  1. I dag
  2. const fz = require("zigbee-herdsman-converters/converters/fromZigbee"); const tz = require("zigbee-herdsman-converters/converters/toZigbee"); const exposes = require("zigbee-herdsman-converters/lib/exposes"); const reporting = require("zigbee-herdsman-converters/lib/reporting"); const e = exposes.presets; const ea = exposes.access; module.exports = [ { zigbeeModel: ["4512759"], model: "4512759", vendor: "Namron", description: "Zigbee thermostat 16A (variant of 4512758)", fromZigbee: [ fz.thermostat, fz.metering, fz.electrical_measurement, ], toZigbee: [ tz.thermostat_local_temperature, tz.thermostat_occupied_heating_setpoint, tz.thermostat_local_temperature_calibration, tz.thermostat_system_mode, tz.thermostat_running_mode, tz.thermostat_control_sequence_of_operation, ], exposes: [ e.climate() .withLocalTemperature() .withSetpoint('occupied_heating_setpoint', 0, 40, 0.5) .withLocalTemperatureCalibration(-10, 10, 1) .withSystemMode(['off', 'heat']) .withRunningState(['idle', 'heat']), e.binary('child_lock', ea.ALL, 'LOCK', 'UNLOCK') .withDescription('Enables/disables physical input on the device'), e.switch(), e.power(), e.current(), e.energy(), ], configure: async (device, coordinatorEndpoint, logger) => { const endpoint = device.getEndpoint(1); await reporting.bind(endpoint, coordinatorEndpoint, [ 'genBasic', 'genIdentify', 'hvacThermostat', 'seMetering', 'haElectricalMeasurement', ]); await reporting.thermostatTemperature(endpoint, {min: 0, change: 50}); await reporting.thermostatOccupiedHeatingSetpoint(endpoint); await reporting.thermostatKeypadLockMode(endpoint); await reporting.currentSummDelivered(endpoint); await reporting.activePower(endpoint); await endpoint.read('hvacThermostat', [ 'systemMode', 'runningMode', 'occupiedHeatingSetpoint', ]); device.powerSource = 'Mains (single phase)'; device.save(); }, }, ]; I den nyeste Z2M versjonen må filene med konvertere ligge i en mappe "external_converters" som ligger under "zigbee2mqtt" mappen. Nå fungerer det å endre temperatur, samt å sett termostaten i off eller heat. Lenger har jeg ikke kommet. Om du finner ut mer, så oppdater gjerne i denne tråden 🙂
  3. @storeulv Hei, Foreløpig er ikke konvektorovnen Matter-sertifisert. Følgende enheter støtter Matter per i dag: Generasjon 3 oljeovner Generasjon 4 panelovner Gulvvarmetermostat (definert som generasjon 4) Smartplugg (definert som generasjon 4) Det er planlagt støtte for Matter på følgende enheter: Gen3 plugg Gen3 konvektorovn (som du har) Gen3 COMAX-ovn Når kommer det? Det er vanskelig å gi en nøyaktig dato, men vi håper å få på plass støtte for Gen3 konvektorovn innen februar 2026. Årsaken er rett og slett at vi har begrenset med utviklingskapasitet, og må prioritere tiden vår der den trengs mest. Vi setter pris på tålmodigheten og forståelsen din, og holder deg gjerne oppdatert når det nærmer seg lansering.
  4. Har forsøkt å søke uten hell, men jeg har kommet over denne siden der Mill sine Matter-sertifiseringer er listet. Jeg har en Mill konvektor gulvovn gen 3, og om jeg forstår det rett så er ikke denne sertifisert for Matter? Søk på Google svarer at "joda, den er klar", men jeg får ikke til koblingen. Om den ikke er sertifisert så har jeg to spørsmål: er sertifisering av konvektorovner i pipeline? om de skal være klare så er det muligens en mangel i appen, er dette i så tilfelle en kjent feil?
  5. Jeg fikk ikke gjort noe mer, del gjerne det du har fått til 👍
  6. Hei. Gammel tråd, men er det noen som har fått denne til å fungere i Z2M? Den hvite versjonen 4512758 som er identisk går inn og alt utenom strømforbruk fungerer. Jeg fikk Copilot til å (etter mange forsøk) lage en config der jeg fikk inn alle data (utenom strømforbruk), men den klarte ikke å sende kommandoer tilbake til termostaten
  7. @DOS @Michael Seitz Takk for god hjelp og oppfølging. Har fått den opp nå. Måtte bruke litt makt og må leve med noen knekte klips. Ser ut som den er såpass i orden at det skal gå fint å sette den sammen igjen (forhåpentligvis).
  8. I går
  9. Jeg tok en titt på min router og så at side-dekselet faktisk har flere plastdingser som passer inn i motstykker på sideveggen. Det er nok det som gjør det vanskelig å klemme sammen side-dekslet. Ja, du må komme deg mellom klips og nippelen med et verktøy.
  10. Om jeg husker er det enklere å begynne fra bunnen og jobbe seg oppover. Og så trenger du 2 verktøy…
  11. Hm, det er nok den eneste veien å gå ... altså å klemme klipsene innover. Kanskje funker det som vist på bildet. Prøv å klemme side-dekslet innover på en side, og å bøye side-veggen utover med en skrutrekker eller en tykk (og sløv!) kniv. Det er lettere å klemme inn side-dekslet i midten og ved foten fordi toppen er forsterket med ekstra plast. Du ser jo på de bildene til Bjørn og Torbjørn hvor de fire klipsene er. Lykke til 🙂
  12. Jeg har en Homey Pro 2023 som logger seg av hele tiden. Etter å ha resatt ved å ta spenningen, logger den seg av etter 30-60 min igjen (lyser rødt hele tiden, etter at den har stoppet). Vet at Namron har problemer med at produktene genererer for mye trafikk, men har deaktivert Namron Appen, men har sett meldinger med info om minne problemer. Finnes der noen feil logg, som jeg evt. kan sjekke? Mvh. Helge
  13. Hei, ref tidlig i denne tråden så er det noen bilder som viser 4 klips på hver side, Det nytter ikke å få klemt den inn får å klips til løsne, eller dratt det fra hverandre.
