Ruud Skrevet 7. februar 2019 Skrevet 7. februar 2019 Hei. Jeg har noe av de samme problemene. Mine deviser har ikke oppdatert seg siden 20. januar. Kun devisen "Verisure status" som har oppdatert seg senest i dag med den passende teksten OK Jeg leger ved utdrag fra meg også om du trenger å titte på litt flere i helga ? Startup log: (utdrag) 07.02.2019 20.51.11 ~!~Startup~!~Settings Loaded. 07.02.2019 20.51.11 ~!~Startup~!~ 07.02.2019 20.51.11 ~!~Startup~!~******************************************************************************** 07.02.2019 20.51.11 ~!~Startup~!~ HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now 07.02.2019 20.51.11 ~!~Startup~!~******************************************************************************** 07.02.2019 20.51.11 ~!~Startup~!~ 07.02.2019 20.51.12 ~!~Load Config~!~511 total devices loaded. 07.02.2019 20.51.12 ~!~Load Config~!~Loading Event Groups... 07.02.2019 20.51.12 ~!~Load Config~!~Loading Events... 07.02.2019 20.51.12 ~!~Load Config~!~226 total events loaded. 07.02.2019 20.51.12 ~!~Load Config~!~Loading COUNTERS... 07.02.2019 20.51.12 ~!~Load Config~!~Loading TIMERS... 07.02.2019 20.51.12 ~!~Startup~!~HomeSeer version is: 3.0.0.435 07.02.2019 20.51.14 ~!~Plug-In~!~Found plug-in: LSoftVerisure, version: 2.6.293.0 07.02.2019 20.51.21 ~!~Startup~!~Initializing Plug-Ins 07.02.2019 20.51.23 ~!~Plug-In~!~Finished initializing plug-in LSoftVerisure 07.02.2019 20.51.23 ~!~Plug-In~!~Finished initializing plug-in MQTT 07.02.2019 20.51.23 ~!~Info~!~Plugin LSoftVerisure has connected. IP:127.0.0.1:50892 07.02.2019 20.51.23 ~!~Info~!~Plugin MQTT has connected. IP:127.0.0.1:50894 07.02.2019 20.51.23 ~!~Starting Plug-In~!~Initializing plugin LSoftVerisure ... 07.02.2019 20.51.23 ~!~LSoftVerisure~!~LSoftVerisure plugin initializing 07.02.2019 20.51.24 ~!~LSoftVerisure~!~C:\Program Files (x86)\HomeSeer HS3 07.02.2019 20.51.24 ~!~LSoftVerisure~!~Debug:False 07.02.2019 20.51.24 ~!~LSoftVerisure~!~LogToFile:False 07.02.2019 20.51.24 ~!~Starting Plug-In~!~Plugin LSoftVerisure started successfully in 624 milliseconds 07.02.2019 20.51.26 ~!~LSoftVerisure Error~!~System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync.(WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) 07.02.2019 20.51.26 ~!~LSoftVerisure Error~!~{"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} 07.02.2019 20.51.26 ~!~LSoftVerisure Error~!~Finner ikke devices for lokasjon Åsheimgrenda 07.02.2019 20.51.27 ~!~Plug-In~!~Finished initializing plug-in TibberSeer Endret til debug: Log (utdrag) feb-07 21.18.29 LSoftVerisure Error Finner ikke devices for lokasjon Åsheimgrenda feb-07 21.18.29 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-07 21.18.29 LSoftVerisure Error System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync.   (WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) feb-07 21.18.29 LSoftVerisure Debug Funnet 1 lokasjoner feb-07 21.18.28 LSoftVerisure Debug Henter lokasjoner feb-07 21.18.28 LSoftVerisure Debug Login utført feb-07 21.18.28 LSoftVerisure Debug Logger inn f feb-07 21.17.30 LSoftVerisure Error Finner ikke devices for lokasjon Åsheimgrenda feb-07 21.17.30 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-07 21.17.30 LSoftVerisure Error System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync.   (WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) feb-07 21.17.29 LSoftVerisure Debug Funnet 1 lokasjoner feb-07 21.17.28 LSoftVerisure Debug Henter lokasjoner feb-07 21.17.28 LSoftVerisure Debug Login utført feb-07 21.17.28 LSoftVerisure Debug Logger inn feb-07 21.16.29 LSoftVerisure Error Finner ikke devices for lokasjon Åsheimgrenda feb-07 21.16.29 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-07 21.16.29 LSoftVerisure Error System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync.   (WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) feb-07 21.16.28 LSoftVerisure Debug Funnet 1 lokasjoner feb-07 21.16.28 LSoftVerisure Debug Henter lokasjoner feb-07 21.16.28 LSoftVerisure Debug Login utført feb-07 21.16.28 LSoftVerisure Debug Logger inn feb-07 21.15.37 LSoftVerisure Debug Generate html for Åsheimgrenda feb-07 21.15.37 LSoftVerisure Debug GenSettings, link:html/LSoft/Verisure/settings.htm parms: feb-07 21.15.29 LSoftVerisure Error Finner ikke devices for lokasjon Åsheimgrenda feb-07 21.15.29 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-07 21.15.29 LSoftVerisure Error System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync.   (WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) feb-07 21.15.28 LSoftVerisure Debug Funnet 1 lokasjoner feb-07 21.15.28 LSoftVerisure Debug Henter lokasjoner feb-07 21.15.28 LSoftVerisure Debug Login utført feb-07 21.15.28 LSoftVerisure Debug Logger inn feb-07 21.14.29 LSoftVerisure Error Finner ikke devices for lokasjon Åsheimgrenda feb-07 21.14.29 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-07 21.14.29 LSoftVerisure Error System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync.   (WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) feb-07 21.14.28 LSoftVerisure Debug Funnet 1 lokasjoner feb-07 21.14.28 LSoftVerisure Debug Henter lokasjoner feb-07 21.14.28 LSoftVerisure Debug Login utført feb-07 21.14.28 LSoftVerisure Debug plugin last timer run:01.01 00.00 feb-07 21.14.28 LSoftVerisure Debug Logger inn feb-07 21.14.28 LSoftVerisure Debug plugin state:True feb-07 21.14.28 LSoftVerisure Debug Timer state:True feb-07 21.13.29 LSoftVerisure Error Finner ikke devices for lokasjon Åsheimgrenda feb-07 21.13.29 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-07 21.13.29 LSoftVerisure Error System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync.   (WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) feb-07 21.13.28 LSoftVerisure Debug Funnet 1 lokasjoner feb-07 21.13.28 LSoftVerisure Debug Henter lokasjoner feb-07 21.13.28 LSoftVerisure Debug Login utført feb-07 21.13.28 LSoftVerisure Debug Logger inn feb-07 21.12.29 LSoftVerisure Error Finner ikke devices for lokasjon Åsheimgrenda feb-07 21.12.29 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-07 21.12.29 LSoftVerisure Error System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync.   (WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) Siter
Kenneth Skrevet 8. februar 2019 Forfatter Skrevet 8. februar 2019 Hmm, i dag ser det ut som feilmld er borte.. Siter
torhaala Skrevet 8. februar 2019 Skrevet 8. februar 2019 Hei, Prøvte å oppgradere fra 2.2 til 2.6 idag, men får denne feilmeldingen? Initializing plug-in(2): LSoftVerisure Instance::Could not resolve type with token 01000023 from typeref (expected class 'Verisure.StartStatus' in assembly 'Verisure, Version=2.6.283.0, Culture=neutral, PublicKeyToken=null')STACK: Server stack trace: Exception rethrown at [0]: at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.InitIO(string) at Scheduler.clsHSPI.CheckInterfaces () [0x000c4] in <4466e08c7a6c46068e3ccd83aaf1bbac>:0 Kjører HS3 på en Hometroller SEL - Mono 5+ installert, noen som har noen ide hva som er feil? Siter
