  1. I går
  2. Hey there! Welcome to the world of home automation—great to see you're starting with an energy-efficiency focus! I was in a similar position not too long ago, and I’ve learned quite a bit about creating a smart, energy-saving setup without losing comfort. Happy to share what’s worked for me: 1. Smart Hubs for Beginners If you're new, I'd recommend starting with Amazon Echo (Alexa) or Google Nest Hub. Both are beginner-friendly and support a wide range of energy-efficient smart devices. They’re easy to integrate with smart plugs, lights, and thermostats, and their ecosystems keep expanding. 2. Smart Plugs & Thermostats That Actually Help For smart plugs, TP-Link Kasa Smart Plugs are reliable, affordable, and come with great scheduling features. As for thermostats, nothing beats the Google Nest Learning Thermostat in my opinion—it adapts to your schedule and can significantly cut energy use over time. I reviewed a bunch of options recently on my site—here’s a full breakdown of the Top 10 Smart Gadgets for Energy Efficiency in 2025 if you want more product comparisons and pros/cons. 3. Managing Seasonal Changes Seasonal adjustments are key! I use smart thermostats and automated lighting scenes based on sunrise/sunset and temperature changes. Some systems, like Nest or Ecobee, allow seasonal scheduling and remote control, which is super helpful during winter and summer months. If you’re prepping for colder seasons, you might find these Winter Energy Saving Tips useful too—it’s packed with practical ways to automate heat and lighting while keeping bills in check. 4. Monitoring Energy Usage Platforms like Sense Energy Monitor, Emporia Vue, or even your smart plug apps give detailed usage reports. They helped me realize which appliances were energy hogs. The insights definitely helped cut costs. If you're trying to figure out what makes the most sense for your setup, here's a beginner-friendly Home Energy Efficiency Guide that might give you a clearer roadmap. Feel free to ask if you need help choosing between products or setting up automation routines. Home automation can feel overwhelming at first, but with a focus on energy savings, it pays off really quickly. Good luck transforming your space into a smarter, more efficient home!
  3. Jeg ble litt nysgjerrig på dette anlegget og sjekket brukerveiledningen. På side 93 beskrives Boost funksjonen og beskriver at hastigheten både på inn og ut-luft økes. Ikke bare på innluft, slik jeg er vant til på Systemair ved aktivering av «komfyravtrekk» funksjonen der. Derfor mener jeg du kan koble deg innpå de to lederne som går til «Cooker hood» på skjemaet og koble dette til OUT1 på Smart implant, tilsvarende det som vises på side 14 i Smart Implant manualen. Slik jeg forstår dette vil da ventilasjonsanlegget aktivere boost modus så lenge utgangen på Smart implant er lukket og deaktiveres igjen når utgangen åpnes. Fibaroen er ganske grei på strømforsyning (9-30V DC), du kan trolig drive den med en strømforsyning du har liggende. I værste fall kan du teste med et 9v batteri. 🙂 Men dette dekker kun en funksjon, boost. Det å bytte til borte modus ser jeg ingen metode for i skjemaet. Utfordringen er at dette anlegget styres av en trådløs fjernkontroll som jeg ikke finner noe dokumentasjon på ift frekvens. Bruker den 433 Mhz kan du kanskje fange opp relevant kommando, men ut fra menysystemet på den tror jeg heller dette er bluetooth basert og at det ikke er praktisk mulig å fange opp den konkrete kommandoen. Jeg håper jeg tar feil, men tror du trenger modbus for full kontroll på dette anlegget.
  4. Siste uke
  5. Takk for både rask og god respons! Det er et Østberg Heru 100T EC-anlegg fra 2013. I følge github’en må jeg inn i fjernkontrollen og aktivere modbus. For å komme dit må man ha Gen 3 fjernkontroll, og kretskort. Problemet er at jeg tydeligvis har gen 2, og dermed må ut med mange tusenlapper for å bytte. Dersom en smart implant kan hjelpe meg litt, er mye gjort.
