  1. I går
  2. Hi, Typing in English because I do not speak Norwegian well enough 🙂 I do not like subscriptions and I switched from Futurehome to a Homey Pro. This is a hub which connects just like everything, runs locally, so no issue with cloud costs. Also no subscription. It connected all my devices in a few taps and I can make automations between different devices very easily. It all goes via the Homey App. It is sooooo much easier than Home Assistant. And I do not need to code or pay for remote access etc. Works like a charm and can highly recommend it. I got mine directly from their shop (it is a Dutch company btw). Just google Homey.
  3. Dette er ikke oppdatert med nyeste satser, men jeg legger ved hvordan jeg løste dette. Dette er basert på lnett sin nettleie. Dag/natt, vinter/ikke vinter osv. Kumulativt over et par mnd så fulgte det faktura +/- et par kroner. Legger følgende i en template helper. {% set spot = states('sensor.nord_pool_no2_current_price') | float(0.5) * 1.25 %} {% set provider_charge = 0.049 %} {% set grid_rent_high = 0.3871 %} {% set grid_rent_low = 0.3071 %} {% set energy_tax_high = 0.2055 %} {% set energy_tax_low = 0.1189 %} {% set enova_tax = 0.0125 %} {% set month = states("sensor.date_time_iso")[5:7] | int %} {% set time = states("sensor.date_time_iso").split("T")[1][:2] | int %} {% if spot > 0.9125 %} {% set spot = (spot - 0.9125) * 0.1 + 0.9125 %} {% endif %} {% set fixed_costs = (spot + provider_charge + enova_tax) | float(0) %} {% set energy_tax = energy_tax_high if 12 >= month >= 4 else energy_tax_low %} {% if (states("binary_sensor.workday_sensor") == "off") %} {% set grid_rent = grid_rent_low %} {% elif 22 > time >= 6 %} {% set grid_rent = grid_rent_high %} {% else %} {% set grid_rent = grid_rent_low %} {% endif %} {% set energy_price = (fixed_costs + grid_rent + energy_tax) | float %} {{energy_price}}
  4. Siste uke
  5. Jeg endte opp med å plassere det i templates.yaml da jeg ikke fikk det til å fungere i config. Men jeg har prøvd å finne ut av den nye nettleien fra 1.Juli... Hjelper ikke at Tensio (min netteier) skriver utydelig... De skriver: "Nettleie består av 3 deler." 1. Kapasitetstrinn maks kW (peak 3 timer fordelt på 3 dager, 5kW, 10kW trinn) 2. Energiledd pr kWt (som går til netteier, pr kWt forskjell dag og natt) (56,16 (39,29 natt)) 3. Offentlige avgifter som er forbruksavgift, merverdiavgift og ENOVA-avgift. (21,16+1,25) (april-oktober (?)) Spotpris + 56,16 + 21,16 + 1,25 = pris pr kWt = 78,57 øre kWt + spotpris Eller skriver Tensio feil (utydelig), at 3. offentlige, er inkludert i 2. energiledd? Akkurat som de skriver feil med at redusert forbruksavgifter er april-oktober? ... Sjekket Futurehome app, den viser 50 Sjekket strømleverandør, den viser 59,29 (trolig rett med påslag på spotpris) Sjekket BKK, den viser 59,86 inkl alt. (annen leverandør) Sjekket tidligere faktura = Energiledd er sum av Energiledd+Forbruksavgift+Energifond. Nye fra 1.Juli er 56,16 inkl alt. for 06-22. frem til 31.desember...
  6. Bestilte meg en sånn, så får vi se om jeg får den til å virke med portåpneren: https://www.aliexpress.com/item/1005005408244662.html?spm=a2g0o.order_list.order_list_main.5.21ef1802xugj4z
  7. Det er først og fremst en logisk feil i det du har skrevet. Den første if-else der en setter pris til 0.604 eller 0.420 vil aldri ha noen virkning fordi prisen blir satt til 0.122 eller 0.211 nedenfor. Og så tror jeg det er bedre å bruke additional_costs: >- {% if now().hour >=6 and now().hour <22 %} {{ 0.604 | float }} {% else %} {{ 0.420 | float }} {% endif %} {% if now().month >= 4 and now().month < 10 %} {{ 0.122 | float }} {% else %} {{ 0.211 | float }} {% endif %} Legg merke til >- Det betyr at det som kommer bak er en multilinje streng. Og linjen under additional_costs: >- må ha et innrykk. Det er yaml syntax Men som nevnt, du må først og fremst rydde opp i den logiske feilen med at det aldri blir satt noen natt eller dagpris. Det er et eksempel her: https://github.com/custom-components/nordpool?tab=readme-ov-file#additional-costs
  8. Kan jo tenkes at kortet jobber på 5V ettersom denne dingsen har USB-porter, og at det er en liten 3,3V regulator mellom Vcc og ESPen?