  14. Dere har nok veldig rett, folkens. Mange takk! Står det noe i NEK700 om krav til klargjøring av infrastruktur i boliger mtp. elkom?
  15. Siste uke
  16. Det er lenge siden jeg åpnet min router. Kunne kanskje du laste opp bilder som viser hvor langt du har kommet og hvilken klips du ikke får av?
  17. Hei Olav Har du forsatt nRF52840 Dongle til salgs? Kjøper gjerne 2 stk for 100kr + frakt
  18. Det går helt fint. Har en Easee Equalizer og en Tibber Puls koblet på samme port med en enkel RJ45 splitter. En av dem må forsynes med strøm direkte, f.eks fra en gammel mobillader.
  19. Noen som har testet å koble til 2 HAN-lesere på samme HAN-port? Det skal vel i teorien kunne fungere siden det er en bus?
  20. Z-TRM3 har plutselig ingen info tilgjengelig i Z-Wave JS (Home Assistant). Jeg har forsøkt å re-interview, exclude, include osv, men samme resultat. Enheten kommer bare opp unknown som på bilde. Alt info var korrekt tidligere. Noen som vet hvordan man får den til å fungere riktig igjen?
  21. Hei, Har lest gjennom denne tråden nå utallige ganger og jeg er ganske ny på dette. Så gi meg litt slack for evt feil her 😅 Sitter her med Zyxel EX5700 og prøver å få av plastikk "chassiet". Har sett på bilder postet av @autoTorbjørn, men jeg har ikke nubbkjangs til å få av klips, har heller ikke lyst til å fikle med antennene i toppen. Har fått av toppen. Bunnen måtte jeg knekke av festene til foten. Har klart å delvis få opp et klips eller to på hver side i toppen. - Utover dette så sliter jeg veldig. Noen tips? Evt bilder?
  22. Du har rett, leste ikke godt og langt nok. Bra konklusjonen ble den samme. 😊
  23. ekomloven gjelder definitivt også privatpersoner. "virksomhet" er nok her å forstå som "aktiviteter". Det er bare å lese videre i § 1-2. Absolutt ikke fritt fram for privatpersoner å bruke alt mulig av radiofrekvenser f.eks, og dette er loven som begrenser det Men som storeulv påpeker så gjelder kapittel 2 bare tilbydere, definert i § 1-5 som Det kan altså også væe en fysisk person. Men normalt tilbyr ikke folk slike tjenester til andre fra sine hjemmenettverk
  24. Det er jeg helt enig i, og det bekreftes i lovens innledning: «§ 1-2.Saklig virkeområde Loven gjelder virksomhet knyttet til elektronisk kommunikasjon og tilhørende utstyr og datasentre.» Privatpersoner er ikke virksomheter.
  25. Det skal være ganske ålreit dekning da den trådløse routeren ikke er så langt unna. Er også der jeg jobber og benytter trådløst nett mot jobbPC som aldri har problemer. Forsøkt en restart av router og modem nylig uten at det hjalp.
  26. EKOM-lovens §2 tituleres "Krav til tilbyder..." Disse paragrafene er da etter min tolkning ikke relevante for hvermannsen, men de er definitivt relevante for de som skal tilby nettjenester. Så da kan du, fortsatt etter min tolkning 😉 trekke så mye ethernet du bare ønsker hjemme hos deg selv. Eller hos en kompis...du er uansett ikke en tilbyder av hverken nett eller tjenester på nettet.
  27. God dag. Litt tilfeldig kom jeg over den "nye" elkom-loven og fikk nesten kaffen i halsen, for der står det følgende: § 2-7.Prosjektering, installasjon, vedlikehold og sammenkobling av elektroniske kommunikasjonsnett Virksomhet som er ansvarlig for prosjektering, installasjon, vedlikehold eller sammenkobling av elektroniske kommunikasjonsnett, skal ha tillatelse fra departementet. Virksomheten skal sikre og dokumentere at det elektroniske kommunikasjonsnettet bygges på en faglig forsvarlig måte og med tilfredsstillende kvalitet. Eier av elektronisk kommunikasjonsnett skal bruke virksomhet som innehar tillatelse etter første ledd, ved prosjektering, installasjon, vedlikehold og sammenkobling av elektroniske kommunikasjonsnett, og skal kunne dokumentere at nettet er bygget på en faglig forsvarlig måte og med tilfredsstillende kvalitet. [...] https://lovdata.no/lov/2024-12-13-76/§2-7 Forøvrig er definisjonen av elektronisk kommunikasjonsnett: System for signaltransport, uavhengig av om dette er basert på permanent infrastruktur eller sentralisert styring, som muliggjør overføring av lyd, tekst, bilder eller andre data ved hjelp av elektromagnetiske signaler i fritt rom eller kabel, der radioutstyr, svitsjer, annet koblings- og rutingsutstyr, tilhørende utstyr eller funksjoner inngår, herunder nettverkselementer som ikke er aktive. Jeg lurer på hva denne lovteksten egentlig betyr i praksis. Kan vi ikke trekke ethernetkabler i eget hus?