  6. Jeg kjenner ikke ditt anlegg, men har etablert styring over modbus både hjemme (Systemair VSR300 styrt av Home Assistant) og hos min bror (Flexit Nordic S4 styrt av Homey Pro). I ditt koblingsskjema står det modbus på en utgang. Jeg søkte og fant dette: https://github.com/toringer/home-assistant-heru Det er rett nok for styring fra Home Assistant, men der vil du i alle fall finne dokumentert hvilke kommandoer som må sendes over modbus for å styre anlegget. Da har du tilgang til alle anleggets funksjoner. Det jeg tror du kan gjøre med et eksternt rele som Fibaro smart implant er begrenset til å koble deg på noen av inngangene vist på tegningen, som «Cooker hood»/komfyravtrekk. Men komfyravtrekk har begrenset nytteverdi, da den øker hastigheten kun på viften inn, for å kompensere for undertrykket i huset som skapes av komfyravtrekket. Jeg ser ikke hvordan du skal kunne endre hastigheten på avtrekk her, men det er det sikkert andre som kan bidra med.
  7. Nytt hus overtatt og den balanserte ventilasjonen (Østberg Heru 100T ec) er av den gamle sorten (les: ikke smart). Jeg vurderer å sette inn en Smart Implant i den balanserte ventilasjonen, men koblingsskjema og jeg er ikke spesielt gode venner. Jeg tenkte å inn med muligheter for å sette systemet i feriemodus, booste avtrekk ved dusjing osv. Noen som har god kontroll på dette og kan hjelpe meg litt på vei?
  8. Hmmmm... Fikk et tips om å ta ut en systemlogg fra /e/OS/ så da ble det enda en ny systeminstallasjon... og GPS virker!!! Har kjørt gjennom OTA oppdateringer fra 2.7 til 2.8, 2.9 og 3.0.1 og GPS virker i alle versjoner. Hva kan en lære av dette da? Sannsynligvis ingenting men det har nå vært gøy å gjøre disse "farlige" installasjonene som kan få telefonen inn i permafrosten mange ganger og med rimelig grei suksess hver gang. Har vært noen få tilfeller der jeg har måtte holde powerknappen inne i 20-30 sekund for å få den til å dø...
  9. Er det flere enn meg som driver og leker med alternativer til Android på telefonen? Har brukt /e/OS/ på en Samsung Galaxy S9 i lang tid (fra ver 0.7 til 3.01) og det fungerer helt supert men har noen bagatellmessige ulemper som jeg skulle likt å pynte på. Nå har tiden kommet til oppgradering siden S9en er 7 år med knust glass og et batteri som bare varer en time... Kjøpte meg en Google Pixel 7 Pro 256. Ved installasjon av /e/OS/ får jeg ikke liv i GPSen og /e/OS/ community har ikke kommet opp med løsninger eller forklaringer enda så pr i dag er ikke /e/OS/ aktuell... GPSen fungerer med en mengde andre operativsystem jeg har prøvd og Pixel 7 Pro er også på kompatibelitetslisten til /e/OS/... Der finnes jo et snes alternativer men så langt har jeg sett meg ut disse: LineageOS: Prøvekjørt og ser ut til å funke fint men en må bare huske på å installere MindTheGApps under installasjonen for å få tilgang til Google Apps. GrapheneOS: Svært begrenset telefonstøtte men Pixel serien er støttet og det er jo det jeg har... CalyxOS: Er jo mange flere alternativer men starter med disse. Når en har fått det inn i fingrene så tar det jo ikke mange minutt å skifte operativsystem... Noen som har gode tips om hva en bør gå for? Det handler jo om å bli kvitt den skjulte sporingen og Googles jernhånd over MINE overvåkingsmuligheter som samtaleopptak.