  9. Kom på en sak til som er verdt å nevne. Hvis noen har eldre utgaver av Deltaco SH-P03USB bør de vite om at den er listet som farlig produkt i 2020. De som selges i dag heter Deltaco SH-P03USB2 og er ikke rammet av den samme feilen. Leste en annen plass at ESP8266 ikke er oppgitt å tåle annet enn 3,3V, men noen hevdet at sjefen for ESP hadde sagt at 5V går helt fint. Det fungerer bra på denne enheten i alle fall. 🙂
  10. Interessant. Slo meg aldri. Det var kanskje grunnen til at jeg ikke lykkes å flashe med Vcc fra TTL-adapteret. Jeg jukset til slutt med å plugge i AC i stedet, men det er jo en småskummel løsning.
  11. Takk for fin oversikt, dette skulle jeg ha sett tidligere. 🙂 Beskrivelse av mindre inngripende metode for installasjon av ESPHome/Tasmota er postet i denne tråden.
  12. Denne er på salg igjen, laveste enhetspris jeg fant er hos Teknikkdeler til kr 111,- pluss 49, - i frakt. Ang installasjon av annen programvare (Tasmota eller ESPHome) har jeg gjort et par erfaringer jeg tror kan være til nytte for flere, selv om oppsett av denne enheter også er omtalt i denne tråden. Det er ikke nødvendig å åpne enheten helt, det holder å skru opp de to skruene (PZ1) under gummifoten i enden lengst fra ledningen. Plastikken er seig og myk nok til å tåle at man bøyer opp enten tilstrekkelig til å komme til for å plugge i Dupont kabler (hann til hun) i hullene som synes i enden av kortet. Rekkefølge fra yttersiden og innover: VCC - Ground - GPIO 0 - Rx - Tx. VCC kobles til 5v (ref BlitzWolf) ut på USB til TTL adapter, Ground til Ground, GPIO 0 skal kobles til jord ved oppstart (når USB kobles til PCen) og så fra igjen, Rx til Tx på TTL adapter og tilsvarende Tx til Rx. Når dette er klart åpnes https://web.esphome.io for å starte selve flasheprosessen. Det går fint i første trinn "Prepare for first use" som jeg får bekreftet fullført. Neste trinn feiler, men det viste seg etter litt undersøkelser at ikke betyr så mye. Dette trinnes skulle gitt tilgang til å velge Wifi nett for enheten. Restart enheten (plugg fra USB og koble til USB igjen) og søk etter Wifi nett fra en PC/Nettbrett/mobil. Da vil du finne et wifinett med navn som begynner på "esphome-web-". Koble til dette og du ledes til en webside der du kan konfigurere esphome med ditt Wifi og dermed få enheten inn i Home Assistant eller konfigurere alt direkte. I Home Assistant må den legges til i ESPHome Builder om du vil endre konfigurasjon på enheten videre derfra.
  13. Jeg har løst dette med en egen template sensor for nettleie, beskrevet i denne tråden. En slik template bør kunne brukes som input for additional cost i Nordpool.
  14. Har problemer... Koden som står på siden til integrasjonen, feiler også. Det fungerer ned til og med low_price_cutoff: Men additional_costs: feiler, ingen output... Her er det høyere pris på nettleie kwt mellom 06-22 på dagen. Og høyere pris på vinter. Kan være noe så dumt som et mellomrom eller et tegn. ChatGPT skriver om hele koden til noe helt annet, fikk ikke noe hjelp der. - platform: nordpool VAT: true currency: "NOK" price_in_cents: true region: "NO3" precision: 3 price_type: kWh low_price_cutoff: 0.95 additional_costs: " {% if now().hour >=6 and now().hour <22 %} {{ 0.604 | float }} {% else %} {{ 0.420 | float }} {% endif %} {% if now().month >= 4 and now().month < 10 %} {{ 0.122 | float }} {% else %} {{ 0.211 | float }} {% endif %}" Kan noen korrigere meg?
  15. Sjekk denne videoen, Simon pleier å være konkret og vise ting på en god måte.
  16. Ingenting skal inn i ZHA, ZHA slettes. Når Z2M er oppe å går korrekt (det er ikke lett å sette opp) Legges enhetene til der, der har de støtte.
