.com/SKU_SEN0610_Gravity_C4001_mmWave_Presence_Sensor_12m_I2C_UART https://www.silabs.com/development-tools/wireless/efr32xg26-explorer-kit?tab=overview Den får strøm fra USB-C og fungerer som router i Thread mesh nettverket.
  3. I går
  4. https://www.facebook.com/groups/449526166277051/
  5. Hei, Vet ikke om du har løst det, men jeg bruker ZHA, har satt opp denne blueprinten. https://github.com/theberzer/HA-blueprints/blob/main/Namron_switch_1_4512728.yaml
  6. Siste uke
  7. Hva landet dere på her? Funker det som beskrevet med 8V trafoen??
  8. Har en del slike liggende som jeg ikke trenger mer og selger de for en rimelig penge (50kr / stk + frakt). Kan brukes for å lage en OpenThread Border Router av en Raspberry PI etc. nRF52840 Dongle - nordicsemi.com The nRF52840 Dongle is a small, low-cost USB dongle that supports Bluetooth 5.4, Bluetooth mesh, Thread, Zigbee, 802.15.4, ANT and 2.4 GHz proprietary protocols. The Dongle is the perfect target hardware for use with nRF Connect for Desktop as it is low-cost but still support all the short range wireless standards used with Nordic devices. The dongle has been designed to be used as a wireless HW device together with nRF Connect for Desktop. For other use cases please do note that there is no debug support on the Dongle, only support for programming the device and communicating through USB. It is supported by most of the nRF Connect for Desktop apps and will automatically be programmed if needed. In addition custom applications can be compiled and downloaded to the Dongle. It has a user programmable RGB LED, a green LED, a user programmable button as well as 15 GPIO accessible from castellated solder points along the edge. Example applications are available in the nRF5 SDK under the board name PCA10059.
  9. Slik styres effekten på VVB for å ligge hårfint under grensen på et trinn på nettleie. Det har sine fordeler med å bruke en SSR og puls-bredde modulering av varmeelementet. Årsaken til svingninger er hovedsaklig varmekabler som også er puls-bredde modulert med en periodetid på 5 minutter.
  10. Fikk ikke noe særlig ut av det. Der skulle de koble det opp mot et annet system
  11. Jeg har en lås med nøkkel på på begge sider. Bildet viser innsiden. Den fikk jeg montert aquara u200 ganske enkelt ved å skru av øverste lag her og selv finne frem et par skiver til å feste aquara bakplate. Bakplaten til aquara måtte jeg bytte senterstykket med et medfølgende alternativt senterstykke. Det fungerte greit, men store deler aquara låsboks står et stykke fra selve døra. Fylte dette med medfølgende selvklebrende skumlapper. Det jeg sliter med er imidlertid å få paret med home assistant. Har en dedikert tread usb (skyconnect) som er jeg flashet med tread da jeg satte den i home assistant green. Men har ennå ikke klart å få paret den. Jeg har ikke aquara hub. men har en android og en iphone med home assistant app som jeg forsøker å få det til med.
  12. Får du til å styre laderen, start/stopp/hastighet? Futurehome hubben min er låst nå uten abb. Laderen står på ZigBee. Må kanskje fysisk resette laderen for å koble til WiFi?
  13. Takk! Jeg har lagt inn HAN og vvb-rele, funker fint i z2m. Får prøve meg på laderen....
  14. Ja, les mer her:
  15. Noen som har fått billaderen til å fungere i HA?
  16. For en ukes tid siden passerte jeg en milepæl med 50% inntjening på solcelleanlegget og forventet 100% inntjening i desember 2028. Det der med å beregne inntjening er ikke helt enkelt for forskjellige beregninger, som alle kan virke fornuftige, kan gi veldig forskjellige resultater. I dag bruker jeg "Reelt forbruk x timepris" minus "kjøpt strøm X timepris". Timepris er jo for inneværende time og selvsagt inkl. nettleie og alle avgifter. Forbruket fordeler seg jo rundt i døgnet på en naturlig måte og strømkjøp styres til de billigste timene så jeg tror denne beregningen er ganske reell.