lilfire Skrevet 8. februar 2019 Skrevet 8. februar 2019 Har ikke hatt noe linux maskin kjørende her hjemme så siste versjon er ikke testet på linux men endringene som er gjort burde ikke ha knekt den. Skal forsøke å sette opp en linux maskin snart for testing Siter
jmoen Skrevet 10. februar 2019 Skrevet 10. februar 2019 (endret) Hei. Testet Beta, men på Linux, så kanskje ikke beste kandidat slik sett ? Den funker (etter å ha endret path i HSPI_LSoftVerisure.exe.config fra \ til / ) og jeg får opp komponenter med verdier som jeg kan lage events på, men får også feilmeldinger som følger: 08:52:32:7908:[LSoftVerisure Error]->Feil ved opprettelse av database kobling 2/10/2019 8:52:32 PM: Feil ved opprettelse av database kobling 2/10/2019 8:53:31 PM: XX data hentet 08:53:31:0384:[LSoftVerisure]->XX data hentet 08:53:31:6454:[LSoftVerisure Error]->Feil ved opprettelse av database kobling 2/10/2019 8:53:31 PM: Feil ved opprettelse av database kobling 2/10/2019 8:54:31 PM: XX data hentet 08:54:31:1116:[LSoftVerisure]->XX data hentet 08:54:31:7364:[LSoftVerisure Error]->Feil ved opprettelse av database kobling 2/10/2019 8:54:31 PM: Feil ved opprettelse av database kobling Feb-10 10:54:36 PM LSoftVerisure Error System.DllNotFoundException: SQLite.Interop.dll at (wrapper managed-to-native) System.Data.SQLite.UnsafeNativeMethods.sqlite3_config_none(System.Data.SQLite.SQLiteConfigOpsEnum) at System.Data.SQLite.SQLite3.StaticIsInitialized () [0x0001d] in :0 at System.Data.SQLite.SQLiteLog.Initialize () [0x00000] in :0 at System.Data.SQLite.SQLiteConnection..ctor (System.String connectionString, System.Boolean parseViaFramework) [0x00021] in :0 at System.Data.SQLite.SQLiteConnection..ctor (System.String connectionString) [0x00000] in :0 at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteConnection..ctor(string) at Verisure.VerisureSync. (System.String ) [0x00000] in :0 at Verisure.VerisureSync.GenPage (System.String link) [0x005fc] in :0 og den fortsetter slik med sutring over database kopling. Merk at dette er en helt ny installasjon. Eller virker alt ok på mitt lille anlegg. -J- Endret 10. februar 2019 av jmoen Siter
lilfire Skrevet 11. februar 2019 Skrevet 11. februar 2019 (endret) Hmm, linux er ikke min sterkeste side desverre. Den feilmeldinga der indikerer jo at den benytter feil path for sqllite. Antar det er denne linjen du endret? <probing privatePath="Bin\LSoft\Verisure" /> Og du har denne path og fila "System.Data.SQLite.dll" liggende der? Og den er versjon 104? Endret 11. februar 2019 av lilfire Siter
GO_Nilsen Skrevet 11. februar 2019 Skrevet 11. februar 2019 På 10.2.2019 den 11.17, lilfire skrev: Ny BETA klar LSoftVerisure Får ikke linken til å virke. Sliter med at det ikke kommer opp noen devicer. Bare den som heter Verisure status: OK Kjører 2.6.293.0 Får feilmelding: feb-11 21.38.29 LSoftVerisure Error Finner ikke devices for lokasjon XXXXXXXXXXXX feb-11 21.38.29 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-11 21.38.29 LSoftVerisure Error System.Net.WebException: The remote server returned an error: (503) Server Unavailable. at System.Net.HttpWebRequest.GetResponse() at Verisure.VerisureSync.(WebRequest ) at Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) Siter
