Primært 2G & 5G. Men hadde vært moro og fått til 6G også. Hva er problemene rundt 6G? Noen tips? Slet veldig med å finne pin-out på header i dag, når jeg fant ut av det så var klokka blitt litt for mye. Har et lite håp om å bli ferdig i morgen og å få testet det. -
Skal du bruke 6G eller bare 2G og 5G? Det er noen måneder siden jeg oppdaterte OpenWRT, men det har dessverre ikke skjedd noe med problemene rund 6G ... -
const fz = require("zigbee-herdsman-converters/converters/fromZigbee"); const tz = require("zigbee-herdsman-converters/converters/toZigbee"); const exposes = require("zigbee-herdsman-converters/lib/exposes"); const reporting = require("zigbee-herdsman-converters/lib/reporting"); const e = exposes.presets; const ea = exposes.access; module.exports = [ { zigbeeModel: ["4512759"], model: "4512759", vendor: "Namron", description: "Zigbee thermostat 16A (variant of 4512758)", fromZigbee: [ fz.thermostat, fz.metering, fz.electrical_measurement, ], toZigbee: [ tz.thermostat_local_temperature, tz.thermostat_occupied_heating_setpoint, tz.thermostat_local_temperature_calibration, tz.thermostat_system_mode, tz.thermostat_running_mode, tz.thermostat_control_sequence_of_operation, ], exposes: [ e.climate() .withLocalTemperature() .withSetpoint('occupied_heating_setpoint', 0, 40, 0.5) .withLocalTemperatureCalibration(-10, 10, 1) .withSystemMode(['off', 'heat']) .withRunningState(['idle', 'heat']), e.binary('child_lock', ea.ALL, 'LOCK', 'UNLOCK') .withDescription('Enables/disables physical input on the device'), e.switch(), e.power(), e.current(), e.energy(), ], configure: async (device, coordinatorEndpoint, logger) => { const endpoint = device.getEndpoint(1); await reporting.bind(endpoint, coordinatorEndpoint, [ 'genBasic', 'genIdentify', 'hvacThermostat', 'seMetering', 'haElectricalMeasurement', ]); await reporting.thermostatTemperature(endpoint, {min: 0, change: 50}); await reporting.thermostatOccupiedHeatingSetpoint(endpoint); await reporting.thermostatKeypadLockMode(endpoint); await reporting.currentSummDelivered(endpoint); await reporting.activePower(endpoint); await endpoint.read('hvacThermostat', [ 'systemMode', 'runningMode', 'occupiedHeatingSetpoint', ]); device.powerSource = 'Mains (single phase)'; device.save(); }, }, ]; I den nyeste Z2M versjonen må filene med konvertere ligge i en mappe "external_converters" som ligger under "zigbee2mqtt" mappen. Nå fungerer det å endre temperatur, samt å sett termostaten i off eller heat. Lenger har jeg ikke kommet. Om du finner ut mer, så oppdater gjerne i denne tråden 🙂
- 420 svar
Har forsøkt å søke uten hell, men jeg har kommet over denne siden der Mill sine Matter-sertifiseringer er listet. Jeg har en Mill konvektor gulvovn gen 3, og om jeg forstår det rett så er ikke denne sertifisert for Matter? Søk på Google svarer at "joda, den er klar", men jeg får ikke til koblingen. Om den ikke er sertifisert så har jeg to spørsmål: er sertifisering av konvektorovner i pipeline? om de skal være klare så er det muligens en mangel i appen, er dette i så tilfelle en kjent feil?