  17. Pixel 7 Pro fikk skjermhavari og ved fix via forsikringen ble det oppgradering til Pixel 8 Pro og nå virker i alle fall GPS. /e/os har hatt litt trøbbel i versjon 3 (bl.a. Vipps virker bare nå og da) så nå har jeg kjørt GrapheneOS en måneds tid og det fungerer helt supert.
  18. Har du lest denne tråden? Kanskje du finner svaret der. https://community.home-assistant.io/t/tahoma-switch-integration-to-ha/642856/7
  19. Det snakkes fremdeles bare om timepris... https://radioh.no/haugaland-kraft-krever-endringer-i-norgespris-forslag/
  20. Smart Plug er ikke anbefalt for varmtvannsbereder på grunn av risiko for varmgang / brannfare. Aeotec Heavy Duty er en ok løsning basert på Z-Wave.
  21. Jeg har 2 stk Tahoma switch pga avstand til garasjen. Måtte ha en egen en i garasjen da jeg ikke fikk signal ned dit fra huset for å styre garasjeportene. Jeg har kjøpt enda en for å ha i huset, men klarer ikke å legge den inn i appen. Det står på nettet at man kan bare trykke på legg til hub, men den muligheten er ikke hos meg. Noen som vet hvordan jeg kan få til dette uten å ha to kontoer?
  22. Tusen takk for tips. Jeg skal sjekke opp disse.
  23. Det var litt mer komplekst enn jeg hadde sett for meg... 🙂 De nyeste vvb fra oso er jo forberedt for smart tilkobling ved å plugge inn en dings, så jeg antar det er et eller annet interface som det går an å innstille sett-temperaturen gjennom. Ingen som har sett hvilken protokoll som brukes der? Alternativt tror jeg bare jeg kombinerer avlesning av temperatur og strømpris med en smartplugg som styres fra HA. Burde gi nesten samme resultat, men med mindre lodding og kjøleribber... 🙂
  24. Her er min siste versjon av esphome kode. De største endringene er tellere for energi brukt og kostnad i kroner. substitutions: devicename: Varmtvannstank esphome: name: varmtvannstank on_boot: - priority: -100 then: - delay: 30s - homeassistant.event: event: esphome.boot data: message: "${devicename} Started" esp8266: board: esp01_1m restore_from_flash: false wifi: ssid: "HEIME5.ORG" password: !secret heime_wifi domain: .lan #captive_portal: # Enable logging logger: # Enable Home Assistant API api: reboot_timeout: 24h ota: platform: esphome script: - id: set_output mode: single then: - output.set_level: id: pwm_output level: !lambda |- double set_t = 10.0; if(id(varmtvannstank_modus).active_index() == 1) set_t = id(vvb_lav_temperatur).state; else if(id(varmtvannstank_modus).active_index() == 2) set_t = id(vvb_medium_temperatur).state; else if(id(varmtvannstank_modus).active_index() == 3) set_t = id(vvb_hoy_temperatur).state; id(vvb_skal_temperatur).publish_state(set_t); double diff_t = set_t - id(varmtvannstank_topp_temperatur).state; double diff_c = set_t - id(varmtvannstank_senter_temperatur).state; double diff_b = set_t - id(varmtvannstank_bunn_temperatur).state; if(diff_t > 1.0) { auto time_now = id(homeassistant_time).utcnow(); id(time_stop) = time_now.timestamp; id(energy_stop) = id(vvb_total_daily_energy).state; } double c = 0.00135 * set_t - 0.03839286; double v_t = diff_t + c; double v_c = diff_c / 20 + c; double v_b = diff_b / 50 + c; double v = min((id(effekt)/100.0), max(max(v_t, 0.0), max(v_c, v_b))); id(power).publish_state(v * 2.0); if(set_t > id(vvb_lav_temperatur).state) id(mode_last_changed).publish_state(id(homeassistant_time).now().timestamp); return v; globals: - id: last_value_from_ha type: int initial_value: '0' - id: effekt type: float restore_value: no initial_value: '100.0' - id: time_start type: float restore_value: no initial_value: '0.0' - id: energy_start type: float restore_value: no