tonlof Skrevet 11. februar 2019 Skrevet 11. februar 2019 Hej, får följande fel med senaste betan. Har provat flera användarnamn och användarkontona fungerar felfritt på mypages. Feb-11 21:30:43 Starting Plug-In Plugin LSoftVerisure started successfully in 301 milliseconds Feb-11 21:30:43 LSoftVerisure Error Kunne ikke loge inn Feb-11 21:30:43 LSoftVerisure Debug Login utført Feb-11 21:30:43 LSoftVerisure Debug Logger inn Feb-11 21:30:43 LSoftVerisure Update every 600 second Feb-11 21:30:43 LSoftVerisure Debug a:2.7.62.0 Feb-11 21:30:43 LSoftVerisure Debug v:2.7.62.0 Feb-11 21:30:43 LSoftVerisure LogToFile:False Feb-11 21:30:43 LSoftVerisure Debug:True Feb-11 21:30:43 LSoftVerisure C:\Program Files (x86)\HomeSeer HS3 Feb-11 21:30:43 LSoftVerisure LSoftVerisure plugin initializing Feb-11 21:30:43 Starting Plug-In Initializing plugin LSoftVerisure ... Siter
lilfire Skrevet 12. februar 2019 Skrevet 12. februar 2019 10 timer siden, GO_Nilsen skrev: Får ikke linken til å virke. Sliter med at det ikke kommer opp noen devicer. Bare den som heter Verisure status: OK Kjører 2.6.293.0 Får feilmelding: feb-11 21.38.29 LSoftVerisure Error Finner ikke devices for lokasjon XXXXXXXXXXXX feb-11 21.38.29 LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"} feb-11 21.38.29 LSoftVerisure Error System.Net.WebException: The remote server returned an error: (503) Server Unavailable. at System.Net.HttpWebRequest.GetResponse() at Verisure.VerisureSync.(WebRequest ) at Verisure.VerisureSync.GetDevices(String giid, Int32 attempt) 2.6 har et problem med at et par av kallene mot verisure kun går mot server 01 og denne er nede nå. Jobber med at server skal velges automagisk i 2.7. Beta linker fungerer kun i et gitt tidsrom eller x antall nedlastninger - så om linken ikke fungere er dette brukt opp. Siter
lilfire Skrevet 12. februar 2019 Skrevet 12. februar 2019 10 timer siden, tonlof skrev: Hej, får följande fel med senaste betan. Har provat flera användarnamn och användarkontona fungerar felfritt på mypages. Feb-11 21:30:43 Starting Plug-In Plugin LSoftVerisure started successfully in 301 milliseconds Feb-11 21:30:43 LSoftVerisure Error Kunne ikke loge inn Feb-11 21:30:43 LSoftVerisure Debug Login utført Feb-11 21:30:43 LSoftVerisure Debug Logger inn Feb-11 21:30:43 LSoftVerisure Update every 600 second Feb-11 21:30:43 LSoftVerisure Debug a:2.7.62.0 Feb-11 21:30:43 LSoftVerisure Debug v:2.7.62.0 Feb-11 21:30:43 LSoftVerisure LogToFile:False Feb-11 21:30:43 LSoftVerisure Debug:True Feb-11 21:30:43 LSoftVerisure C:\Program Files (x86)\HomeSeer HS3 Feb-11 21:30:43 LSoftVerisure LSoftVerisure plugin initializing Feb-11 21:30:43 Starting Plug-In Initializing plugin LSoftVerisure ... Hmm, har du noen spesiele tegn i passordet ditt? Dette skal ikke ha noe betydning men vet jo aldri, har jo hatt en feil med dette før så. Siter
tonlof Skrevet 12. februar 2019 Skrevet 12. februar 2019 13 timer siden, lilfire skrev: Hmm, har du noen spesiele tegn i passordet ditt? Dette skal ikke ha noe betydning men vet jo aldri, har jo hatt en feil med dette før så. Jag hade ! i lösenordet men har tagit bort så att det bara är bokstäver och siffror men ingen skillnad. Siter