@DOS @Michael Seitz Takk for god hjelp og oppfølging. Har fått den opp nå. Måtte bruke litt makt og må leve med noen knekte klips. Ser ut som den er såpass i orden at det skal gå fint å sette den sammen igjen (forhåpentligvis). - Siste uke
Jeg tok en titt på min router og så at side-dekselet faktisk har flere plastdingser som passer inn i motstykker på sideveggen. Det er nok det som gjør det vanskelig å klemme sammen side-dekslet. Ja, du må komme deg mellom klips og nippelen med et verktøy. -
DOS svarte på autoTorbjørn sitt emne i Annen Elektronikk
Om jeg husker er det enklere å begynne fra bunnen og jobbe seg oppover. Og så trenger du 2 verktøy… -
Hm, det er nok den eneste veien å gå ... altså å klemme klipsene innover. Kanskje funker det som vist på bildet. Prøv å klemme side-dekslet innover på en side, og å bøye side-veggen utover med en skrutrekker eller en tykk (og sløv!) kniv. Det er lettere å klemme inn side-dekslet i midten og ved foten fordi toppen er forsterket med ekstra plast. Du ser jo på de bildene til Bjørn og Torbjørn hvor de fire klipsene er. Lykke til 🙂 -
Hei, ref tidlig i denne tråden så er det noen bilder som viser 4 klips på hver side, Det nytter ikke å få klemt den inn får å klips til løsne, eller dratt det fra hverandre. -
CF6 svarte på CF6 sitt emne i Automasjonskaféen
Dere har nok veldig rett, folkens. Mange takk! Står det noe i NEK700 om krav til klargjøring av infrastruktur i boliger mtp. elkom? -
Disse er solgt. -
Tass ble medlem
Det er lenge siden jeg åpnet min router. Kunne kanskje du laste opp bilder som viser hvor langt du har kommet og hvilken klips du ikke får av? -
Nick1 begynte å følge Nordic Semiconductor nRF52840 Dongle selges
Hei Olav Har du forsatt nRF52840 Dongle til salgs? Kjøper gjerne 2 stk for 100kr + frakt
Nick1 ble medlem
Flere HAN-lesere på samme port?
christbj svarte på OlavT sitt emne i Strømsparing og strøm-overvåkning
Det går helt fint. Har en Easee Equalizer og en Tibber Puls koblet på samme port med en enkel RJ45 splitter. En av dem må forsynes med strøm direkte, f.eks fra en gammel mobillader.- 1 svar
OlavT begynte å følge Flere HAN-lesere på samme port?
Noen som har testet å koble til 2 HAN-lesere på samme HAN-port? Det skal vel i teorien kunne fungere siden det er en bus?
Jepsh begynte å følge Z-TRM3 kan ikke identifiseres
Z-TRM3 har plutselig ingen info tilgjengelig i Z-Wave JS (Home Assistant). Jeg har forsøkt å re-interview, exclude, include osv, men samme resultat. Enheten kommer bare opp unknown som på bilde. Alt info var korrekt tidligere. Noen som vet hvordan man får den til å fungere riktig igjen?
KennethN ble medlem
Stains ble medlem
Hei, Har lest gjennom denne tråden nå utallige ganger og jeg er ganske ny på dette. Så gi meg litt slack for evt feil her 😅 Sitter her med Zyxel EX5700 og prøver å få av plastikk "chassiet". Har sett på bilder postet av @autoTorbjørn, men jeg har ikke nubbkjangs til å få av klips, har heller ikke lyst til å fikle med antennene i toppen. Har fått av toppen. Bunnen måtte jeg knekke av festene til foten. Har klart å delvis få opp et klips eller to på hver side i toppen. - Utover dette så sliter jeg veldig. Noen tips? Evt bilder? -
ekomloven gjelder definitivt også privatpersoner. "virksomhet" er nok her å forstå som "aktiviteter". Det er bare å lese videre i § 1-2. Absolutt ikke fritt fram for privatpersoner å bruke alt mulig av radiofrekvenser f.eks, og dette er loven som begrenser det Men som storeulv påpeker så gjelder kapittel 2 bare tilbydere, definert i § 1-5 som Det kan altså også væe en fysisk person. Men normalt tilbyr ikke folk slike tjenester til andre fra sine hjemmenettverk- 5 svar
Det er jeg helt enig i, og det bekreftes i lovens innledning: «§ 1-2.Saklig virkeområde Loven gjelder virksomhet knyttet til elektronisk kommunikasjon og tilhørende utstyr og datasentre.» Privatpersoner er ikke virksomheter. -