  17. Takk for svar. Ok, da skal nok dette gå bra likevel 🙂 - Fikk lagt til FH relé for varmtvannstank uten problemer med ZHA - Fikk lagt til FH HAN-sensor. Må sjekke om den er korrekt. - Jobber med å finne ut hvordan jeg skal konfigurere zigbee2mqtt
  18. @The X har helt rett, så ikke gi opp @eathome. Og du finner mer forklaring på mye av dette i denne tråden. Fordelen med Home Assistant er at de aller fleste problemer lar seg løse. Det er nok ikke rett system for alle, men for de med litt teknisk interesse er alt mulig. Og skulle du angre på valget er det bare å selge HA utstyret og heller kjøpe Homey Pro. Koster mer men er litt enklere. Det er også omtalt i tråden i lenken over.
  19. Bra løsning om en kan ha lampe som kan ha toggle on/off
  20. Har byttet fra "Future"home til Ha både hos kunde og hos mine foreldre. Slapp av, pust. 😉 Alt du nevner går rett inn... HA Green + Nabu Casa SkyConnect. Sett opp som Z2M (zigbee2mqtt) Termostat, dimmer, bereder-puck og HAN sensor fungerer. 👌 HAN-sensor trenger trolig justering av volt og ampere avlesing, Watt og kWt har vært riktig.
  21. Gjorde ett bomkjøp med G5 dome. Klarer ikke kjenne igjen bilskilt på ønsket avstand. Vurderer å teste G6 Bullet, se om det er bedre
  22. TP-Link Tapo C325WB Wi-Fi, ColorPro Night Vision, 2K bilde, ca 1000kr Har AI og forteller på varslet om det er bil, person, dyr, e.l. Fargebilde på natten i mørket er magi for oss over 40år... 😛 Men finnes sikkert nyere og enda bedre kamera anno 2025. Pris gir pekepinn på kvalitet.
  23. Jeg var nok litt for rask til å forsøke å bytte. Jeg kjøpte meg HA green og solgte futurehome hub og røykvarsler før jeg sjekket litt grundigere og nå står jeg her med masse problemer dessverre 😕 Jeg har - to Futurehome hvite termostater som styrer varmekabler på bad og inngang. - Et futurehome rele for varmtvannstank - Et futurehome puck dimmer. - og forøvrig en han-sensor men den regnet jeg ikke med ville fungere. Og så begynner jeg å lese meg litt opp og det begynner å set ut som om det ikke er mulig å bruke mine Futurehome enheter lenger. Jeg ønsker i størst mulig grad å bruke zigbee. Spørsmålet mitt er om det bare er å finne frem lommebok og bytte ut FH termostater, relé og puck med noe som er mer åpent mot HA?
  24. Har ikke noen direkte anbefaling annet enn å sjekke litt reviews på nettet, men et 4k fargekamera kanskje? Samletest av et utvalg her.
  25. Har vært en del hendelser utenfor huset vårt/i nabolaget i det siste, så nå ønsker jeg kamera utenfor som gir god bildekvalitet hele døgnet. Har alt Neste ringeklokke, men det gir ikke god nok kvalitet på video. Må klare å vise folk, bilskilt osv på minst 8 meter avstand. Noen gode tips til valg av kamera?
  26. Jeg tror vi har misforstått hverandre litt her. Begrepene som brukes kan tolkes forskjellig, nettopp derfor det er bra med oppklarende spørsmål og kommentarer. Jeg ønsket å få frem at kun bruk av smarte lyspærer og trådløse knapper vil medføre risiko for at automasjoner ikke fungerer hvis noen har skrudd av den fysiske lysbryteren. Dette er jo det enkleste å starte med da man ikke trenger elektriker. Du kan evt bruke en returfjær i stedet for tape, beskrevet i denne tråden.
  27. Takk til dere alle sammen 👍🏼 Ble godt svar på mitt spørsmål. Jeg har allerede smart pære med vanlig bryter i tillegg til Zigbee bryter og det går jo på ved strømbrudd om vanlig bryter står på og Zigbee har skrudd den av. Og er vanlig bryter skrudd av forblir det mørkt 😏 Skal nå prøve en Shelly pille for en led stripe som har kun vanlig av på bryter. Pilla skal kobles på lavvolt siden så det er lovlig for oss ikke sertifiserte 😇 Den vil få det omtalte problemet over, men det kan evt fikses med en teip på bryteren i på stilling. Det forstår mine andre i husholdningen som ikke er interessert i smarte løsninger 😂