  10. Hei, jeg kom over denne tråden nå... Jeg har målere (med Modbus rs485) fra Carlo Gavazzi både hjemme på TN nett og på hytta, de viser nøyaktig strømtrekk på alle 3 fasene. EM540 har jeg begge steder. Jeg henter data fra måler til home Assistant.
  11. Ser veldig bra ut. 12th gen Intel CPUer er meget bra, stort steg imo opp fra 11th gen. Bruker du virkelig så mye minne? Jeg har 64gb ram i min proxmox, kjører 10 VMer (lyver litt, blanding av VM og CT) og bruker ~60% av minnet. Da er jeg ikke gjerrig på minnet. Digg med stor SSD. Jeg gikk selv over fra Vmware (realtek, hello hello..) til Proxmox - største forskjellen for meg i starten var at man kunne sette opp små maskiner kalt konteinere (CT). Veldig nyttig når man ikke trenger et helt OS. Typ litt som docker.
  12. Hei, Jeg la merke til spørsmålet ditt i forbifarten. Du kan dessverre ikke strømme TV 2 Nyhetskanalen på samme måte som NRK sine sendinger, og årsaken er enkel: TV 2 benytter kryptering og krever innlogging før du får tilgang til strømmene deres – selv når de er gratis tilgjengelige. Dette står i kontrast til NRK, som ikke benytter tilsvarende kryptering. Dermed kan NRKs direktesendinger hentes og castes direkte fra strømme-URL-en uten å gå via nettsider eller autentisering. For å få TV 2 til å fungere, må du enten: Finne en tredjepart som tilbyr en ukryptert strøm (som sannsynligvis ikke skjer med TV 2s tillatelse), eller Lage en egen løsning, for eksempel en Python-applikasjon, som logger inn og henter de nødvendige tilgangstokenene før du videresender strømmen til ønsket avspillingsenhet. Det løser kanskje ikke problemet ditt direkte, men forhåpentligvis forklarer det hvorfor du får NRK til å fungere – men ikke TV 2. For referanse: https://www.tv2.no/video/live/nyhetsstrommen/20259505 er noe av det nærmeste du kommer en direktestrøm uten å gå via nettsidene deres, men linken som spilles av her, går også igjennom en godkjenningsprosess og får en tidsbegrenset tilgang til videostrømmen gjjennom Akamai. Linken du referer til har funksjon for å spille av fra flere tilbydere enn NRK ser jeg, så du kan kanskje rette en forespørsel til de som har utviklet den om de vil integrere de nødvendige stegene for å kunne strømme TV2 Nyhetskanalen også. Slik det er i dag, er dette ikke mulig med bruk av det integrasjonen cast støtter utfra det som er skrevet nå, det vil kreve en endring og utvidelse for å få dette til å fungere.
  13. Hei, Jeg har liten erfaring med å dele emner eller filer på forum fra tidligere, så om jeg nå poster på ett helt feil sted er det fint om jeg kan få hjelp til å flytte dette dit det skulle ha vært. Jeg vil gjerne dele en blueprint jeg laget for en tid tilbake, som lar deg bruke Namron 8-kanals bryter (kjøpt hos Elektroimportøren) til å styre fire ulike lys – med støtte for både av/på-funksjon og dimming, basert på angitte terskler og intervaller. Bakgrunnen er at jeg bruker Fibaro Dimmer 2 via Z-Wave til flere av lysene mine. Namron-bryteren benytter Zigbee og kan derfor ikke kommunisere direkte med disse. Dette skapte en utfordring – særlig for dimmefunksjonen – da bryteren ikke kunne styre lysene direkte. Jeg begynte med en enkel automatisering for dimming, men den ble fort uoversiktlig når jeg skulle duplisere den for fire lys per bryter, med både av/på og dimmefunksjon. Derfor laget jeg en mer fleksibel og gjenbrukbar blueprint. Slik fungerer blueprinten: Velg bryteren du vil bruke. I mitt tilfelle er den tilgjengelig via Zigbee2MQTT, og defineres som en MQTT-enhet i blueprinten. Bruker