initial_value: '0.0' - id: time_stop type: float restore_value: no initial_value: '0.0' - id: energy_stop type: float restore_value: no initial_value: '0.0' number: - platform: template max_value: 100.0 min_value: 0.0 step: 1 mode: slider id: effekt_varmtvannsbereder name: effekt_varmtvannsbereder unit_of_measurement: '%' initial_value: 100 optimistic: true set_action: then: - lambda: |- id(effekt) = x; - script.execute: set_output - platform: template max_value: 90.0 min_value: 10.0 step: 5 mode: slider id: vvb_hoy_temperatur name: vvb_hoy_temperatur unit_of_measurement: '°C' initial_value: 80 restore_value: true optimistic: true - platform: template max_value: 90.0 min_value: 10.0 step: 5 mode: slider id: vvb_medium_temperatur name: vvb_medium_temperatur unit_of_measurement: '°C' initial_value: 65 restore_value: true optimistic: true - platform: template max_value: 90.0 min_value: 10.0 step: 5 mode: slider id: vvb_lav_temperatur name: vvb_lav_temperatur unit_of_measurement: '°C' initial_value: 45 restore_value: true optimistic: true i2c: sda: GPIO14 scl: GPIO4 scan: true status_led: pin: number: GPIO13 inverted: yes output: - platform: sigma_delta_output pin: 12 update_interval: 2.5s id: pwm_output state_change_action: - lambda: |- id(internalcost).publish_state(state ? 2.0 * id(current_energy_price).state : 0.0); sensor: - platform: homeassistant id: current_energy_price entity_id: pyscript.totalstrompris - platform: wifi_signal name: "${devicename} WiFi Signal" update_interval: 300s - platform: mcp9808 id: varmtvannstank_topp_temperatur name: "${devicename}_topp_temperatur" address: 0x1D filters: - sliding_window_moving_average: window_size: 5 send_every: 1 on_value: then: - script.execute: set_output - platform: mcp9808 id: varmtvannstank_senter_temperatur name: "${devicename}_senter_temperatur" address: 0x1E filters: - sliding_window_moving_average: window_size: 5 send_every: 1 on_value: then: - script.execute: set_output - platform: mcp9808 id: varmtvannstank_bunn_temperatur name: "${devicename}_bunn_temperatur" address: 0x1F filters: - sliding_window_moving_average: window_size: 5 send_every: 1 on_value: then: - script.execute: set_output - platform: total_daily_energy id: vvb_total_daily_energy name: "VVB Total Daily Energy" power_id: power restore: false method: left accuracy_decimals: 2 filters: - throttle: 60s - platform: integration name: "VVB Total Daily Cost" id: vvb_total_daily_cost sensor: internalcost state_class: "total_increasing" time_unit: h unit_of_measurement: "NOK" restore: false integration_method: left accuracy_decimals: 2 filters: - throttle: 60s - platform: template id: power name: "Effekt varmtvann" unit_of_measurement: "kW" icon: "mdi:power-plug" accuracy_decimals: 3 - platform: template id: vvb_skal_temperatur name: "VVB skal temperatur" unit_of_measurement: '°C' icon: "mdi:coolant-temperature" accuracy_decimals: 0 - platform: template id: internalcost unit_of_measurement: "NOK" update_interval: 1s accuracy_decimals: 6 internal: true - platform: template name: "${devicename}_modus_last_changed" device_class: timestamp id: mode_last_changed filters: - throttle: 708s - platform: template name: "${devicename}_heating_ratio" id: heating_ratio update_interval: never unit_of_measurement: 'W/Wmaks' accuracy_decimals: 2 interval: - interval: 2h then: - if: condition: - lambda: !lambda |- auto time_now = id(homeassistant_time).utcnow(); if(time_now.timestamp - id(last_value_from_ha) > 7200) return true; return false; then: - select.set: id: varmtvannstank_modus option: "Middels" time: - platform: homeassistant id: homeassistant_time timezone: "Europe/Oslo" on_time: - seconds: 0 minutes: 0 hours: 0 then: - sensor.integration.reset: vvb_total_daily_cost text_sensor: - platform: homeassistant id: watchdog entity_id: sensor.time on_value: then: - lambda: !lambda |- auto time_now = id(homeassistant_time).utcnow(); id(last_value_from_ha) = time_now.timestamp; select: - platform: template id: varmtvannstank_modus name: "${devicename}_modus" optimistic: true options: - Borte - Lav - Middels - Høy initial_option: Lav restore_value: true set_action: then: - lambda: !lambda |- if(x == "Middels" || x == "Høy") { auto time_now = id(homeassistant_time).utcnow(); id(time_start) = time_now.timestamp + 30.0; id(energy_start) = id(vvb_total_daily_energy).state; } else if(x == "Borte") { id(time_start) = 0.0; id(heating_ratio).publish_state(1.0); } else if(x == "Lav") { if(id(time_stop) > id(time_start) && id(time_start) > 0.0) { double de = id(energy_stop) - id(energy_start); double dt = id(time_stop) - id(time_start); double r = (de / dt ) * 1800; id(heating_ratio).publish_state(min(r, 1.0)); } else if(id(time_start) > 0.0) { id(heating_ratio).publish_state(1.0); } } binary_sensor: - platform: status name: "${devicename} Esp Status" button: - platform: restart name: "${devicename} Restart"
  25. Hei. Fikk du løsning på dette? Her er et forslag: Qubino 3-fas Smart Meter, med tilleggsmodul BICOM432. Sistnevnte er en kontaktor 32A som styres optisk fra Smart Meter. Kan også tilkobles en ekstra BICOM432 med ledninger, mener jeg, men det må sjekkes opp.
  26. For de som er litt handy, finnes det enkle og rimelige løsninger for avlesning av temperatur i beredere. På de nyere beredere fra i alle fall OSO, er hullet for målestaven til OSO, ordinært 1/2" gjengeparti. Min løsning er som følger: Har brukt en 1/2" ansatsnippel (innvendig diameter; 15mm), som er loddet sammen med et ordinært kobberrør 15mm (tilpasset rett lengde for min VVB), med loddesluttmuffe på enden. Rett montert på fiksen på tanken, vil dette gi en vanntett løsning. For måling av temperatur, har jeg DS18B20 vanntette fire sensorer med ledning, som er koblet på Fibaro Smart Implant. Sensorene er plassert i bunn, midten og nær topp. I tillegg har jeg en sensor på utgangsrøret fra berederen, for kontroll på varmtvannets temperatur etter blandeventil. Dette gir all den informasjon som trengs, for å bearbeide dette videre i egne systemer. DS18B20 koster jo veldig lite (jeg har mange liggende, hvis noen vil kjøpe). Smart Implant, er jo en mulighet, og er på ZWave. Det er mange andre muligheter, både innenfor Zigbee og WiFi. ESP32 er jo nevnt.
  27. Jeg har Amina S og det fungerer bra. Bruker den med Home Assistant og zigbee2mqtt. Litt tungvindt firmwareoppdatering, men nyeste versjon skal ha lagt til OTA som skal fungere med z2m så det er forhåpentlig løst.
  28. Enheten jeg bruker er en Sonoff dings som hadde rele. Jeg loddet av releet og har koblet til en kraftig SSR. Denne er montert på en kjøleribbe og det hele montert i en boks. Jeg kan ta noen bilder hvis det er interessant. Jeg har fagbrev og å lage slike til eget bruk er greit. Hvis noen her vil gjøre det samme, pass i det minste på at kjøleribbe er jordet godt og at den ikke blir for varm. Klarer en så vidt å ta på den er den rundt om 50 grader. SSR har optokobler på inngang så det er lett å få til galvanisk skille mellom lavspenning og 230V. SSR kobler inn og ut ved nullgjennomgang på spenningen og den er lydløs. Det siste var årsaken til at jeg bruker en SSR. Jeg hadde en kontaktor tidligere, men det ble for mye bråk av den. Selv når jeg ikke brukte pwm.