Trash2000 Skrevet 12. februar 2019 Skrevet 12. februar 2019 På 11.2.2019 den 12.50, lilfire skrev: Hmm, linux er ikke min sterkeste side desverre. Den feilmeldinga der indikerer jo at den benytter feil path for sqllite. Antar det er denne linjen du endret? <probing privatePath="Bin\LSoft\Verisure" /> Og du har denne path og fila "System.Data.SQLite.dll" liggende der? Og den er versjon 104? Pang! Har aldri fått opp pluginet i Linux tidligere. Ny retning på skråstreken gjorde susen Siter
jmoen Skrevet 12. februar 2019 Skrevet 12. februar 2019 On 11/02/2019 at 12:50, lilfire said: Hmm, linux er ikke min sterkeste side desverre. Den feilmeldinga der indikerer jo at den benytter feil path for sqllite. Antar det er denne linjen du endret? <probing privatePath="Bin\LSoft\Verisure" /> Og du har denne path og fila "System.Data.SQLite.dll" liggende der? Og den er versjon 104? Korrekt. Skal grave litt mer rundt SQLite saken, er vist kjent mono utfordring, bare jeg er tilbake på landjorden. -J- Siter
jmoen Skrevet 12. februar 2019 Skrevet 12. februar 2019 7 minutes ago, Trash2000 said: Pang! Har aldri fått opp pluginet i Linux tidligere. Ny retning på skråstreken gjorde susen Knall ?? Får du samme melding: feil ved opprettelse av databasekopling ? -J- Siter
Trash2000 Skrevet 12. februar 2019 Skrevet 12. februar 2019 3 minutter siden, jmoen skrev: Knall ?? Får du samme melding: feil ved opprettelse av databasekopling ? -J- Ser sånn ut, ja System.DllNotFoundException: SQLite.Interop.dll at (wrapper managed-to-native) System.Data.SQLite.UnsafeNativeMethods:sqlite3_config_none (System.Data.SQLite.SQLiteConfigOpsEnum) at System.Data.SQLite.SQLite3.StaticIsInitialized () [0x0001d] in :0 at System.Data.SQLite.SQLiteLog.Initialize () [0x00000] in :0 at System.Data.SQLite.SQLiteConnection..ctor (System.String connectionString, System.Boolean parseViaFramework) [0x00021] in :0 at System.Data.SQLite.SQLiteConnection..ctor (System.String connectionString) [0x00000] in :0 at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteConnection:.ctor (string) at Verisure.VerisureSync. (System.String ) [0x00000] in :0 at Verisure.VerisureSync.GenPage (System.String link) [0x005fc] in :0 Siter
lilfire Skrevet 13. februar 2019 Skrevet 13. februar 2019 10 timer siden, tonlof skrev: Jag hade ! i lösenordet men har tagit bort så att det bara är bokstäver och siffror men ingen skillnad. Sender deg en PM Siter
lilfire Skrevet 13. februar 2019 Skrevet 13. februar 2019 10 timer siden, Trash2000 skrev: System.DllNotFoundException: SQLite.Interop.dll Kan du forsøker flytte/kopiere mappene x64 og x86 fra "Bin\LSoft\Verisure" ut til root mappa til HS for å se om er probing i configen som ikke fungere Siter
Trash2000 Skrevet 13. februar 2019 Skrevet 13. februar 2019 9 timer siden, lilfire skrev: Kan du forsøker flytte/kopiere mappene x64 og x86 fra "Bin\LSoft\Verisure" ut til root mappa til HS for å se om er probing i configen som ikke fungere Løftet x64 og x84 til /usr/local/HomeSeer/. Samme db-feilmelding. Siter
Trash2000 Skrevet 13. februar 2019 Skrevet 13. februar 2019 1 time siden, Trash2000 skrev: Løftet x64 og x84 til /usr/local/HomeSeer/. Samme db-feilmelding. Restart hjalp! Litt ustabil, men fikk åpnet døra i alle fall en gang. Herlig :) Siter