du en annen integrasjon enn MQTT, må du gjøre noen manuelle justeringer. Velg hvilke lys du vil styre. Du kan tilordne lys (eller grupper) til hver av de fire knappene (L1–L4). Angi dimmeparametere. Du kan definere hvor mye lyset skal justeres per steg (f.eks. ±5 %), og hvor ofte det skal skje (f.eks. hvert 0,4 sekund) mens knappen holdes inne. Funksjonalitet: Kort trykk slår lyset av eller på. Dimming styres via MQTT-meldingene brightness_move_up, brightness_move_down og brightness_stop. Når en dimmekommando registreres: Blueprinten sjekker om dimming_active er false. Hvis ja, settes den til true, og en løkke starter som trinnvis justerer lysstyrken. Løkken stopper automatisk hvis: Lysstyrken når 0 % eller 100 %. brightness_stop mottas (når knappen slippes), og dimming_active settes tilbake til false. Siden dimming kun kan skje når dimming_active er false, tillater blueprinten dimming av kun ett lys om gangen. Jeg vurderte mer avansert logikk for å støtte flere samtidige dimmeprosesser, men kompleksiteten gjorde det lite hensiktsmessig – og jeg har heller ikke hatt behov for det. Blueprinten inneholder fortsatt litt debug-logging, som du kan fjerne eller tilpasse etter behov. Jeg har brukt denne løsningen i flere måneder uten problemer – den har fungert stabilt og som ønsket. Jeg har desverre ikke så mye ressurser tilgjengelig for brukerstøtte så håper det kan gi glede i den formen det er i slik det er nå. (edit: la med ett bilde av blueprint, bare for å illustrere bedre) namron_switch_blueprint.yaml
  14. Tidligere
  15. Har byttet en del enheter fra Z-Wave til Matter. Benytter Apple TV som Hub / Thread Border Router. Har også lagt de samme enhetene til min egen Matter kontroller. Da kan jeg bruke Apple Home og i tillegg gjøre mer avanserte ting med egen kode. De fleste Matter enheten har jeg laget selv som: Aidon Han-leser for å følge med på strømforbruk, diverse enheter for å måle luftkvalitet (PM, VOC, CO2, NOx etc.). luftfuktighet, lufttrykk, temperatur, lysstyrke. Fungerer meget bra. Bruker en blanding av Espressif ESP32-C5 og Silicon Labs Dev Kits.
  16. Fungerer bra i Apple Home også.
  17. Jeg holder på å pusle litt med Homeseer Touch igjen, og ser at det finnes en del actions for devicer/features som regnes som en thermostat. Hos meg er det kun varmekablene i gangen som gjenkjennes som en thermostat, og som jeg dermed kan kontrollere ved hjelp av disse action'ene. Jeg har ikke greid å finne noe informasjon om hvorfor det er sånn, men jeg ser at "Device Type" (under Advanced Information i Status/Graphics fanen) er "Api NotSpecified SubType Temperature", "Api NotSpecified SubType ModeSet" etc. for varmekablene, men kun oppgitt til "API4" for varmepumpene mine. Vet noen om det er noe måte å redigere dette på, sånn at varmepumpene lar seg kontrollere som thermostater?
  18. Moskus
    Sliter med HomeSeer
    Ja, det er veldig sært! Nå får ikke jeg med alt verden, men denne var ny for meg.
  19. Kan se ut som om det blir denne maskinen: Intel Core i7-12700 CPU Kingston FURY Beast DDR4 3200MHz 128GB Kingston NV3 SSD 2TB ASUS PRIME B760M-A WIFI D4 Hovedkort
  20. Min gamle ESXi-server begynner virkelig å bli akkurat det: Gammel. Jeg trenger en ny. Men jeg har oppdaget at jeg her helt ute på hardware, totalt blankt. Jeg trenger altså en ny PC som skal kjøre Proxmox. Den skal kjøre 5-6-7 ulike VMer. Jeg har i dag 72 GB med minne, men vil muligens ha mer? SSD-disk. CPU? GPU, i det minste mulighet for det? Plex kan dra nytte av det. Hjelp meg! 😄 Hva skal jeg kjøpe?
