149
Alt skrevet av Fermate
It happened! Z-Uno is available for order! Find you favorite Z-Wave shop in our Where to buy list. More resellers to be listed soon. Start working with your Z-Uno board by following instructions on Getting started page. If you experience a problem with your Z-Uno, please check for a solution on Troubleshooting page. If this does not help, please write us on the forum or by mail on [email protected]. We would also like to encourage you to share your projects with others. Send us descriptions, photos, schematics and sketch to upload on Z-Uno Projects page. New C++ beta released (version 2.0.3). What's new? millis() function implemented Serial avaliable, peek, parseInt, parseFloat I2C library added (Wire.h) based on I2C library and example for MCP23017 based on I2C library and example for BMP180 SPI library added (SPI.h) Keypad library added (called ZMEKeypad) fixed update problems from 0.6.2, 0.6.3, 0.6.7, 0.7.0 and 2.0.x bits operations: bitRead, bitSet, bitClear, bitWrite Macro ARDUINO and F_CPU added Like before, this C++ beta release is available under http://rus.z-wave.me/files/z-uno/test-ucxx/package_z-wave.me_index.json URL (please remove stable URL in Arduino IDE settings and put this instead) In next versions we will add DHT11 and some other examples. We plan to finally release stable C++ version in August to substitute current 0.x.x branch (C only) by C++ enabled 2.x.x branch. Copyright © 2016 Z-Wave.Me, All rights reserved. You are receiving this email because you subscribed to Z-Uno mailing list. Our mailing address is: Z-Wave.Me ul. Schepkina, 47 Moscow, 129110 Russia Add us to your address book Want to change how you receive these emails? You can update your preferences or unsubscribe from this list
Teamviewer er fint fordi en kan sette det opp til å starte med serveren etter boot. Grei å ha som en reserveløsning som alltid er der og som også gir et hint om at maskinen kommer opp igjen etter en boot. Men for å JOBBE på er RDP mye smooth'ere syns jeg.
Bare en liten presisering: Z-uno er ikke en addon til en Arduino, det er en selvstendig microprosessor som kan programmeres med Arduino programmerings miljøet. Den har en innebygget Z-wave modul som kan eksponere forskjellige z-wave devicer etter behov og har pinner som du kan måle/styre ting med, med din egen kode mellom z-wave enheten og pinnene. Den er tenkt til å bygge z-wave moduler med for input / output og en del innebygget intelligens.
For meg så ser det ut til at den ThinKnx serveren ikke er en "gateway" eller et "rent KNX mot Z-wave grensesnitt" som du kaller det. Jeg er redd den er et skybasert styringssystem ala Zipato, som kan kommunisere med KNX og Z-wave og hvor logikken mellom disse legges i dette styrings systemet. (Om så styringen lastes ned og kjøres lokalt kan jo hende) Har du sjekket hvordan ThinKnx'en settes opp? (Brukerveiledningen)
Se der ja Hm, men du må i alle tilfelle ha noe som sier at når den Z-wave noden sender det signalet med den verdien så skal det gjøres om til en gruppe kommando på den gruppen med verdien som parameter..
Jeg programmerte en liten snutt som sendte og mottok KNX telegrammer for et år tid siden. Hadde tenkt å lage noe plugin greier til HomeSeer men HomeSeer delen er ikke bare - bare. Og jeg har ingen KNX i huset selv. Jeg tenkte at en kunne koble grupper fra KNX mot Eventer i HomeSeer og så kunne trigge grupper i KNX fra Actions på Devicer i HomeSeer. Programmerer du noe Visual Basic selv? KNX biblioteket var ganske greit, men du må jo ha noe i mellom det og Z-wave da... Og HomeSeer blir vel HELT overkill for deg?
Uæ! Kan kunne jeg spart meg for pakka som gikk i kveld også Lillestrøm på kveld Oslo på jobb/dagtid
Søren nå sendte jeg akkurat IKEA dingsene til deg uten å se dette. Da må jeg ut med nye 160 Kr i porto Hva med 660 Kr
Z-Uno is comming! Dear Z-Uno followers! We are happy to announce that Z-Uno is now available for pre-order from Z-Wave Europe. Currently only 868/869 MHZ version is available (Europe and Russia). Check your local Z-Wave distributor for availability in your preferred e-shop. Meanwhile we have released new Z-Uno software version 0.7.1. What's new? New 10 channels certification sketch added to examples (Z-Wave Plus certified sketch) Fixed problem with Z-Uno having nodeId > 50 (was unstable in large networks) Many minor fixes (listed on github) We are also working to release C++ version soon (version 2.0.3). What will be new in C++ version? DHT-11 library built in 1-wire, SPI and I2C protocols support many-many fixes Documentation on our website is also improving. New examples added (like this CO2 sensor). More examples and projects will be added soon. Copyright © 2016 Z-Wave.Me, All rights reserved. You are receiving this email because you subscribed to Z-Uno mailing list. Our mailing address is: Z-Wave.Me ul. Schepkina, 47 Moscow, 129110 Russia Add us to your address book Want to change how you receive these emails? You can update your preferences or unsubscribe from this list
Z-Uno is comming! Dear Z-Uno followers! We are happy to announce that Z-Uno is now available for pre-order from Z-Wave Europe. Currently only 868/869 MHZ version is available (Europe and Russia). Check your local Z-Wave distributor for availability in your preferred e-shop. Meanwhile we have released new Z-Uno software version 0.7.1. What's new? New 10 channels certification sketch added to examples (Z-Wave Plus certified sketch) Fixed problem with Z-Uno having nodeId > 50 (was unstable in large networks) Many minor fixes (listed on github) We are also working to release C++ version soon (version 2.0.3). What will be new in C++ version? DHT-11 library built in 1-wire, SPI and I2C protocols support many-many fixes Documentation on our website is also improving. New examples added (like this CO2 sensor). More examples and projects will be added soon. Copyright © 2016 Z-Wave.Me, All rights reserved. You are receiving this email because you subscribed to Z-Uno mailing list. Our mailing address is: Z-Wave.Me ul. Schepkina, 47 Moscow, 129110 Russia Add us to your address book Want to change how you receive these emails? You can update your preferences or unsubscribe from this list View full record
Jeg mener at den skal klare to lysrør ja.
- 3 svar
Ok pm meg med adressen din da Sent from my iPhone using Tapatalk
Ok Men jeg er i Danmark de neste 3 ukene så jeg får ikke sendt dem før jeg kommer hjem
Hehe jeg ga bort 4 stykker av dem til en venn fordi jeg ikke trodde de hadde samme kapabiliter som Touch. Får dem sikkert tilbake om jeg ber om det
Kan det ha noe med kaffe å gjøre?
Kan Duett styres fra HomeSeer og spille fra Tidal/Spotify?
Greia med Conrad antennen er at den er en GP (Ground Plane) antenne. Det vil si at den har en "motvekt" i de tre pinnene som peker nedover og er koblet til "jord". (Ved å skru ut en av pinnene kan du lage en retningsvirkende antenne da den vil sende mindre i den retningen der pinnen mangler) Ikke til salgs men til gi-bort (Jeg vil tro en slik hjemmegjort en er like god som Conrad antennen, om en ser bort fra fysiske ting som vind etc)
Dette er altså alternativet til å bestille en slik: http://www.conrad.com/ce/en/product/190073/Antenna-Aurel-GP-433
Du ble så stille. Var det for dyrt? Har du et skambud?