jmoen Skrevet 14. februar 2019 Skrevet 14. februar 2019 On 13/02/2019 at 08:58, lilfire said: Kan du forsøker flytte/kopiere mappene x64 og x86 fra "Bin\LSoft\Verisure" ut til root mappa til HS for å se om er probing i configen som ikke fungere Testet litt frem og tilbake og ble til slutt kvitt feilmelding ved å kopiere over System.Data.SQLite.dll med den fra Z-Wave plugin Det som ikke funker er Graf, den er blank og jeg får ingen feilmeldinger. -J- Siter
lilfire Skrevet 15. februar 2019 Skrevet 15. februar 2019 På 13.2.2019 den 19.58, Trash2000 skrev: Restart hjalp! Litt ustabil, men fikk åpnet døra i alle fall en gang. Herlig At det hjalp å løfte filene betyr at det er probingen som ikke fungerer som den skal Første treffet jeg får med å google "mono probing linux" sender meg til HS forumet så kan være det er noe svakheter i HS når det gjelder probing og linux. 9 timer siden, jmoen skrev: Testet litt frem og tilbake og ble til slutt kvitt feilmelding ved å kopiere over System.Data.SQLite.dll med den fra Z-Wave plugin Det som ikke funker er Graf, den er blank og jeg får ingen feilmeldinger. -J- Du kopierte over hvilken fil? jeg ser at i mitt HS miljø benyter z-wave pluginen versjon 1.0.87. Mens jeg bruker versjon 1.0.104. så å skrive over "min" SQLite.dll med zwave sin er nok ikke en løsning. Ja Graf har fått lite prioriteringer i de siste versjonene. Jeg vuderer om jeg skal gi det en overhaling eller om jeg skal droppe det. For logging og presentasjon av data har man jo andre plugins man kan benyte som gjør en bedre jobb. Siter
lilfire Skrevet 16. februar 2019 Skrevet 16. februar 2019 På 13.2.2019 den 19.58, Trash2000 skrev: Restart hjalp! Litt ustabil, men fikk åpnet døra i alle fall en gang. Herlig Det er en probing path for verisure.dll filen også; "HomeSeer HS3\Bin\LSoft\Verisure\Verisure.dll.config" Har du fikset \ der også? For jeg anser ikke det å flytte de mappene ut til root som noen løsning. Siter
Trash2000 Skrevet 16. februar 2019 Skrevet 16. februar 2019 46 minutter siden, lilfire skrev: Det er en probing path for verisure.dll filen også; "HomeSeer HS3\Bin\LSoft\Verisure\Verisure.dll.config" Har du fikset \ der også? For jeg anser ikke det å flytte de mappene ut til root som noen løsning. Yup, byttet retning på skråstreken først ja. Siter
jmoen Skrevet 17. februar 2019 Skrevet 17. februar 2019 (endret) On 15/02/2019 at 07:37, lilfire said: At det hjalp å løfte filene betyr at det er probingen som ikke fungerer som den skal Første treffet jeg får med å google "mono probing linux" sender meg til HS forumet så kan være det er noe svakheter i HS når det gjelder probing og linux. Du kopierte over hvilken fil? jeg ser at i mitt HS miljø benyter z-wave pluginen versjon 1.0.87. Mens jeg bruker versjon 1.0.104. så å skrive over "min" SQLite.dll med zwave sin er nok ikke en løsning. Ja Graf har fått lite prioriteringer i de siste versjonene. Jeg vuderer om jeg skal gi det en overhaling eller om jeg skal droppe det. For logging og presentasjon av data har man jo andre plugins man kan benyte som gjør en bedre jobb. Det var System.Data.SQLite.dll filen, som ligger i plugin katalogen til ZWave, som jeg overskrev din dll med. Da forsvant alt av feilmeldinger og alt ser vel ut. Jeg antar det er noe i din dll som ikke spiller med min mono (kjører Raspbian) eller motsatt. Er uansett bare ett hack jeg ville prøve og det funket ? Endret 17. februar 2019 av jmoen Siter