  21. Ja, jeg fant en løsning. Basert på svaret / forklaringen fra Pål hos Namron tok jeg kontakt med Elektroimportøren hvor jeg kjøpte dimmerne mine, og fikk tak i denne: https://www.elektroimportoren.no/conbee-iii-zigbee-usb-stick/94581/Product.html Deretter krevde det en del prøving og feiling mens jeg forsøkte å følge guidene Pål delte (hvor linkene i tråden her dessverre ikke ser ut til å fungere lenger). Etter noen mislykkede forsøk kom jeg frem til en fremgangsmåte som har gjort det mulig å oppdatere dimmerne mine. Det tar meg ca 20 minutter å oppdatere hver dimmer. Etter oppdateringen så rapporterer dimmerne at de kjører FW versjon 3.12, og de kan nå styres av Homey som forventet (uten at de begynner å leve sitt eget liv og dimmer sporadisk opp og ned de påfølgende 30 sekundene).
  22. Har "i evigheter" manglet emojis i Brave browser på hjemmeautomasjon.no Noe lurt jeg kan gjøre for å få de på plass? De er der i Firefox og i Brave på andre Invision fora... Har etterlyst det noen ganger men Node-RED kan fremdeles ikke velges som system i profilen...
  23. Litt mer finpussing av GPS... Sliter jo en del med feil sjekksum i meldingene fra NEO6-GPSen. Ser andre løser problemet ved å øke mottaksbufferstørrelsen i ESP32 til 512 men jeg har gått helt opp til 4096 uten at jeg ser noen bedring... For å eliminere feilkilder gjør jeg nå en sjekksum-sjekk i ESP32 og fjerner setninger med feil før data sendes til MQTT/Node-RED og har nå kommet opp i 100% riktig mottak i Node-RED sin sjekksum-sjekk. For å slippe å skru opp klipperen ved programoppdateringer har jeg tatt i bruk https://pypi.org/project/micropython-ota/ og den funker fint. Programoppdatering skjer da ved krasj eller når jeg skrur klipperen av/på. Kan jo lage til en manuell fjernoppdatering men ser ikke det store poenget når av/på knappen gjør jobben... Når jeg nå leter etter årsak til den halvhjertede kommunikasjonen finner jeg at NEO6 SKAL forsynes med 3.3V (<3.6V) og ved omkobling ser jeg at en masse av de feile GPS-setningene forsvinner... En kunne jo nesten tro at jeg hadde benyttet meg av KS (kunstig sladder, aka AI/KI)... Kjæm sæg
  24. Rudi
    Sliter med HomeSeer
    HMM, sjekket på server i dag, da var det celsius igjen. Merkelig!!!!
  25. Rudi
    Sliter med HomeSeer
    De kommer inn i Fahrenheit.
  26. Jeg har gått for en helt vanlig 230VAC magnetventil i samme størrelse som vannrøret inn. Satt på ledning med støpsel. Så kan bruke hvilken som helst plugg til å styre dette.
  27. Ja, absolutt. Men så var det den vanlige misforståtte "forenklingen" i å beholde det man har fra før.... Ville nok vært mye enklere å bytte alt sammen til LED-paneler med zigbee-driver. Hadde jeg bare ikke vært så fordømt sta.
  28. Er det noen som har gjort research eller har erfaring og anbefaling på en god vannstopper/ vannstoppventil for hovedkran som allerhelst har god integrering mot HomeAssistant? Av de alternativene jeg har sett på er kanskje Resideo L5 den mest interessante, evt Waterguard+, men er ikke helt sikker på om jeg synes wifi er det beste for slike systemer. Grohe Sense Guard har jeg inntrykk av at folk ikke er helt fornøyd med.
